The Nissan/Datsun Sports Option Parts, Model YN10, HN10 Series publication No. EC-058 is dated August 20, 1982. This article includes parts from the catalog that apply or can be used with Datsun 1200. N10-specific parts are not listed here. Datsun Model N10 was a front wheel drive car marketed as "Pular", "Cherry" or "310". For model years 1978-1982. HN10 indicates A14 engine, while N10 indicates A12A engine.
Engine Tune Up Parts (A12A)
- 11041-H5720 HEAD ASSY-cylinder (w/o valve inserts & guides)
- 11044-M0821 GASKET-cyl head t=0.8, d=79ø [t(std.)=1.2]
- 12010-M0820 PISTON SET-W/Pin (Pin dia.: 17.4ø) d=76ø (w/three piston rings) Forging parts
- 12032-M0820 CLIP-Piston (Total piston displacement: 1,270 cc... Primary specs.)
Oil Catch Tank Parts
- 1 11125-K0475 TANK KIT-Oil Catch Capacity 2l, Resin
- 2 11136-H2310 TANK ASSY-Breather Return
Road Wheel Parts
- 40300-M2221 ROAD WHEEL-FR 9J x 13 (Taper) Aluminum, Offset 10 [4 spoke minilight type]
- 40300-M2220 ROAD WHEEL-RR 8J x 13 (Taper) Aluminum, Offset 10
- 40222-A0220 BOLT-hub M12 x 1.25 x 50
- 40224-R1120 NUT-Road Wheel (Taper) Zinc-plated
- 40224-E7210 NUT-Road Wheel (Taper) Chrome-plated cap nut
- 40209-A0220 SPACER-Road Wheel Aluminum, t = 5
Brakes
- 41060-H1020 PAD ASSY-Brake FR DS11 AN18 caliper for Long distance driving
- 41060-H1021 PAD ASSY-Brake FR M59S AN18 caliper for Short-medium distance driving
- 44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4
- 44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4
- 44100-M7000 CYL ASSY-Wheel 5/8" N10 standard
- 44100-M4901 CYL ASSY-Wheel 11/16" Selective Use
- 44100-G2800 CYL ASSY-Wheel 1/4" Selective Use
- 44100-U9200 CYL ASSY-Wheel 13/16" Selective Use
ETC Parts
- 21400-M7305 RADIATOR ASSY Std. part on HN10E model
- 1 28455-H1075 TACHOMETER ASSY Max Indication: 10,000 rpm
- 2 24880-14675 GAUGE-Oil Temperature Max. Indication: 150° C
- 3 25071-12976 GAUGE-Oil Pressure Max. Indication: 10 kg/cm²
- 4 25072-A9950 HOSE-Oil Pressure l = 2,000
- 5 25080-12976 GAUGE-Water Temperature Max. Indication: 110° C
- 6 25150-E8700 SWITCH ASSY-Ign & Starter
- 7 25400-N3120 SWITCH ASSY-Cut Off
- 8 25371-A7600 LABEL-Cut Off Switch [Triangular]
- 9 25371-N3121 LABEL-Cut Off Switch [Round]
- 10 26360-H1075 BLADE-Windshield Wiper l=400
- 11 63882-H5275 MUD FLAP SIZE 300 x 210, t = 4 ['DATSUN']
- 63824-27720 HANGER-Mud Flap 4 needed
- 63826-27720 PLATE-Mud Flap 4 needed
