Sedan badges
Revision as of 06:56, 2 November 2025; view current revision
Category: Body
Sedan grille badges
Side #C-pillar trim badge and #Rear Quarter name badge
Rear #Model badge, #Trim badge, and #Transmission badge
16673.jpgAlbum 16673 16134.jpgAlbum 16134 17765.jpgAlbum 17765 9928.jpgAlbum 9928 758.jpgAlbum 758 20863.jpgAlbum 20863 20862.jpgAlbum 20862
South Africa GX badges
10248.jpgAlbum 10248
Grille
Center badge & Left-side trim badge
Side
20868.jpgAlbum 20868
Rear Quarter
#76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
#76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
20867.jpgAlbum 20867
Location
14093.jpgAlbum 14093 14094.jpgAlbum 14094
76854-H1000
174_5d5270a05de0e.jpgPost 492238 174_5d5270c9e99cd.jpgPost 492238
Similar:
PB110_Badges#Sunny_Quarter_Badge
9998_4d9ca51941ed4.jpgPost 362773
76854-H1600
76854-H1600 EMBLEM-'Datsun' BODY SIDE Sedan, Coupe Export
15745.jpgAlbum 15745
3973.jpgCoupe 20843.jpg#Sedan
'Datsun' badge has same three pins as '#Sunny' badge, so it is interchangeable
24320.jpgAlbum 24320 24323.jpgAlbum 24323
C-pillar
C-pillar Emblems:
#DX
#GL
#GX
20866.jpgAlbum 20866
DX: ~70mm wide, GX: 99mm wide?, GL 100mm or 109mm wide?
All three badges have a similar pin arrangement, perhaps it is the same
#76852-H1000 BADGE-"Deluxe" SEDAN-DX
20848.jpgAlbum 20848
#76852-H2001 BADGE-"GL" SEDAN-GL
23133.jpgAlbum 23133
#76852-H2300/76853-H2300 BADGE-"GX" SEDAN-GX RH & LH
5204.jpgAlbum 5204
C-pillar Badge Location
1977 GX
15399.jpgAlbum 15399
1973 DX
6576.jpgAlbum click to view
1970? press photos
751.jpgAlbum 751 5271.jpgAlbum 5271
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places on the 2-door sedan:
* 1970-1971 - down low
* l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
748.jpgAlbum 748
1971 - below the corner
1973 at the corner
76852-H1000 DX
76852-H1000 BADGE-"Deluxe" SEDAN-DX ~70mm diameter
13484.jpgAlbum 13484 20848.jpgAlbum 20848
Hand-painted reproduction
24325.jpgAlbum 24325 24324.jpgAlbum 24324
Portugal version
26892.jpgAlbum 26892
76852-H2001 GL
23133.jpgAlbum 23133 28120.jpgAlbum 28120 28121.jpgAlbum 28121 28122.jpgAlbum 28122
76852-H2300 GX
29762.jpgAlbum 29762 15399.jpgAlbum 15399
76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
18264.jpgAlbum 18264 5204.jpgAlbum 5204
Right-side and left-side versions
29760.jpgAlbum 29760 29761.jpgAlbum 29761
Three fasteners
29763.jpgAlbum 29763
Rear
#Model, #Trim, #Transmission
20870.jpgAlbum 20870
174_68b4d11eb557a.jpgPost 499034
14189.jpgAlbum 14189 750.jpgAlbum 750 25995.jpgAlbum 25995
Model
Rear model badge (Datsun or Sunny)
  • Japan domestic models had 'Sunny' badges as they were sold by Sunny Shop
  • Export models had 'Datsun' badges
20894.jpgAlbum 20894
Left Rear Sunny - UK???
