Timing Chain
Revision as of 05:31, 11 November 2025; view current revision
Categories: Engine Mechanical | Valvetrain
<-- back to Camshaft
The Timing Chain drives the Camshaft. The cam pulley is twice as big as the crank pulley, so the cam runs at exactly 1/2 the speed of the crankshaft.
Also see:
* Timing Cover
* Crankshaft Pulley
We have seen a couple of single link timing chains on A12, which is the original A10 single row chain. Insist on the factory specified double-chain, like Nissan did for later A10s.
super-strong Double-Roller chain is standard
8966.jpgAlbum 8966
NOT GOOD - early A10 single-row chain
A10_timing_chain.jpg 24938.jpgAlbum 24938 24939.jpgAlbum 24939
NOTE: A rattle can be the trait of a stretched timing chain. Pinging/pinking has also often been mistaken for timing chain rattle
A-series engine has a short timing chain -- and with an automatic adjuster -- it rarely stretches or goes bad.
24803.jpgAlbum 24803
Compare to the loooooong chaing used in the Nissan KA24E engine:
KA24 often has timing chain problems
Checking For Wear
The timing chain can be directly check when the Timing Cover is off. It can also be indirectly checked for wear even if the engine is all sealed up.
Covered
To check the timing chain, remove the distributor cap, and turn the engine by hand clockwise. Then mark the rotor position. Finally turn the engine back anti-clockwise until the rotor just moves. How much did the engine turn before the rotor did?
* A little -- timing chain is OK
* considerable -- chain is worn
Cover Off
If tensioner spindle projection is more than 15mm, replace chain. Rotate the engine clockwise a bit, then check the distance.
24796.jpgAlbum 24796
This ones looks to be at the limit:
25111-.jpgAlbum click to view
Replacement
14385.jpgAlbum 14385
Alignment
Check the cam gear alignment. It should be exactly like this:
174_4ee9b6405e4fc.jpgUpload click to view
If it is not lined up, see Camshaft_replacement#Timing.
Do not attempt to match up the bright/marked links on the chain. That only works the first time, as soon as you rotate the engine the links will no longer match (even though it is still in time)
Timing here is one tooth off (notice the key on bottom pulley)
Slinger
Don't forget the oil slinger.
12302-18000 THROWER-OIL CRANKSHAFT
21479.jpgAlbum 21479
Kit
The timing chain kit (timing set) includes: Cam, Crank, Chain, Tensioner
KIT SET
CLOYES Part # 94054S RockAuto.com $35.79
CLEVITE/PERFECT CIRCLE Part # 92602
ITM 05390500 RockAuto.com $32
STC SHIMIZU
Timing Kit NIS-A14 (includes sprockets)
Timing Chain Kit CK-NIS-A14 (no sprockets)
14366.jpgAlbum 14366
Cam Sprocket
38 tooth Cam Gear (timing gear)
* Sealed Power 223478 $3.50
* ITM 50022 $4.67
* ITM 50021 $4.67
* CLOYES Part # S47 RockAuto.com $9.41
* Beck/Arnley 0250282 $10.85
Cam Sprocket Bolt
Special bolt 13082
Chain
Same as SRL311 with U20 engine (for Jackshaft)
CHAIN RockAuto.com
* CLOYES Part # S478 $9.40
* CLOYES 94054 $9.70
* BECK/ARNLEY Part # 0240226
* ITM 2354 $7
specs
Links: 54
Pitch: 3/8 inch
Rollers: Double
Timing Marks: 2
Crank Gear Key
Same key is used for the engine crankshaft pulley.
12316-30000 KEY-WOODRUF 5X16 2
Tensioner
* CLOYES Part # 95005 RockAuto.com $3.90
* ITM 60004 $6.37
Early non-return tensioner (A10 engine)
* 13070-18010 ASS'Y-TENSIONER, non-return B10 [double-chain]
Early A12 engines (to April 1970) also used a tensioner on the Tension side of the chain. Apparently this was deemed unnecessary so was omitted starting May 1970.
13083-18001 TENSIONER-CHAIN TENSION SIDE -0470
13084-18000 SUPPORT-TENSIONER TENSION SIDE -0470
08110-62010 BOLT M6 FIXING TENSIONER -0470
Crank Sprocket
19 tooth Crankshaft Gear (Timing Crank Sprocket, Timing Crank Gear)
RockAuto.com
* CLOYES Part # S477 $8.87
* Sealed Power 223477 $6.17
* Beck/Arnley 0250258 $7.36
Adjustable Cam Gear
Fitting an adjustable Camshaft gear lets you fine tune the timing. The cam vendor's recommendations are usually best, but retarding the cam a degree or two will generall shift the torque curve higher up in the RPM range. Advancing the cam will (usually) lower the power curve a few RPM.
ps13kai_0399-img600x450-1335611934sqhy0p82792.jpg ps13kai_0399-img600x450-1335611934g5pec482792.jpg
Adjustable gears come in a few basic kinds:
  • Multi-key. Rollmaster had one with nine adjustible keys in the crank sprocket
  • Multi-hole. Using different holes
  • Variable: Slotted holes allow a continuously variable range
fine-tuning the cam (Timing the camshaft)
3639.jpgAlbum 3639 3640.jpgAlbum 3640
Datsun100ATurbo homemade camshaft pulley
2980.jpgAlbum 2980
Pitroad
682.jpgAlbum 682 174_5b2aac25d538b.jpgPost 488654
Tomei
3639.jpgAlbum 3639 3640.jpgAlbum 3640 174_5b2aaa833efea.jpgPost 488653 174_5b2aaa8bd739b.jpgPost 488653
Rollmaster
7339.jpgAlbum 7339 697.jpgAlbum 697
Kameari - buy at Brojects
21685.jpgAlbum 21685 21684.jpgAlbum 21684 174_5b2aa73a86c00.jpgPost 488652 174_5b2aa5296d0ad.jpgPost 488651 174_5b2aa547291a6.jpgPost 488651 174_5b2aa5549e9ca.jpgPost 488651 174_5b2aa56ba5299.jpgPost 488651 174_5b2aa61f912ba.jpgPost 488651 174_5b2aa62ba77a9.jpgPost 488651
Gear Drive
Touring Sedan (TS) style
25686.jpgAlbum 25686
TSではレギュレーション違反となってしまうが、高回転でのチェーンによるフリクションを減らす為に試みられたカム·ギア·トレイン。 Although it violates regulations for the Touring Sedan class, the cam gear train was an attempt to reduce chain friction at high revolutions.
8324.jpgAlbum 8324
TOMEI
31235.jpgAlbum 31235
