<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Rear Window Side Window Moulding (molding trim) Weatherstripping
Van
REAR SIDE WINDOW (VAN 4-DOOR) 76822-H1400 GLASS-side window (R.H.) V-Std, V-P 76822-H1501 GLASS-side window (R.H.) V-DX 1 76823-H1400 GLASS-side window (L.H.) V-Std, V-P 76823-H1501 GLASS-side window (L.H.) V-DX 76832-H1400 WEATHERSTRIP-side window (R.H.) 2 76833-H1400 WEATHERSTRIP-side window (L.H.) 3 76833-H1400 BRACKET-guard bar 4 4 76857-H1400 BAR-guard 2 fixing guard bar 5 08530-52020 SCREW 4 6 08916-43510 WASHER-tooth lock 4 references: 1971 B110 Parts Catalog C-173 Figure 112-2
SIDE WINDOW (2 DOOR VAN) 76824-H4500 GLASS-side window (R.H.) 1 76825-H4501 GLASS-side window (R.H.) 2 76832-H1201 HINGE-side window 2 3 80234-H1000 WASHER-bracket pivot 6 4 80284-H1000 WASHER-rubber "A" 6 5 80285-H1000 WASHER-rubber "B" 6 6 76844-H1201 NUT-finish 6 7 76842-H1201 BRACKET-catch handle 2 8 08330-51020 SCREW 6 76870-H1200 HANDLE ASS'Y-side window (R.H.) 9 76871-H1200 HANDLE ASS'Y-side window (L.H.) 9-1 76872-18000 PIN-handle side window 2 10 76838-H4500 SHIM-side window handle 2 11 01423-00023 SCREW 4 76834-H4500 WEATHERSTRIP-side window (R.H.) 12 76835-H4500 WEATHERSTRIP-side window (L.H.) 13 76828-H1200 COVER-side window hinge 2 14 76922-H1201 WELT-side window 2 76822-H1400 GLASS-side window (R.H.) V-Std, V-P 76822-H1501 GLASS-side window (R.H.) V-DX 15 76823-H1400 GLASS-side window (L.H.) V-Std, V-P 76823-H1501 GLASS-side window (L.H.) V-DX 76834-H4500 WEATHERSTRIP-side window (R.H.) 2-Van 16 76835-H4500 WEATHERSTRIP-side window (L.H.) 2-Van 17 76852-H1400 BRACKET-guard bar 4 18 76857-H4500 BAR-guard 2 2-Van fixing guard bar 19 08530-52020 SCREW-tapping, oval head 4 20 08916-43510 WASHER-tooth lock 4
Truck
BACK WINDOW 12 79712-G1000 GLASS-back window (up to '73-8) * 79712-G1200 GLASS-back window (from '73-9) 13 79710 79417-G1000 WEATHERSTRIP-back window 79417-G1001 WEATHERSTRIP-back window (up to '73-8) * 79417-G1201 WEATHERSTRIP-back window (from '73-9) * (79712-G1200) is compatible with the new parts in the set (79714-G1201) 14 79810-G1000 RAIL/PLATE-guard back window 3 08310-61226 SCREW-with washer (fixing guard plate) 6
HOLDFAST-GUARD 93100-G1060 FRAME ASSY-GUARD 7804- 93152-G1060 HOLDFAST-GUARD FRAME 8504- 3 [clip] 93154-G1060 HOLDFAST-GUARD FRAME 8504- 3 [insert] 93156-G1060 HOLDFAST-GUARD FRAME 8504- 3 [bracket] 08110-61610 08110-61225 93158-G1060 HOLDFAST-GUARD FRAME SIDE 8504- 2 08110-82025 BOLT
Sedan
1 76802-H1202 WEATHERSTRIP-SIDE WINDOW RH SEDAN 2 DOOR 2 76803-H1202 WEATHERSTRIP-SIDE WINDOW LH SEDAN 2 DOOR 3 76828-H1200 COVER-SIDE WINDOW HINGE (2) SEDAN 2 DOOR 4 76822-H1301 GLASS-SIDE WINDOW RH TINTED & TEMPERD T= SEDAN 2 DOOR (OP) 5 76823-H1301 GLASS-SIDE WINDOW LH TINTED & TEMPERD T= SEDAN 2 DOOR (OP) 6 76870-H1200 ASSY-HANDLE SIDE WINDOW RH SEDAN 2 DOOR 7 76870-H1200 ASSY-HANDLE SIDE WINDOW LH SEDAN 2 DOOR 8 76872-18000 PIN-HANDLE SIDE WINDOW (2) SEDAN 2 DOOR 9 08430-41620 SCREW-MACHINE M4 (4) SEDAN 2 DOOR 10 08916-43410 WASHER-TOOTH LOCK (4) SEDAN 2 DOOR 11 76873-H1200 