Keys
Revision as of 21:31, 17 February 2025; view current revision
Category: Body
Keys for some 1200s in some markets are matched: One key opens all doors as well as operates the ignition. In other markets there is a different key for the ignition. Also there are left-hand and right-hand keys that otherwise look identical.
Also see:
* Locks
* Ignition Switch
Usage
1972 USA Owners manual
29363.jpg03   29364.jpg04
Your Datsun is equipped with an ignition key warning buzzer. A buzzer will sound when the key is left in the ignition switch and the driver's door is opened.
Key Types
Early 1200s used two keys: a reversible key for the doors, and a single-sided key for the ignition switch. Starting from 1972, Datsun 1200 in the USA was fitted with a revised ignition switch which used the same key as the doors.
VOSS double-sided (reversible) Nissan Motor key. KEY00-00035
14874.jpgAlbum 14874
Early models with optional steering lock used a VOSS single-sided oval-headed key for the ignition. So these 1200s used two keys:
21977.jpgAlbum 21977
The use of one-key-fits-all or two keys depended on the model, year and country:
22000.jpgAlbum 22000
* USA 1971 sedan: 2 different keys
* USA 1971 coupe: single key
* USA 1972-1973: single key
OVAL KEYS
Early 1200 models with optional steering lock used an oval-headed key for the steering column. In the USA market, this was 1971 only.
VOSS KEY00-00034/VH1000 single-sided
21987.jpgAlbum 21987
VOSS-type keys (KEY00-00034) were made by Kanto Seiki under license of VOSS of Germany. These were used starting around 1969. The former WASO type (KEY00-00028) were made by Kanto Seiki under license of WASO of Sweden. The only real difference is the length. The VOSS keys are shorter, which means WASO key won't fit in the VOSS cylinder. The longer VOSS keys should never be used in a WASO cylinder, as it may lock the steering incorrectly.
Nissan Motor Keys
1972-1973 Datsun 1200 used VOSS double-sided keys with the "Nissan Motor" text and "N" symbol. These fit the dash ignition switch, doors, boot and fuel filler lid locks. Also, later 1200s with steering lock used this key instead of the oval key.
VOSS KEY00-00035 double-sided
VOSS double-sided newer shape used in JDM (Sunny Truck) and SADM (Bakkie)
21980.jpgAlbum 21980 14875.jpgAlbum 14875
KEY00-00055 Left-hand $8.27 USD (not KEY00-00056 Right-hand)
24396.jpgAlbum 24396
B110 key is shorter than 510 key:
24395.jpgAlbum 24395
Ignition Switch
21998.jpgAlbum 21998
Also see: Key Part Numbers
Also see: Locks
KEY00-00055 Key Blank-Master
* supersedes 80610-H1001 KEY ASS'Y-with holder Coupe
Replacement style, genuine Nissan part:
KEY00-00035 KEY-BLANK 8110-
KEY00-00055 KEY-BLANK
21997.jpgAlbum 21997
KEY00-00035 KEY-BLANK FOR VOSS TYPE [reversible]
KEY00-00034 KEY-BLANK FOR VOSS TYPE STEERING LOCK [single-sided]
21981.jpgAlbum 21981 21978.jpgAlbum 21978
B110 USA
80610-H1900 KEY (WITHOUT HOLDER)
80610-H1001 ASSY-KEY [with leather holder]
80690-E6000 CASE ASSY-KEY [leather case for key]
B210 USA
KEY00-00039 KEY-BLANK ST'G LOCK & DOOR
B310
K9810-H9101 KEY SET -0880
99810-H9101 KEY SET 0179-
99810-H9100 KEY SET -1278
KEY00-00039 KEY-BLANK,TYPE L
Dimensions
Length
Nissan keys come in various lengths. The original Datsun 1200 keys were the short length.
21983.jpgAlbum 21983
  • Short: ~31 mm groove length
    • 2.0 inch overall
    • Original 1200 reversible key length
  • Medium: ~38 mm groove length
    • 2.4 inch overall
    • Used by Datsuns & Nissans 1974-1981, Subaru, and Mazda Cosmo
  • Long: ~46 mm groove length
    • 2.7 inch overall
NISSAN KEY LENGTHS
11mm KEY00-00035
21mm KEY00-00036
21mm KEY00-00037
Width
Width is 8.9 mm at the point where the grooves start.
21984.jpgAlbum 21984
Width of the teeth area is 7.1 mm
Center groove width: 2.3 mm
Outside groove width: about 1.0 mm minimum (some keys have it machined all the way out, that is to say a wider groove)
Right-Handed vs Left-Handed
The reversible key came in left-hand and right-hand versions. Make sure you buy the type that fits your Datsun.
24394.jpgAlbum 24394
KEY00-00035 left groove (Datsun 1200)
2nd groove is left of center groove
KEY00-00035
2nd groove is right of center groove
21982.jpgAlbum 21982
KEY00-00034 R (Datsun 510)
Aftermarket Keys
Two styles were used (center, right). The newer, longer one (left) will work, but is not the original style.
10322.jpgAlbum 10322
The little groove diagrams below the photos are for the keylock, so they are the reverse of the actual key.