84822-H1000
Sunny 1200 - Right Rear
23991.jpgAlbum 23991
84822-H1600
84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN
174_68b4d13a5c91d.jpgPost 499034 18640.gifAlbum 18640
Datsun 1200 - Right Rear signature
21715.jpgAlbum 21715 15650.jpgAlbum 15650 16745.jpgAlbum 16745 19425.jpgAlbum 19425 24319.jpgAlbum 24319 12129.jpgAlbum 12129 datsun_1200_emblem_1_73.jpg 18640.gifAlbum 18640
9998_4d9ce1b0c1d77.jpgPost 362773 9998_4d9ce1c1e0afe.jpgPost 362773 9998_4d9ce1cb3f975.jpgPost 362773 9998_4d9ce1d957c51.jpgPost 362773 9998_4d9ce1e3104c6.jpgPost 362773 9998_4d9ce1ec91375.jpgPost 362773
Trim
Left Rear trim badge (Deluxe, GL or GX). Standard model (base model) has no trim badge.
Deluxe #84823-H1000 Left Rear
GL early #84823-H2001 Left Rear
GL 1972 #84823-H3300 Left Rear
non-1200 GL
GX #84823-H2300 Left Rear
GX 5-Speed 84823-H7200
Deluxe Rear
Deluxe 84823-H1000 Left Rear sedan attaches to boot lid
Deluxe_trunk_badge_B110.jpg 26891.jpgAlbum 26891
differs from similar looking front facelift badge
* #DELUXE grille badge: long studs for mounting through grille
*  DELUXE trunk badge: small pins for surface mount
174_68b4d147ab0dc.jpgPost 499034 22513.jpgAlbum 22513
21439.jpgAlbum 21439 16172.jpgAlbum 16172 14817.jpgAlbum 14817 24335.jpgAlbum 24335
GL Rear 1970-1971
GL early 84823-H2001 Left Rear sedan & coupe
25776.jpgAlbum 25776 25777.jpgAlbum 25777 25660.jpgAlbum 25660 20864.jpgAlbum 20864 174_5d79542f7af02.jpgPost 492571
GL Rear 1972
GL 1972 84823-H3300 Left Rear Facelift sedan & coupe
174_5d775d43af58d.jpgPost 492555 174_5d7954674ae37.jpgPost 492571
174_5b348e2e94666.jpgPost 488731
GX Rear
Rear GX "see-through" script. Used in Japan and South Africa markets.
174_5d756dcaab01a.jpgPost 492517 174_5d756dd73c003.jpgPost click for topic
84823-H2300 trim badge GX MARK 'GX'
* 1970-1972 Japan
* 1974-1976 South Africa
Used by coupe on Right Side
174_5d74ccd7de40e.jpgPost 492514 11785.jpgAlbum 11785
Used by sedan on Left Side
17111.jpgAlbum 17111 2305.jpgAlbum 2305 25662.jpgAlbum 25662 174_5d756dc157e69.jpgPost 492517
compare to #front GX badge which is not see-through but has a solid background attached
18053.jpgAlbum 18053
approximately 10cm wide
9930.jpgAlbum 9930 174_5d756dac67030.jpgPost 492517
Make your own GX badge
23911.jpgAlbum 23911 23912.jpgAlbum 23912 23913.jpgAlbum 23913 23914.jpgAlbum 23914
Transmission
Rear transmission badge (#Sports or #Automatic)
  • 3-speed cars did not have a gearbox badge
  • 4-speed cars were badged "Sports" in some markets
Sports
79200-H1020 MARK-"Sports" sedan 4-speed
79200-H1060 MARK-"Sports", with sealing washer
"Sports" badge - 4-speed Center Rear (left of license plate)
sports_badge.jpg 20865.jpgAlbum 20865 27820.jpgAlbum 27820
"Sports" 4-speed - to right of license plate - 1972 GL Sedan rear
25977.jpgAlbum 25977 755.jpgAlbum 755
Automatic
#79200-H1020 Early "Full Automatic"
79200-H2820 Late "Full Matic" from '71 April (also used by coupe), 79200-H3200 1972
fullmatic.jpgAlbum click to view 26202.jpgAlbum 26202
N22 Coupe badge on sedan ('Nissan Automatic')
26079.jpgAlbum 26079
79200-H1020
Used on sedan
174_5d744a228ad84.jpgPost 492502 9784.jpgAlbum 9784
Used on early Coupe
