<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Coupe Fuel Tank
Standard
17201-H1802 ASSY-TANK FUEL 38L COUPE 17201-H1801 1 17201-H1801 ASSY-TANK FUEL 38L COUPE 2 17342-18000 RING-O COUPE 3 17343-H1001 PLATE-LOCK COUPE 3 17343-14801 PLATE-LOCK COUPE 2 17343-H1001 4 25060-H1800 GAUGE-FUEL TANK COUPE 5 17312-P0102 PACKING-DRAIN COUPE 2 17312-P0101 5 17312-14800 PACKING-DRAIN COUPE 5 17312-H1000 PACKING-DRAIN COUPE 2 17312-14800 5 17312-P0101 PACKING-DRAIN COUPE 2 17312-H1000 6 17310-P0100 PLUG-DRAIN COUPE 2 17310-H1000 6 08931-44210 PLUG-DRAIN COUPE 6 17310-H1000 PLUG-DRAIN COUPE 2 08931-44210 7 17251-H1900 CAP-FILLER COUPE 7 17251-H1000 CAP-FILLER COUPE 2 17251-H1900 8 17264-18000 PACKING COUPE 9 17220-H1801 TUBE-FILLER COUPE 10 17222-H1000 NECK-FILLER COUPE 11 17221-H1000 PACKING FILLER NECK COUPE 12 08310-40812 SCREW-MACHIN (3) COUPE 13 17229-H1801 HOSE-FILLER COUPE 14 17228-H1400 GROMMET COUPE 15 08723-15800 CLAMP-HOSE (2) COUPE 16 A7325-H1000 TUBE(10X14DX5M) COUPE 17 08723-11400 CLAMP-HOSE (2) COUPE 17 16439-22100 CLAMP-HOSE (2) COUPE 2 08723-11400 18 17335-H1800 TUBE COUPE 19 17324-H1400 GROMMET COUPE 20 17334-H1801 CLIP COUPE 2 17310-H1000 21 08510-51012 SCREW COUPE 22 77700-89915 PLUG-RUBBER 30 COUPE 23 08110-82062 BOLT-WITH LOCK WASHER (5) COUPE 24 08915-53810 WASHER-PLAIN (5) COUPE 25 74890-H1800 PROTECTOR-FILLER HOSE COUPE 26 08110-62010 BOLT FIXING PROTECTOR (3) COUPE 27 08915-23610 WASHER FIXING PROTECTOR (3) COUPE 28 08915-43610 WASHER FIXING PROTECTOR (3) COUPE
1973 LB110 USA Parts Catalog
Evapo
1 17201-H1802 ASSY-TANK FUEL 38L COUPE EVAPO 2 17342-18000 RING-"O" COUPE 3 17343-H1001 PLATE-LOCK COUPE 3 17343-14801 PLATE-LOCK COUPE 2 17343-H1001 4 25060-H1800 GAUGE-FUEL TANK COUPE 5 17312-P0101 PACKING-DRAIN COUPE 2 17312-H1000 5 17312-P0102 PACKING-DRAIN COUPE 2 17312-P0101 5 17312-H1000 PACKING-DRAIN COUPE 2 17312-14800 5 17312-14800 PACKING-DRAIN COUPE 6 17310-H1000 PLUG-DRAIN COUPE 2 08931-44210 6 17310-P0100 PLUG-DRAIN COUPE 2 17310-H1000 6 08931-44210 PLUG-DRAIN COUPE 7 17251-H1902 CAP-FILLER COUPE EVAPO 0173- 2 17251-H1901 7 17251-H1900 CAP-FILLER COUPE 7 17251-H1000 CAP-FILLER COUPE EVAPO 0470- 6 17251-H1900 7 17251-H1901 CAP-FILLER COUPE EVAPO 0672- 2 17251-H1000 8 17264-18000 PACKING COUPE 9 17220-H1802 HOSE-FILLER UPPER COUPE EVAPO 9 17220-H1803 HOSE-FILLER UPPER COUPE EVAPO 