2006 June 1400 Brochure Nissan South Africa
8 page brochure, 2 sheets folded.
Cover
Page 1 & 2
Page 3 & 4
Page 5
| 05 1400 CHAMP
All work and no play is no fun. Which is why the 1400 Champ gives you that little bit extra without compromising its under-the-skin durability. Rugged, sporty styling is emphasised by spotlamps, decals, blackouts and a tinted windscreen. Inside, you’ll feel the comfort of individual bucket seats, cloth upholstery, a rev counter and a soft grip steering wheel. It’s built around the same reliable engine, while the big loadbox swallows everything from cooler boxes to surfboards. Whether you’re playing or working, the 1400 Champ lets you go your own way. Daar kom mos ’n tyd wanneer die werk klaar is. Dit is wanneer die 1400 Champ daardie bietjie ekstra bied sonder dat daardie onkeerbare uithouvermoë in gedrang gebring word. Sy sportiewe voorkoms word beklem- toon deur kolligte, sierstroke, swart afwerking en ’n getinte windskerm, terwyl afsonderlike skottelsitplekke, materiaaloortreksels vir die sitplekke en ’n sagte-greep stuurwiel die binneruim afrond. Maar hy word steeds gebou rondom dieselfde betroubare enjin, terwyl sy groot laairuim alles insluk van koelbokse tot strandsam- brele. Of jy nou speel of werk, die 1400 Champ gee jou die kans om dinge op jou eie manier te doen. | 30 YEARS OF SERVICE
When there’s a job to be done, Africa’s tough-as-nails range of 1400 Bakkies will never let you down. With an indestructible engine, load-lugging rear wheel drive and the undisputed respect of all who own and operate them, the 1400 Bakkie is built to survive the harshest of local conditions. For 30 years it has cut its teeth on the best and worst of South African roads – whatever the load, whatever the distance, the Champion of Africa is with you all the way. As daar gewerk moet word, sal Afrika se rateltaai 1400-reeks bakkies jou nooit in die steek laat nie. Met ’n onvernietigbare enjin, vragdraende agterwielaandrywing en die verdiende respek van almal wat hulle besit, is die 1400 Bakkie gebou om die ergste situasies moontlik kaf te draf. Vir meer as 30 jaar het dié bakkie homself bewys op die beste en slegste paaie in Suid-Afrika. Wat ookal die vrag, hoe ver ookal die afstand, die Kampioen van Afrika is altyd met jou. |
Page 6 Specifications
TECHNICAL SPECIFICATIONS - NISSAN 1400 BAKKIE AND CHAMP
NISSAN MODEL CODE / MODELKODE
1400 STD 1400 CHAMP
408 B01
ENGINE TYPE / ENJINTIPE
A14 4 CYL / 4 SIL
Displacement / Verplasingsinhoud (cm3) 1397
Bore x stroke / Boring x slag (mm) 76 x 77
Compression ratio / Drukverhouding 9.4 : 1
Max power / Kragpiek (kW @ rpm-SABS) 47 @ 6000
Max torque / Wringkragpiek (Nm @ rpm-SABS) 97 @ 2500
TRANSMISSION TYPE / TRANSMISSIE-TIPE
5 speed manual / 5 spoed handrat
Ratio: 1st / Verhouding: 1ste 3,513
Ratio: 2nd / Verhouding: 2de 2,170
Ratio: 3rd / Verhouding: 3de 1,378
Ratio: 4th / Verhouding: 4de 1,000
Ratio: 5th / Verhouding: 5de 0,821
Final drive ratio / 3,910
Eindaandrywing-verhouding
STEERING TYPE / STUUR-TIPE
Recirculating ball / Hersirkuleerkoeël
Turning radius / Draaisirkel (m) 8.2
MASS & DIMENSIONS / MASSA & AFMETINGS STD CHAMP
GVM / BVM (kg) 1349 1360
Tare mass / Tarra massa (kg) 758 772
Gross payload / Bruto loonvrag (kg) 591 588
Overall length / Totale lengte (mm) 3845
Overall width / Totale breedte (mm) 1495
Overall height / Totale hoogte (mm) 1425
Overall wheelbase / Totale asafstand 2300
Loadbox length / Laaibak lengte (mm) 1518
Loadbox width / Laaibak breedte (mm) 1285
Ground clearance / Grondvryhoogte 160
Fuel tank capacity / Brandstofkapasiteit 45 litre
SUSPENSION / VERING
Front / Voor Ind. strut, coil springs & stabiliser bar /
Onaf. stuttipe, kronkelvere & stabiliseerstaaf
Rear / Agter Live axle, semi-elliptic leaf springs /
Draai-as, halfelliptiese bladvere
Shock absorbers / Telescopic double-acting /
Skokbrekers Teleskopiese dubbelwerking
Brakes / Remme Power assisted front discs and rear drums /
Kraghulp-skywe voor en trommels agter
INTERIOR / BINNERUIM STD CHAMP
Heater & demister / • •
Verwarmer & ontwasemer
Bench seat / Banksitplek •
Bucket seats with cloth inserts / •
Skottelsitplekke met materiaalinsetsels
Inertia reel safety belts / • •
Rukstop sitplekgordels
Interior light / Binneliggie •
Trip meter / Ritmeter •
Handrem op vloer
Floor mounted handbrake / • •
Moulded floor carpet / Gevormde tapyt • •
Tachometer / Tagometer •
3-spoke steering wheel / • •
3-speek stuurwiel
Head restraints / Kopstutte •
Door panels with cloth inserts / •
Deurpanele met materiaalinsetsels
Floor console / Vloerkonsole • •
EXTERIOR / BUITE-AFWERKING
Front black bumper / • •
Swart buffer voor
Door vent windows / Deursyvenstertjies • •
Dual exterior mirrors / • •
Twee buite-truspieëls
Curved rear window / Geronde agterruit • •
Loadbox with double side panels / • •
Laaibak met dubbele kantpanele
Lockable fuel lid / • •
Sluitbare brandstofvuldeksel
Halogen headlamps / Halogeen koplampe • •
12” spoker wheels / 12” speekwiele White/Wit
Silver/Silwer
Spot lamps / Kolligte •
Tonneau cover / Bakseil •
Tinted windshield / Getinte voorruit •
Mudflaps (front and rear) / •
Modderflappe (voor en agter)
WHEELS / WIELE
Size & type / Grootte & tipe 4J X 12 Steel / Staal
Tyres / Bande 155SR12a
Back
Every effort has been made to ensure that the content of this publication is correct at the time of going to press (June 2006). This brochure has been produced featuring prototype vehicles exhibited at motor shows and, in accordance with the company’s policy of continuously improving its products, Nissan South Africa reserves the right to change the specification and the vehicles described and shown in this publication at any time. Nissan dealers will be informed of any such modifications as quickly as possible. Please check with your local Nissan dealer to receive the most up-to-date information. Due to the limitations of the printing processes used, the colours shown in this brochure may differ slightly from the actual colours of the paint and interior trim materials used. All rights reserved. Reproduction in whole or part of this brochure without the written permission of Nissan is forbidden.
