Hitachi Twin Carb
Revision as of 17:07, 21 August 2009; view current revision
Category: Fuel System
Some Datsuns were fitted with sidedraft carburetors right from the factory. Usually fitted with twin Hitachi variable venturi carburetors which are very similar to S.U. (Skinners Union) carburettors from Britain. The Datsun 1200 GX models were fitted with twin Hitachi HJE38W 38 mm carburetors. Some Japan-market B210s were fitted with A12T or A14T engines which also used twin-Hitachi carbs. Many Datsun fans refer to the Hitachis sidedraughts as "SUs", so keep that in mind when you read information. It may be about the factory Hitachi sidedrafts, or it may be about the (non-Datsun) British SU sidedrafts.
Reportedly, Hitachi licensed the SU design, but I have yet to see a reference for that (Nissan manual, etc).
Datsun twin-carb setups used two basic Hitachi sizes:
  • 38 mm (1-1/2 inch bore) on most cars
  • 46 mm (1-7/8 inch bore) on Z-cars. These are too big for Nissan A engines (even if you use one) and reportedly the late model flat top 46s are a bad design.
Three Different Designs
Factory Hitachi setups for A-series engine include the A12GX, A12T and A14T types. These were fitted to JDM B110, B210 and Datsun Cherry vehicles. South Africa also sold many Twin-Carb B110s.
  • A12GX for B110 (1971-1973) - Extra Large Oval Ports (30 x 34.5 mm)
  • A12T for B210 (1974-1975) - Extra Large Oval Ports
  • A14T for B210 (1976-1978) - Standard Oval Ports (28 x 34 mm)
A12 GX Engine
The Datsun 1200 GX (Grand Luxe Twin-carb) models were always fitted with the A12 GX Engine. This engine featured a matched pair of left- and right- hand Hitachi HJE38W sidedraft carbs. These are the true "dome-top" Hitachis, already setup for performance. They can use standard SU needles so tuning it quite easy.
11041-H2300 HEAD ASSY-CYLINDER A12 GX B110
See main article A12GX Engine
A12T Engine
JDM 1973-1975 B210 GX models had the A12T twin-carb engine. While very similar to the A12 GX Engine, the A12T engine used different flattop Hitachis and a slightly different intake manifold with a few more fittings. Reportedly, these are decent carburetors that only need a few simple modifications. The B210's A12T cylinder head is identical the A12 GX head, except the passage for old-style rocker oiling may not be drilled in B210 heads.
11041-H5702 HEAD ASS'Y-cylinder A12T
NOTE: B210 "GX" refers to the car and does not necessarily mean the car included a twin-carb engine as the B110 GX did. While 1973-1975 Japan-market B210 GX models did include the A12T engine, outside Japan most B210 GX models were fitted with a single-carb (A12S) engine.
JDM Datsun Cherry (E10) models also used the A12T engine, including the famous Cherry X1-R vehicle.
11041-M0801 HEAD ASSY-CYLINDER A12T
The M08 head looks like the A12GX head. Most likely the fittings and accessory bolts are slightly different from the A12GX version.
A14T Engine
Starting in July 1976, the B120's A12T was replaced by the A14T. This corresponded with the B211 model change (B210 minor facelift). Some (but not all) GX models used the Twin-carb engine; even in Japan other 1976-1978 GX models used a single carb engine. Unlike the A12GX and A12T engines with their monster intake ports, the A14T used standard A14 oval ports (28x34 mm), which are smaller than A12GX ports (30x35mm). A14T used a single tube exhaust manifold (A12 twin-carb engines used twin-outlet exhaust manifold).
11041-M2460 HEAD ASSY-CYLINDER A14T
Datsun Cherry (F10) models with A14T engine also used the very same cylinder head.
  • A14T Manifold matches standard A14 gasket
  • One improvement over the A12GX engine is that the A14T uses a small thermostat where the water goes into the manifold
A14T engines used flat-top carbs, heavily modified from the A12 type Hitachis apparently to manage emission control.
