Template:Twin Carb Linkage
Revision as of 20:55, 25 June 2019; view current revision
Linkage depends in part on the manifold you use. Does it have bolt-bosses for linkage? Or does it have built-in linkage bar?
Side Pull
Tomei manifold Side Pull. Nismo/Tomei manifold have built-in bar towers and use a large diameter cross bar
8988.jpgAlbum 8988
Center Pull
Center Pull - Need the floating lever for the carburetors. In essence, a single throttle lever, with its own balance screw
Center Pull needs only one carb-pull, eliminating the separate throttle adjustments. The center floating linka has its own balance screw
15692.jpgAlbum 15692 15691.jpgAlbum 15691
Single Carb Linkage
For bolt-style manifolds
20641.jpgAlbum 20641
Quadrant
Fan lever - Harada Shosho company
27290.jpgAlbum 27290
Nissan cable quadrant
11496.jpgAlbum 11496 11497.jpgAlbum 11497 11368.jpgAlbum 11368
Generic cable bracket
11506.jpgAlbum 11506
Throttle Lever
Universal carby throttle lever
556.gifAlbum 556
