Drip rail
Revision as of 07:38, 30 October 2017; view current revision
Category: Body
Roof drip rails keep rain off the top of the doors.
25758.jpgAlbum 25758
Panels
The drip rails (drip mouldings) are actually part of the Body Side panels, where the roof attaches to the side.
Also see Body Side Part Numbers
ASSY-FRONT PILLAR
ASSY-RAIL ROOF SIDE OUTER
PANEL-RAIL ROOF SIDE INNER
Removing
discussion
You need good door rubbers that seal real good -- the water runs off the side down the side windows instead of in the drain and then down the front or back. Just grind where the spot welds are inside the door opening. and the whole rail will come off. To regain strength, weld the roof skin to the car the full length.
shaved rail
14606.jpgAlbum 14606
2332's Sunny Truck
13948.jpgAlbum 13948
14547.jpgAlbum 14547
flyby's sedan
5974.jpgAlbum 5974
Chrome Trim
All 1200s except Standard trim included chrome trim over the roof rain drip rails.
Also see Body Side Trim Part Numbers
SET-MOULDING ROOF DRIP RH
SET-MOULDING ROOF DRIP LH
Each set consists of:
MOULDING-ROOF DRIP FRONT
MOULDING-ROOF DRIP REAR
CLIP-MOULDING ROOF DRIP [Center clip]
To install, place it on the top edge, then snap it down onto the bottom edge
Depress downward after hooking the top
To remove, pull bottom edge out, which will snap it off the rail.