Nissan B211 Parts catalog showing some GX models were fitted with single-carb (A14S) engine:
A14T Features:
  • A lot of emission controls
  • EGR port on top of manifold
  • Throttle servo
  • Flat-top triangular-bell Hitachis
  • Automatic chokes (electric)
  • Vacuum ports on each end, top of manifold
  • No PCV valve fitting
Carb side:
  • 4-bolt pattern on 3.5 in. circle
  • 1.5 inch bore
  • Carb spacing approx 7-1/8 inch
  • Water ports at bottom
Retro-fitting
For true bolt on experience, you will need a complete setup:
  • Intake manifold
  • Exhaust manifold (twin down-pipe cast headers). The clearance differently than regular manifolds
  • Two carbs
  • Fuel lines
  • Accelerator cable & linkage
  • Choke cables
  • Air cleaners
In general on a given manifold you can use SU, Zenith-Stromberg (ZS) or Hitachi sidedrafts, but note that the linkage, hose locations and air cleaner attachment will vary.
NOTE: The Hitachi sidedraught carbs are on the left side of the A-series engine. On a RHD car there is clearance aplenty, but on a LHD car fitting an air cleaner it a bit tricky. But this is more easily fitted to LHD than a twin-Weber setup.
Variations
Dome Tops vs Flat tops:
  • Dome Tops are early models
  • Flat Tops are 1974-up some with emission controls
38 mm (1-1/2"): NOTE Linkage differs between different models.
  • HJB38W: Roadster R engine (SPL311-1600)
  • HJB38W-3: Roadster with G engine
  • HJB38W-6: SPL311 1600 Roadster 0565-
    • HJB38W-3-RSF: Rear carb
    • HJB38W-3-FSF: Front carb
  • HJE38W: B110
  • HJL38W6: 510 L16 & L18
  • RL411: Different mounting angle
46 mm (~1-13/16)
  • HJL46W: ?
  • HJG46W: Roadster U20 (SRL311-2000)
  • HJG46W-3A: S30 (240Z) Manual Trans -0871
    • HJG46W-R3A rear carb
    • HJG46W-F3A front carb
  • HJG46W-4: S30 Automatic 0870-0871
  • 1972 changed to water-heated carbs
  • HJG46W-8: S30 1972 manual trans
    • HJG46W-R8B rear carb
    • HJG46W-F8B front carb
  • HJG46W-9: S30 1972 auto trans
    • HJG46W-R9A: rear carb
    • HJG46W-F9A: front carb
  • HBM46W-1 1973-1974 (240Z & 260Z Flat Tops)
http://www.zparts.com/zptech/articles/mal_land/ml_sucarb2/SUcarb_111601b.htm
Parts Donors
  • A-series import engines from Japan
  • Datsun Competition setups
  • Datsun Roadsters: Reportedly, all Roadsters were fitted with Hitachis except the 2000 Roadster (2-liter engine) which came with Solex/Mikuni carbs.
  • Datsun 411 SSS (circa 1966)
  • Datsun 510 (1600) SSS
  • Datsun 610 (180B) SSS
  • Datsun 710 (160J) SSS
Damper Oil
The damper (aka dashpot) is oil-filled. Nissan recommended 20W or 10W30 Elephant Oil, but any brand of motor oil will work. Others have reported success with ATF (automatic transmission fluid), sewing machine oil (generally 10W), or motorcyle oil. The lighter oils tend to run the carb on the lean side.
Tuning
See Datto1000wagon's Tech Article on Datsun1200.com
Go here for lots of information: The Hitachi-SU Tech Pages.
Troubleshooting
Go here for lots of information: The Hitachi-SU Tech Pages - Troubleshooting.
References
  1. Nissan Motorsports catalog (#99996-CAT98 and other years)
  2. Nissan Schematic catalog (#99996-M8015)
Parts Suppliers
  • Z-Therapy sells parts and complete setups http://www.ztherapy.com
    Get the 510 SSS carb setup. The jetting is slightly different but otherwise they are the same
  • craigslist and other local sources (from time to time)
  • eBay from time to time
The parts although not common, are not rare in USA. Quite a few twin setups were found on import engines in the 1980s, and quite a few were purchased from Datsun Competition, so they can be found.
ZTherapy is in the USA, and always has them on hand.
See:
Links
See:
