Kicking Plate
Revision as of 13:24, 20 May 2021; view current revision
Category: Body
Kicking plate (キッキング プレート) is the door jamb. Also known as 'scuff plate' or threshold plate. The door sill is the exterior panel, while the kicking plate is the interior trim.
See also: Kick Panel
[hide]
Kicking plate is made of aluminum. Early and late differ.
4-door sedan set (long pieces are same as Truck)
22579.jpgAlbum 22579 22578.jpgAlbum 22578
Late - holes on both edges
174_5b63c96e98020.jpgPost 489121
174_5b62dc0257785.jpgPost 489116 174_5b62dae0cfea1.jpgPost 489116 174_5b62dae9d1b98.jpgPost 489116 174_5b62daf3b9f08.jpgPost 489116
Notches fit over the floor stringer and seat bracket.
174_5b63c99061248.jpgPost 489121
Custom
19575.jpgAlbum 19575 19576.jpgAlbum 19576
Sources
Bprojects
H10 Early short doors
H12 Early long doors (2-door models)
H31 Late short doors
H36 Late long doors (2-door models)
SHORT doors 2-door models (Sedan/Van/Coupe)
LONG doors (4-door sedan, 4-door Van, Truck)
Early
Early plates have no screw holes on the top surface.
22582.jpgAlbum 22582
Short Doors
74951-H1000 PLATE-kicking, front (R.H.) 4-dr (Sedan/Van), Truck
74952-H1000 PLATE-kicking, front (L.H.) 4-dr (Sedan/Van), Truck
74953-H1000 PLATE-kicking, rear (R.H.) 4-dr (Sedan/Van)
74954-H1000 PLATE-kicking, rear (L.H.) 4-dr (Sedan/Van)
74955-H1000 PLATE-kicking, center (2) 4-dr (Sedan/Van)
85-40412-12 SCREW (8)
Long Doors
74951-H1200 JDM PLATE-kicking, front (R.H.) 2-dr (Sedan/Coupe)
74952-H1200 JDM PLATE-kicking, front (L.H.) 2-dr (Sedan/Coupe)
85-40412-12 SCREW (fixing kicking plate) (8)
Late
From Dec 1971, uses more screws than early plates.
Short Doors
74951-H3100 1972 PLATE-kicking, front (R.H.) 4-dr (Sedan/Van), Truck
74952-H3100 1972 PLATE-kicking, front (L.H.) 4-dr (Sedan/Van), Truck
74953-H3100 1972 PLATE-kicking, rear (R.H.) 4-dr (Sedan/Van)
74954-H3100 1972 PLATE-kicking, rear (L.H.) 4-dr (Sedan/Van)
74955-H3100 PLATE-kicking, center (2) 4-dr (Sedan/Van)
08540-41212 SCREW (24) 4-dr
08540-41212 SCREW (14) Truck (pickup/ute)
Ute sills: 4 side screws, 3 top screws per side (7 per side, 14 per truck)
22581.jpgAlbum 22581 22580.jpgAlbum 22580
Long Doors
74951-H3600 1972 PLATE-kicking, front (R.H.) 2-dr (Sedan/Coupe/Van)
74952-H3600 1972 PLATE-kicking, front (L.H.) 2-dr (Sedan/Coupe/Van)
08540-41212 SCREW (fixing kicking plate) (16)
Early to Nov 1971 - 4 screws per side
74951-H1200
74952-H1200
08540-41242 SCREW-TAPPING M4 (4)
Late from Dec 1971 - 8 screws per side
74951-H3600 PLATE-KICKING FRONT RH SEDAN 2DR, COUPE $27.67 USD
74952-H3600 PLATE-KICKING FRONT LH SEDAN 2DR, COUPE $25.17 USD
08540-14242 SCREW-TAPPING M4 (8)
For long door models - approximately 810 mm length
174_5cb834e188057.jpgPost 491215 174_5cb834d822f86.jpgPost 491215
