Also see:
Part Numbers Index Main article for usage, photos, cross-reference Steering Gearbox
1 48805-H1951 ASSY-GEAR,STEERING, COLLAPSIBLE OP. 2 48850-H1900 ASSY-TUBE,JACKET OP. 3 48011-H1601 ASSY-HOUSING,GEAR OP. 4 48820-H1900 ASSY-SHAFT,COLUMN OP. 5 48025-18000 BEARING-WORM OP. 6 48103-H1002 SHAFT-SECTOR OP. 7 48137-H1002 SEAL-OIL OP. 8 48135-66000 SCREW-ADJUSTING OP. 08911-3401A NUT OP. 08911-34010 9 08911-34010 NUT OP. 10 48133-66000 SHIM-SCREW,T=1.62 OP. 10 48134-66000 SHIM-SCREW,T=1.65 OP. 10 48131-66000 SHIM-SCREW,T=1.56 OP. 10 48130-66000 SHIM-SCREW,T=1.53 OP. 10 48132-66000 SHIM-SCREW,T=1.59 OP. 11 48201-18000 COVER-SIDE OP. 12 48204-18000 PACKING-SIDE COVER OP. 13 08931-10410 PLUG OP. 14 08120-82010 BOLT (8) OP. 15 08915-13810 WASHER-SPRING (8) OP. 16 08911-24610 NUT OP. 17 08915-14610 WASHER-LOCK OP. 18 48031-18000 SHIM-COVER,T=0.05 OP. 18 48032-18000 SHIM-COVER,T=0.07 OP. 18 48033-18000 SHIM-COVER,T=0.08 OP. 18 48034-18000 SHIM-COVER,T=0.10 OP. 18 48035-18000 SHIM-COVER,T=0.12 OP. 19 48910-H1020 BUSH-COLUMN OP. 19 48910-H1021 BUSH-COLUMN OP. 2 48910-H1020 20 48931-H1020 WASHER-PLAIN OP. 21 00922-11700 RING-SNAP OP. 22 08110-81210 BOLT (4) OP. 23 08915-13810 WASHER (4) OP. 24 48960-H1020 ASSY-CLAMP,STEERING POST OP. 25 08915-13810 WASHER-LOCK (4) OP. 26 08110-81210 BOLT (4) OP. 27 08120-83010 BOLT (2) OP. 28 08915-53810 WASHER-PLAIN (3) OP. 29 48361-H1000 BOLT (3) OP. 30 48366-H1000 NUT (3) OP. 31 48502-H1600 ARM-STEERING GEAR OP.
