Wiper Relocation
Revision as of 02:43, 6 November 2017; view current revision
Category: Body Modifications
Clean up your engine compartment by moving the wiper motor inside, under the dash. Weld up the hole for a smooth look, then reverse mount (hide) the wiper washer motor behind firewall. Would it need to be mounted in the same direction for the auto-park (cancel) to work?
Linkage
The motor simply turns in a circle, with the parking mechanism stopping it at a certain point. Can you mount the motor inside, turned around, and rotated 180 degrees so the park is in the same place?
For more detail photos, see Wiper Motor Repair
Stock (LHD) linkage
120Y Fitting
12659_4ca71454b964c.jpgPost 339885 12659_4ca7145f61a16.jpgPost 339885
