The A15 is a 1488cc) engine produced from 1979 through 1985. The stroke was increased by 5 mm from the A14 engine's 77 mm to measure 82 mm. It produces 85hp. It used a different block casting but the same "tall-block" deck height as the A14. In the Roadstar it is capable of 49 mpg (17,3 km/L). A fuel injected version of the A15 (A15E) was offered in Asian markets.
- A15 ID Mark
- Notice how the block extends above the timing cover by about 1 inch
Applications:
- Datsun Sunny B310 (Datsun 210/Datsun 150Y)
- Datsun F10
- Sportstar and Roadstar utes (B120) from Nissan New Zealand
- Nissan Vanette C120
A14 vs A15
A15 uses the second A14 block casting (same block as A14):
- 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
- Bore: 76 mm
- Stroke A15: 82mm
- Stroke A14: 77mm
Earlier A14 blocks were slightly different. The A15 oil pan has slight bumps in the side to allow the larger crank to swing without touch the pan sides.
- Comparo: Early A14 block with Late A14/A15 block
