A14T unique parts. From the 1976 B210 JDM parts catalog. Parts that are the same as a regular B210 engine are not listed here.
Also see:
- Hitachi Twin Carb (A12GX, A12T and A14T engines)
Engine
- 10101-H8425 GASKET KIT-ENGINE REPAIR
- 10102-H8400 ENGINE ASS'Y-BARE [long block]
- 10103-H8400 ENGINE ASS'Y-SHORT
- 11010-H8400 BLOCK ASS'Y-CYLINDER
- 21045-H8400 PIPE-SUCTION WATER PUMP
- 13001-H5700 CAMSHAFT
Pistons, rods and crankshaft are the same as a standard A14 engine.
Cylinder Head and Valve Cover
- 11041-M2460 HEAD ASSY-CYLINDER A14T B210, F10
- 13264-H8400 COVER ASSY-VALVE ROCKER
- 13203-H2300 SPRING-VALVE OUTER
- 13204-H2301 SPRING-VALVE INNER
- 13205-H2300 SEAT-VALVE SPRING
A14T uses standard A14 head gasket, intake valves and exhaust valves.
Manifold
- 14003-M2450 MANIFOLD-INTAKE
- 14065-M2400 STUD [carb mounting] (8)
- 14004-H8400 MANIFOLD-EXHAUST
- 14013-M2400 PLATE-HEAT SHIELD FRONT
- 14014-M2400 PLATE-HEAT SHIELD REAR
- 14035-M2401 GASKET-MANIFOLD TO CYLINDER HEAD
- 14055-M2400 HOSE-WATER [intake to water pipe]
- 14100-M2400 THERMOSTAT ASSY-MANIFOLD WATER
- 14330-M2461 PLATE-HEAT SHIELD CARBURETOR front
- 14331-M2460 PLATE-HEAT SHIELD CARBURETOR rear
- 14875-M2400 CONNECTOR-VACUUM HOSE
Emission Control
- 14120-M2460 TUBE ASSY-EGR
- 14711-M2460 PASSAGE-EGR
- 14791-M2401 CONNECTOR-INLET ELBOW
- 14791-H2461 CONNECTOR-VACUUM STRAIGHT
- 14720-M2400 GASKET-EGR PASSAGE
- 14741-Q1100 VALVE ASSY-BPT
- 14745-M2461 BRACKET-BPT VALVE
- 14751-M2461 TUBE ASSY-BPT
- 14755-H8200 TUBE-PASSAGE TO BPT
- 14792-M2462 CONNECTOR-PIPE
- 14826-M2200 BRACKET ASSY-EAI PIPE
- 14835-U7500 VALVE ASSY-AB with 4-speed
- 14860-H8400 HOSE-AIR
- 14823-H8400 PIPE ASSY-EAI
- 14861-H8400 HOSE AIR
- 14862-M2400 HOSE-AIR CLEANER TO AB VALVE
- 14863-H8400 HOSE-AB VALVE TO INLET CONNECTOR
- 14869-H8401 CLAMP-HOSE
- 14889-H7200 ORIFICE-AB VALVE
- 14896-M2400 CLIP-HARNESS
- 14956-U6700 VALVE ASSY-SOLENOID EGR-CUT
- 14957-H8400 BRACKET-VACUUM SWITCH
- 02141-67400 HOSE-EVAPO
- 02141-358Y0 HOSE-VACUUM E.A.R. TO CONNECTOR
Exhaust Piping
A14T used standard A14 exhaust piping (with a single-outlet exhaust manifold).
Radiator
- 21400-H7210 RADIATOR ASS'Y
This radiator uses the same shroud and top hose as A14 automatics.
Accelerator Pedal
- 18010-H5801 PEDAL ASSY-ACCELERATOR [same as L16 MT B210]
- 18215-H5800 SPRING-PEDAL ROD [same as L16 MT B210]
- 18200-H7510 WIRE ASSY-ACCELERATOR
Fuel
- 11826-M2460 HOSE-ROCKER COVER TO AIR CLEANER to 7612
- 11826-M2461 HOSE-ROCKER COVER TO AIR CLEANER from 7701
- 11828-M2460 HOSE-PIPE CONNECTOR TO VALVE
- 11830-M2460 CONNECTOR-PIPE
- 16587-N0901 CONNECTOR-3 WAY
- 14920-M2401 VALVE ASSY-CONTROL
- 22472-B8000 CLAMP-VACUUM TUBE
- 14896-M2400 BAND-HOSE
- 16335-M2460 ORIFICE-NO 2
- 16290-K0500 CLAMP-VACUUM HOSE
- 22319-M2462 CLAMP-VACUUM HOSE
- 22472-G0302 CLAMP-VACUUM HOSE [same as VB210]
- 22339-M2400 HOSE-VACUUM CONTROL PASSAGE CONN TO A/C
- 22340-M2400 HOSE-VACUUM CONTROL P/M OPENER TO DASH POT
- 22312-H7202 HOSE-VACUUM CONTROL L=120 S/B2318-73002
- 22318-N8610 HOSE-VACUUM CONTROL L=80 S/B2318-73002
- 22320-N4214 HOSE-VACUUM CONTROL L=50 S/B2318-73002
- 22320-Y4002 HOSE-VACUUM CONTROL L=155 S/B2318-N3300
- 22312-M2460 HOSE-VACUUM CONTROL BPT TO TVV
Carburetor
- 16010-H8430 CARBURETOR ASSY FRONT
- 16010-H8450 CARBURETOR ASSY REAR
Fuel
- 17522-H8401 TUBE ASSY-FUEL [steel fuel rail]
A14T uses stock A14 fuel pump.
Air Cleaner
- 16500-H8400 CLEANER ASSY-AIR
- 08110-61662 BOLT
- 16530-U6001 DUCT-AIR
- 08772-14400 (2)
- 16590-H8400 COVER ASSY-EXHAUST MANIFOLD
- 08915-43610 WASHER
- 08110-61010 BOLT
- 16546-H2300 ELEMENT ASSY
- 16565-M2400 FILTER [small]
