Oil Pump Part Numbers
Revision as of 05:39, 4 September 2017; view current revision
Categories: Engine Mechanical | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Oil pump
Oil Filter
10 15208-13211 ELEMENT-oil filter, cartridge
   15208-13212 ELEMENT-oil filter, cartridge <> 15208-13211
   15208-H1010 (from '72-2) <> 15208-13212
   15208-H8911 FILTER ASSY-OIL 7911-8502
   15208-H8903 FILTER ASSY-OIL 8502-
 1 15010-H9701 ASSY-PUMP OIL WITH OUT OIL FILTER A12 0473- 2 15010-H6200
 1 15010-H6200 ASSY-PUMP OIL WITH OUT OIL FILTER A12 0473- 2 15010-H1000
 1 15010-H1000 ASSY-PUMP OIL WITH OUT OIL FILTER A12 -373
 2 15020-H1025 ASSY-SHAFT DRIVE OIL PUMP A12
 2 15020-H1005 ASSY-SHAFT DRIVE OIL PUMP A12 2 15020-H1025
 3 15025-18003 GASKET-OIL PUMP A12
 4 15132-H1000 ASSY-VALVE OIL REGULATOR A12
 5 08310-53010 SET-BOLT BODY TO COVER A12
 6 08915-13510 WASHER-SPRING A12
 7 15066-18000 GASKET-OIL PUMP TO CYLINDER BLOCK A12
 8 08915-13810 WASHER-LOCK (3) A12
 9 15036-18000 BOLT-OIL PUMP (2) A12
10 08110-85510 BOLT A12
11 15050-H1000 ASSY-STRAINER OIL A12
12 15053-18000 GASKET-OIL STRAINER A12
13 08110-82010 BOLT (2) A12
14 08915-13810 WASHER-LOCK (2) A12
   15208-55Y00 ASSY-OIL FILTER CARTRIDGE A12 0272- 15208-H1010
15 15208-H1010 ASSY-OIL FILTER CARTRIDGE A12 0272- 2 15208-13212
15 15208-13211 ASSY-OIL FILTER CARTRIDGE A12
15 15208-13212 ASSY-OIL FILTER CARTRIDGE A12 2 15208-13211
1973 LB110 USA Parts Catalog
