Template:Twin Carb Linkage
Revision as of 07:57, 7 January 2017; view current revision
Linkage depends in part on the manifold you use. Does it have bolt-bosses for linkage? Or does it have built-in linkage bar?
Side Pull
Tomei manifold Side Pull. Nismo/Tomei manifold have built-in bar towers and use a large diameter cross bar
8988.jpgAlbum 8988
Center Pull
Center Pull - Need the floating lever for the carburetors. In essence, a single throttle lever, with its own balance screw
Center Pull needs only one carb-pull, eliminating the separate throttle adjustments. The center floating linka has its own balance screw
15692.jpgAlbum 15692 15691.jpgAlbum 15691
Quadrant
Nissan cable quadrant
11496.jpgAlbum 11496 11497.jpgAlbum 11497 11368.jpgAlbum 11368
Generic cable bracket
11506.jpgAlbum 11506
Throttle Lever
Universal carby throttle lever
556.gifAlbum 556
