<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Automatic Transmission
1 31340-X0100 ASSY-PUMP,OIL 3N71B 31340-X0101 ASSY-PUM.OIL 3N71B 2 31340-X0100 2 31341-X0100 ASSY-HOUSING,OIL PUMP 3N71B 3 31344-X0100 SEAL-HOUSING 3N71B 4 31346-X0102 GEAR-INNER,OIL PUMP 3N71B 31346-X0100 GEAR-INNER,OIL PUMP 3N71B 31346-X0101 GEAR-INNER,OIL PUMP 3N71B 5 31347-X0100 GEAR-OUTER,OIL PUMP 3N71B 31347-X0101 GEAR-OUTER,OIL PUMP 3N71B 31347-X0102 GEAR-OUTER,OIL PUMP 3N71B 6 31350-X0100 ASSY-COVER,OIL PUMP 3N71B 31350-X0101 ASSY-COVER,OIL PUMP 3N71B 2 31350-X0100 7 31361-X0100 RING-SEAL (44) (2) 3N71B 8 31362-X0100 RING-SEAL (43) (2) 3N71B 9 08120-61810 BOLT (5) 3N71B 10 31363-X0100 SEAL-LATHE CUT RING (200D) 3N71B 11 31366-X0100 GASKET-OIL PUMP 3N71B 12 31556-X0102 RACE-BEARING,PUMP COVER, T=1.6 3N71B 12 31556-X0105 RACE-BEARING,PUMP COVER, T=2.2 3N71B 12 31556-X0103 RACE-BEARING,PUMP COVER, T=1.8 3N71B 12 31556-X0100 RACE-BEARING,PUMP COVER, T=1.2 3N71B 12 31556-X0104 RACE-BEARING,PUMP COVER, T=2.0 3N71B 12 31556-X0101 RACE-BEARING,PUMP COVER, T=1.4 3N71B 13 31528-X0100 WASHER-THRUST, T=1.9 3N71B 13 31528-X0101 WASHER-THRUST, T=2.1 3N71B 13 31528-X0102 WASHER-THRUST, T=2.3 3N71B 13 31528-X0103 WASHER-THRUST, T=2.5 3N71B 13 31528-X0104 WASHER-THRUST, T=2.7 3N71B 13 31528-X0105 WASHER-THRUST, T=1.7 3N71B 13 31528-X0106 WASHER-THRUST, T=1.5 3N71B 14 31540-X0100 ASSY-CLUTCH,REAR 3N71B 15 31542-X0100 DRUM-REAR CLUTCH 3N71B 16 31517-X0100 SEAL-O RING (54D) 3N71B 17 31514-X0102 ASSY-PISTON,CLUTCH 3N71B 1272- 2 31514-X0101 17 31514-X0101 ASSY-PISTON,CLUTCH 3N71B 18 31516-X0100 SEAL-LATHE CUT RING (116D) 3N71B 19 31521-X0100 SPRING-PISTON RETURN 1 (10) 3N71B 20 31552-X0100 RETAINER SPRING 3N71B 20 31552-X0102 RETAINER-SPRING 3N71B 1272- 2 31552-X0100 21 31523-X0100 RING-SNAP (54S) 3N71B 22 31529-X0100 PLATE-DISHED (115) 3N71B 23 31536-X0100 PLATE-DRIVEN (115) (3) 3N71B 24 31532-X0100 ASSY-PLATE,DRIVE (115) (3) 3N71B 25 31567-X0100 PLATE-RETAINING (115) 3N71B 26 31538-X0100 RING-SNAP (118) 3N71B 27 31439-X0100 RACE-BEARING,REAR CLUTCH DRUM 3N71B 28 31555-X0100 BEARING-NEEDLE THRUST (2035) 3N71B 29 31510-X0100 ASSY-CLUTCH,FRONT 3N71B 30 31511-X0100 ASSY-DRUM,FRONT CLUTCH 3N71B 31 31517-X0100 SEAL-O RING (54D) 3N71B 32 31514-X0101 ASSY-PISTON,CLUTCH 3N71B 32 31514-X0102 ASSY-PISTON,CLUTCH 3N71B 1272- 2 31514-X0101 33 31516-X0100 SEAL-LATHE CUT RING (116D) 3N71B 34 31521-X0100 SPRING-PISTON RETURN 1 (10) 3N71B 35 31552-X0100 RETAINER-SPRING 3N71B 35 31552-X0102 RETAINER-SPRING 3N71B 1272- 2 31552-X0100 36 31523-X0100 RING-SNAP (54S) 3N71B 37 31529-X0100 PLATE-DISHED 3N71B 38 31536-X0100 PLATE-DRIVEN (115) (3) 3N71B 39 31532-X0100 ASSY-PLATE,DRIVE (115) (3) 3N71B 40 31537-X0102 PLATE-RETAINING, T=11.0 3N71B 40 31537-X0105 PLATE-RETAINING, T=11.6 3N71B 40 31537-X0103 PLATE-RETAINING, T=11.2 3N71B 40 31537-X0101 PLATE-RETAINING, T=10.8 3N71B 40 31537-X0100 PLATE-RETAINING, T=10.6 3N71B 40 31537-X0104 PLATE-RETAINING, T=11.4 3N71B 41 31538-X0100 RING-SNAP (118B) 3N71B 42 31630-X0100 ASSY-BAND,BRAKE 3N71B 43 31624-X0100 STRUT-BAND 3N71B 44 31621-X0100 SPRING-PISTON RETURN (10KG) 3N71B 45 31615-X0100 PISTON-BAND SERVO (64-44) 3N71B 46 31611-X0100 RETAINER-SERVO (64-44) 3N71B 47 31616-X0100 SEAL-LATHE CUT RING (64D) 3N71B 48 31617-X0100 SEAL-LATHE CUT RING (44D) 3N71B 49 31628-X0100 SEAL-O RING (82S) 3N71B 50 31612-X0100 SEAL-LATHE CUT RING (80D) 3N71B 51 31618-X0101 STEM-BAND SERVO PISTON 3N71B 2 31618-X0100 51 31618-X0100 STEM-BAND SERVO PISTON 3N71B 52 31619-X0100 WASHER-STEM 3N71B 2 08915-44200 52 08915-44200 WASHER-PLAIN 3N71B 53 08540-70810 NUT 3N71B 54 08160-61610 BOLT (3) 3N71B
1973 LB110 USA Parts Catalog, page 55C-1
55 31532-X0125 KIT-CLUTCH REPAIR AUTO TRANS 3N71B
1973 LB110 USA Parts Catalog, page 55C-2