SHIM-HANDLE SIDE WINDOW (T=1.00) (2) SEDAN 2 DOOR 11 76873-H1210 SHIM-HANDLE SIDE WINDOW (T=2.00) (2) SEDAN 2 DOOR 12 76832-H1201 HINGE-SIDE WINDOW (4) SEDAN 2 DOOR 13 76842-H1201 BRACKET-CATCH HANDLE (2) SEDAN 2 DOOR 13 G6842-H1201 BRACKET-CATCH HANDLE (2) SEDAN 2 DOOR 14 76844-H1201 NUT-FINISH (6) SEDAN 2 DOOR 15 80234-H1000 WASHER-BRACKET PIVOT (6) SEDAN 2 DOOR 16 80284-H1000 WASHER-RUBBER 'A' (6) SEDAN 2 DOOR 17 80285-H1000 WASHER-RUBBER 'B' (6) SEDAN 2 DOOR 18 08330-51020 SCREW-MACHINE M5 (6) SEDAN 2 DOOR 19 08410-61220 SCREW-MACHINE M6 (4) SEDAN 2 DOOR 20 08915-13620 WASHER-SPRING LOCK (4) SEDAN 2 DOOR 21 08915-43620 WASHER-SPRING (4) SEDAN 2 DOOR 22 79710-H1001 WEATHERSTRIP-REAR WINDOW SEDAN 22 79710-H1000 WEATHERSTRIP-REAR WINDOW SEDAN 23 79713-H1101 GLASS-REAR WINDOW T=4.0 TEMPERED & T SEDAN OP 23 79713-H1103 GLASS-REAR WINDOW T=4.0 TEMPERED & T SEDAN OP 23 79713-H1001 GLASS-REAR WINDOW T=4.0 TEMPERED SEDAN 23 79713-H1003 GLASS-REAR WINDOW T T=4.0 SEDAN 23 79713-H2900 GLASS-REAR WINDOW,T=4,0, HEAT,ANTI SU SEDAN 23 79713-H2901 GLASS-REAR WINDOW T=4.0 HEAT OP SEDAN 0771- 24 79810-H1100 SET-MOULDING REAR WINDOW SEDAN(DX) 24 79810-H1101 SET-MOULDING REAR WINDOW SEDAN(DX) 0670- 25 79812-H1100 MOULDING-REAR WINDOW UPPER SEDAN(DX) 26 79811-H1101 MOULDING-REAR WINDOW UPPER RH SEDAN(DX) 0670- 27 79812-H1101 MOULDING-REAR WINDOW UPPER LH SEDAN(DX) 0670- 28 79813-H1100 MOULDING-REAR WINDOW LOWER SEDAN(DX) 29 79814-H1100 MOULDING-REAR WINDOW RH SEDAN(DX) 29 79814-H1101 MOULDING-REAR WINDOW RH SEDAN(DX) 0670- 30 79815-H1100 MOULDING-REAR WINDOW LH SEDAN(DX) 30 79815-H1101 MOULDING-REAR WINDOW LH SEDAN(DX) 0670- 31 72814-13600 CLIP-MOULDING (2) SEDAN(DX) 0670-
Coupe
Side Window
1 76802-H1801 WEATHERSTRIP-SIDE WINDOW RH COUPE 2 76803-H1801 WEATHERSTRIP-SIDE WINDOW LH COUPE 3 76822-H1805 GLASS-SIDE WINDOW RH TINTED T=4.0 COUPE 4 76823-H1805 GLASS-SIDE WINDOW LH TINTED T=4.0 COUPE 5 76824-H1801 ASSY-SASH SIDE WINDOW RH COUPE 6 76825-H1801 ASSY-SASH SIDE WINDOW LH COUPE 7 76826-H1806 RUBBER-SIDE WINDOW (2) COUPE 7 76826-H1807 RUBBER-SIDE WINDOW (2) COUPE 0970- 2 76826-H1806 8 08310-41218 SCREW-MACHINE WITH TOOTH WASHER FIX H (8) COUPE 9 76870-H1200 ASSY-HANDLE SIDE WINDOW RH COUPE 10 76871-H1200 ASSY-HANDLE SIDE WINDOW LH COUPE 11 76872-18000 PIN-HANDLE SIDE WINDOW (2) COUPE 12 08430-41619 SCREW-MACHINE M4 (4) COUPE 13 08916-43410 WASHER-TOOTH M4 (4) COUPE 14 76873-18000 SHIM-HANDLE SIDE WINDOW (2) COUPE 14 76873-H1200 SHIM-HANDLE SIDE WINDOW (T=1.00) (2) COUPE 2 76873-18000 14 76873-H1210 SHIM-HANDLE SIDE WINDOW (T=2.00) (2) COUPE
Rear Window
1 79710-H1800 WEATHERSTRIP-REAR WINDOW COUPE 2 79713-H1805 GLASS-REAR WINDOW TINTED T=4.0 COUPE 2 79713-H2201 GLASS-REAR WINDOW,TINTED HEAT RIGHT,T OP COUPE 3 79810-H1800 SET-MOULDING REAR WINDOW COUPE 4 79812-H1800 MOULDING-REAR WINDOW UPPER COUPE 5 79813-H1800 MOULDING-REAR WINDOW LOWER COUPE 6 79814-H1800 MOULDING-REAR WINDOW SIDE RH COUPE 7 79815-H1800 MOULDING-REAR WINDOW SIDE LH COUPE 8 79816-H1800 CLIP-MOULDING UPPER (2) COUPE 9 79817-H1800 CLIP-MOULDING LOWER (2) COUPE
