Grunterhunter Supercharged A-series
Revision as of 02:42, 14 October 2025; view current revision
Category: Forced Induction
<-- back to SC14
11103.jpgAlbum 11103 7443.jpgAlbum 7443
The supercharged 1978 Datsun 1200 ute was POST sold to Simmo999 July 2008.
* A15 and 60 series overdrive 5-speed.
* Toyota SC14 blower & downdraught weber
* Pulsar radiator
* High pressure water methanol injection
* Extractors and stainless exhaust
Good solid performance with a 14.7 second 1/4 mile @ 89mph.
Toyota SC14 supercharger is the most popular blower swap for Datsun 1200s. It comes from the Supra Toyota 1G-GZE straight-6 engine.
11096.jpgAlbum 11096
10psi boost = 100+ horsepower
12489.jpgAlbum 12489
Grunterhunter:
torque like a turbo diesel.You really notice the extra punch down low. ... i had to tow [another car] up a reasonably steep hill (probably 1 in 5 incline)- Half throttle, 3-4 psi of boost at 2000 rpm in 4th and it just chugged its way up, happy as larry
Grunterhunter draw-through setup
POST Grunterhunter: my setup lasted a surprisingly long time with non intercooled drawthrough 10psi and 9.7:1 comp- but it does have a fairly big cam, so compression is all relative. You are shooting youself in the foot putting a shim in an otherwise standard engine for 10psi. decreasing your squish will rob you of lots of kW without much gain from the decreased comp/ extra boost potential.
A Weber 32/36 Carburetor is bolted to the blower
12010.jpgAlbum 12010 11219.jpgAlbum 11219 11216.jpgAlbum 11216 11215.jpgAlbum 11215
11214.jpgAlbum 11214
Carbie could also be put in the corner of the engine bay
11213.jpgAlbum 11213
Supercharger outlet manifold
11218.jpgAlbum 11218
EGR delete plate
11217.jpgAlbum 11217
Radiator
Radiator needs to cool 100+ horsepower.
Pulsar radiator keeps it all cool.
11221.jpgAlbum 11221
Blower flanges
11220.jpgAlbum 11220
Gallery
photo gallery
Air Cleaner
With a standard ramflow air cleaner for DGV carburetor
12012.jpgAlbum 12012 11216.jpgAlbum 11216
Or, top it with a PB110 air cleaner (requires hood modification)
12438.jpgAlbum 12438
blow output tube goes to stock intake manifold
12011.jpgAlbum 12011
Brackets
12437.jpgAlbum 12437 11103.jpgAlbum 11103
pulleys
11120.jpgAlbum 11120
11102.jpgAlbum 11102 11097.jpgAlbum 11097 11100.jpgAlbum 11100 11099.jpgAlbum 11099
Outlet can be placed to the left
11098.jpgAlbum 11098
Possible outlet for intercooler, though intercooler is not required
11101.jpgAlbum 11101
