Trunk Fitting Part Numbers
Revision as of 02:07, 30 May 2025; view current revision
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Trunk (bonnet)
Coupe
30396.jpgAlbum click to view
Sedan
See Trunk & Bumper Part Numbers
Coupe
1 84902-H2500 TRIM-TRUNK FLOOR CENTER COUPE 0271- 0 84902-H1800
1 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211 COUPE 0772- 2 85207-H1801
1 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20 COUPE 0772-
1 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13 COUPE 0772-
1 84902-H1800 TRIM-TRUNK FLOOR CENTER COUPE
2 76983-68400 LOCK-MALE COUPE
3 84903-H7100 TRIM-TRUNK FLOOR RH (BLUE,LB-211 COUPE 0772-
3 84903-H7101 TRIM-TRUNK FLOOR RH (BEIGE,LH-20 COUPE 0772-
3 84903-H2501 TRIM-TRUNK FLOOR RH COUPE EVAPO 0271- 0 84903-H1900
3 84903-H1900 TRIM-TRUNK FLOOR RH COUPE EVAPO 0470-
3 84903-H1800 TRIM-TRUNK FLOOR RH COUPE
3 84903-H7102 TRIM-TRUNK FLOOR RH (BLACK,LG-13 COUPE 0772-
4 84904-H1800 TRIM-TRUNK FLOOR LH COUPE
4 84904-H2500 TRIM-TRUNK FLOOR LH COUPE 0271- 0 84904-H1800
4 84904-H7100 TRIM-TRUNK FLOOR LH (BLUE,LB-211 COUPE 0772- 0 84904-H2500
4 84904-H7101 TRIM-TRUNK FLOOR LH (BEIGE,LH-20 COUPE 0772-
4 84904-H7102 TRIM-TRUNK FLOOR LH (BLACK,LG-13 COUPE 0772-
5 08510-51612 SCREW-TAPPING M5 FIX TRIM 1 (16) COUPE
6 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM 1 (16) COUPE
7 08915-43510 WASHER-PLAIN M5 FIX TRIM 1 (16) COUPE
8 76982-68400 ASSY-LOCK FEMALE COUPE
9 08410-41210 SCREW-TAPPING COUPE
10 08915-43410 WASHER-PLAIN COUPE
11 08915-13410 WASHER-LOCK COUPE
12 84905-H1800 STOPPER-TRIM TRUNK FLOOR COUPE
13 84911-H1800 FINISH-TRUNK LID T=1.5 COUPE
13 84921-H1900 FINISH-TRUNK SIDE RH T=2 COUPE EVAPO
14 84922-H1800 FINISH-TRUNK SIDE T=1.5 COUPE EVAPO
14 84921-H1800 FINISH-TRUNK SIDE RH T=1.5 COUPE
14 84921-H2500 FINISH-TRUNK SIDE RH T=1,5 COUPE 0271- 0 84921-H1800
15 84922-H1800 FINISH-TRUNK SIDE LH T=1.5 COUPE
15 84922-H2500 FINISH-TRUNK SIDE LH T=1.5 COUPE 0271- 0 84922-H1800
16 84931-H1800 FINISH-TRUNK REAR T=2 COUPE
16 84931-H1801 FINISH-TRUNK REAR T=2 COUPE EVAPO 0470-
16 84931-H2501 FINISH-TRUNK REAR T=2 COUPE EVAPO 0271- 0 84931-H1801
17 66919-H1001 CLIP-TRIM 1 (14) COUPE
18 66919-H1099 CLIP-TRIM 1 (15) COUPE
19 84932-H1800 MASK-REAR LAMP T=2 (2) COUPE
19 84932-H2500 MASK-REAR LAMP T=2 (2) COUPE 0271- 0 84932-H1800
20 84941-H1800 COVER-TRUNK LID HINGE COUPE
21 84939-H1800 WELT-TRUNK FINISH COUPE
