[edit]
Why does my engine still try to run after I shut it off?
Dieseling or engine run-on is a condition that can occur in gasoline powered engines, whereby the engine keeps running for a short period after being turned off, due to fuel igniting without a spark.
Causes of "running on" (continuing to run when ignition is turned off) are most commonly these:
- Air leak -- leak at manifold gasket, carburetor gasket, or any of the assorted vacuum diaphragms such as the distributor, air cleaner flap motor, or carburetor choke-pulloff. See Vacuum Leaks
- Idle too high. Should be 750 rpm or lower. See Carburetor_Adjustment#Idle_Speed_and_Mixture_Adjustment
- Open Chamber type cylinder heads. While these reduce emissions, they are more susceptible to run-on. To reduce run-on, Datsun fitted carburetors with an anti-diesel valve to these engines.
[edit]
How do I stop the engine?
See the causes and solutions above. But for now, you can easily stop the engine:
- set hand brake
- push clutch pedal down and put in high gear
- turn key OFF and at the same time let the clutch out slowly. This will stop the engine