WARNING: The first key is right-handed, while the second is left-handed. Each key comes either way. Be sure to purchase the correct one for your 1200 locks.
Interesting that some 1200s came with two different keys originally. The 1971-1973 North American models came with single key for ignition, doors and trunk.
Oval Single-Sided Nissan Ignition Key
This is the earlier style for 1968-1971 Datsun, Mazda before the double-sided keys were used. This was used by 1971 USA 1200.
* Nissan: KEY00-00034 (Key-Blank for Voss Type Steering Lock)
* Ilco/Ilco-Kaba: DA20
NOT THIS Waso:
* Waso Type FH
* Taylor: D80K
Short Double-Sided Nissan Key
A double-sided (reversible) key was used by 1972-up 1200s for the ignition switch.
* Nissan: KEY00-00035 (Key-Blank for Voss Type)
* Ilco: 62DV
* Dominion/DL/Hook: DT17
* Taylor: X10
* JMA DAT-8
** Silca : DAT 7
** HD Hook : C050
** HD Hook : C50
** Orion : DA12
** Errebi : NS3R
** CEA : NS7
** RST : D131
** CB Hook : 212
** Standard : 212
** Curtis : DA-21
Taylor X10
21989.jpgAlbum 21989
Long Nissan/Subaru Key
Used by Datsuns, Nissans 1974-1981, Subaru, and Mazda Cosmo. This "long" key is not original to the 1200, but works perfectly fine.
Reversible (left) 2.4 inches long
* Taylor 62DU
* Ilco X7
* Nissan M5001
* Taylor X7
* JMA DAT-1D
** Silca : DAT 6R
** HD : DT19
** HD Hook : C052
** HD Hook : C52
** Orion : DA11L
** Errebi : NS2R
** CEA : NS6S
** RST : D151
** RST : D151R
** CB Hook : 214
** DL : DT19
** Curtis : DA-21
NOT this! Reversible (Right, mirror image)
* Nissan M4001
* Taylor X6
* Ilco X6
* JMA DAT-1I
** Silca : DAT 6
** HD : DT18
** HD Hook : C051
** HD Hook : C51
** Orion : DA11
** Errebi : NS2
** CEA : NS6
** RST : C151R
** RST : D151R
** CB Hook : 213
** CB Hook : 215
** DL : DT18
** Curtis : DA-22
Single-sided
* Taylor D80D/D80E/D80F/D80G
Option
80610-H1001 Key Ass'y (with holder)
1555.jpgAlbum 1555
Key Code
When your key gets worn down too far, making a copy results in a poorly-working new key. Instead, have a new key cut from the original key code.
  • In Australia, the key cut number was stamped directly into the original keys
  • Additionally, the code may be stamped on the right-side door lock cylinder. Remove the door panel to get at the clip which holds the lock in.
    • Not necessarily stamped on left-side door lock, nor trunk/boot lock, nor ignition lock
21992.jpgAlbum 21992
In USA, the key cut number was penciled onto the inside of the glove box door:
13443.jpgAlbum 13443
  • VF: for VOSS single-side KEY00-00034
    • mine is marked "1", possibly to indicate my locks are a single-key system
  • VH: for older (pre-Datsun 1200) WASO KEY00-0028
  • Eng*/DOOR: 4-digit key code
Codes
  • In the range of (M)5001-(M)6000 (or N) for reversible KEY00-00035/KEY00-00055
  • range 4001-5000 is for mirror image keys (non-Datsun 1200)
Non-1200 Keys
Older keys
14873.jpgAlbum 14873
WASO Oval Keys
Use only VOSS type for Datsun 1200
21985.jpgAlbum 21985
Single-Cut Keys
Do not confuse Datsun 1200 keys with these single-sided VOSS keys. They also had "Nissan Motor" text and "N" symbol, but were used by earlier models e.g. Datsun Roadster.
21986.jpgAlbum 21986
21988.jpgAlbum 21988
From http://www5.plala.or.jp/power_planning/key.html:
* KEY00-00201 non-centered grooves
  Mirror of 00202
* KEY00-00202 non-centered grooves
* KEY00-00203 centered groove
* KEY00-00204 centered groove
  Mirror of 00204
21979.jpgAlbum 21979
Mascot Keys/Fashion Keys
30 ネコポス可 サニー M165
Sunny-S logo inside a fiery sun with 'Nissan' in a psychedelic font
20514.jpgAlbum 20514 20513.jpgAlbum 20513
ロイヤルクローバーキー
21976.jpgAlbum 21976
18306.jpgAlbum 18306 20901.jpgAlbum 20901
Nissan Mascot Key by Goto G.SS (Fuki) M165 type
'TO FIT Sunny' - Roman M301 - Accessory Keys ニッサン用 [Nissan Use]
174_5a4b3ce8b8bc2.jpgPost 487114 174_5a4b3d01cdbf1.jpgPost 487114
Sunny Anniversary key with Sunny-chan
17846.jpgAlbum 17846 17845.jpgAlbum 17845
Outback Lock
Datsun Lock
15136.jpgAlbum 15136
Usage:
2975.jpgAlbum 2975