0470- 0 17220-H1802 10 17222-H1000 NECK-FILLER COUPE 11 17221-H1000 PACKING FILLER NECK COUPE 12 08310-40812 SCREW-MACHIN (3) COUPE 13 17229-H1802 HOSE-FILLER COUPE EVAPO 14 17228-H1400 GROMMET COUPE 15 08723-15800 CLAMP-HOSE (2) COUPE 16 17230-H1802 HOSE-FILLER INNER COUPE EVAPO 2 17230-H1801 16 17230-H1801 HOSE-FILLER 2ND(NOT ADOPTED) COUPE EVAPO 17 08723-13600 CLAMP-HOSE COUPE EVAPO 18 A7325-H1000 TUBE-VINYLE(10X14DX5M) COUPE 18 A7515-H1900 TUBE-RUBBER(10X16DX5M) COUPE EVAPO 18 08742-20040 TUBE-RUBBER COUPE EVAPO 2 A7515-H1900 19 16439-22100 CLAMP-HOSE (2) COUPE 2 08723-11400 19 08723-11400 CLAMP-HOSE (2) COUPE 20 17324-H1800 GROMMET COUPE EVAPO 21 08110-82062 BOLT WITH LOCK WASHER (5) COUPE 22 08915-53810 WASHER-PLAIN (5) COUPE 23 17350-H1801 ASSY-TANK RESERVOIR COUPE EVAPO 23 17350-H1802 ASSY-TANK RESERVOIR COUPE EVAPO 0470- 0 17350-H1801 24 63140-78500 NUT-JAM (3) COUPE EVAPO 25 08410-61610 SCREW (3) COUPE EVAPO 26 08915-13610 WASHER-LOCK (3) COUPE EVAPO 27 17335-H1801 TUBE-BREATHER RH COUPE EVAPO 27 17335-H1802 CONNECTOR (2) COUPE EVAPO 0470- 0 17335-H1801 28 17336-H1801 TUBE-BREATHER LH COUPE EVAPO 29 17515-H1817 HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L COUPE EVAPO 2 17230-H1801 29 A7515-H1800 HOSE-FUEL(6X13.5X5M) COUPE EVAPO 29 08742-20020 HOSE-FUEL(6X13.5X2200MM) COUPE EVAPO 29 A7515-H1800 HOSE-FUEL(6X13.5X10M) COUPE EVAPO 0470- 29 08742-20020 HOSE-FUEL(6X13.5X2200MM) COUPE EVAPO 2 17230-H1801 29 08742-20020 HOSE-FUEL (6X13.5X2.2M) COUPE EVAPO 2 A7515-20020 30 16439-22100 CLAMP-HOSE 1 (16) COUPE EVAPO 2 68723-11400 30 08723-11400 CLAMP-HOSE 1 (16) COUPE EVAPO 31 17351-H1800 CONNECTOR-3 WAY COUPE EVAPO 0470- 31 17351-H1801 CONNECTOR-3WAY COUPE EVAPO 2 17351-H1801 32 17361-H1800 TUBE-EVAPORATION COUPE EVAPO MANUAL 32 17361-H1801 TUBE-EVAPORATION COUPE EVAPO MANUAL 0 17361-H1800 33 24251-H1801 GROMMET COUPE EVAPO 34 00951-10600 GROMMET (2) COUPE EVAPO 35 00951-11000 GROMMET (4) COUPE EVAPO 36 00951-11200 GROMMET (2) COUPE EVAPO 0470- 37 46115-C0400 GROMMET (2) COUPE EVAPO 0470- 38 17337-H1800 PROTECTOR-FUEL HOSE COUPE EVAPO 0470- 39 24210-89964 CLIP COUPE EVAPO 0470- 40 74890-H1800 PROTECTOR-FILLER HOSE COUPE EVAPO 41 08110-62010 BOLT FIXING PROTECTOR (3) COUPE EVAPO 42 08915-23610 WASHER FIXING PROTECTOR (3) COUPE EVAPO 43 08915-43610 WASHER FIXING PROTECTOR (3) COUPE EVAPO
