Datsun 620 Truck shares some parts with Datsun 1200
- Hood/Bonnet latch
- 65510-H1000 ROD-HOOD SUPPORT [prop rod]
- 66512-H2500 GROMMET-HOOD SUPPORT ROD
- 65514-H1000 CLAMP-HOOD ROD [rod clip]
- 76486-H1000 Body Sill Retainer [rocker panel trim clip]
- 64803-18000 Canoe Rivet for B10 [holds 620 front wheel well inner splash cover]
- 66919-H1001 CLIP -7708 [for kick panel]
- 73940-H1101 ASSIST STRAP-FRONT [above door]
- 76911-H1101 GARNISH-WINDSHIELD PILLAR RH GRAY -7708
- 76912-H1101 GARNISH-WINDSHIELD PILLAR LH GRAY -7708
- 80940-H1101 ARMREST-FRONT DOOR RH BLACK
- 80940-H1100 620 (BLACK) OPTION to 0678, standard equipment from 0778 USA
- 80940-B9501 620 (BROWN) OPTION to 0678, standard equipment from 0778 USA
- 80940-B9700 620 (BLUE) OPTION to 0678, standard equipment from 0778 USA
- 80504-H1001 REMOTE CONTROL ASSY-DOOR LOCK RH [inside lever & internal rod]
- 80505-H1001 REMOTE CONTROL ASSY-DOOR LOCK LH [inside lever & internal rod]
- 90609-H1400 NUT-OUTSIDE HANDLE ROD [door handle]
- 84371-H1000 HOLDER-OUTSIDE HANDLE
- 80508-H1000 SPRING-RETAINING RH
- 80509-H1000 SPRING-RETAINING LH
- 80690-E6000 CASE ASSY-KEY
- 80600-H1001 CYLINDER ASSY-DOOR LOCK RH
- 80601-H1001 CYLINDER ASSY-DOOR LOCK LH
- 76960-H7400 [B310?] CYLINDER ASSY-GAS FILLER LOCK
- 96315-H1000 BASE-MIRROR OUTSIDE [wing mirror]
- 96327-H6200 [B210] BASE-MIRROR INSIDE
- Inside Mirror (part number differs, but base is the same, so it will bolt on)
- 63845-18000 [B10] CLIP-TUBULAR -7708 [clip for push-in badges]
620 Pickup (Ute)
- 85012-H1000 Rear Bumper RH end
- 85013-H1000 Rear Bumper LH end
- 85206-H1401 rear bumper bracket RH
- 76844-H1201 LOCK ASSY-SIDE WINDOW RH
- 76832-H1201 HINGE-SIDE WINDOW
- 76828-H1200 COVER-SIDE WINDOW HINGE
- 76846-H1201 WASHER [window glass]
- 96905-27800 [B120?] LABEL-LOADING CAPACITY 400KG
