Engine Mounts
Revision as of 09:34, 25 November 2009; view current revision
20928.jpg Insulator
[hide]
Engine Crossmember
Front: 1970-1973 1200 engine tall crossmember (B110/B120)
Rear: 1974-up 1200 tall/short engine crossmember
Not only does the new-style engine have a lower mount, but the mount is further back about 1.5 inch. These photos shows how far back:
Original B110 engine brackets:
right side (high-mount)
Top: B110? left side
Bottom: B210? left side
Early Engine Mounting
1970-1973 Datsun 1200
  • 11223-H1000 INSULATOR-engine mounting, front [10 mm studs]
  • 11221-H1000 BRACKET-engine mounting, front (R.H.)
  • 11222-H1000 BRACKET-engine mounting, front (L.H.)
Late Engine Mounting
1974 and up engines are different, and 1974-up 1200s use a corresponding crossmember
  • Low side mount (new crossmembers)
  • 11222-H5001 BRACKET-ENGINE MOUNTING, LH 7510-8503
  • 11222-G1900 BRACKET-ENGINE MOUNTING, LH 8504-
  • High side mount (similar to earlier)
  • 11221-H5000 BRACKET-ENGINE MOUNTING, RH 7510-8503
  • 11221-G1900 BRACKET-ENGINE MOUNTING, RH 8504-
  • 11223-H5000 INSULATOR-ENGINE MOUNTING, FRONT 7510-8503 [8mm studs]
  • 11223-G1900 INSULATOR-ENGINE MOUNTING, FRONT 8504- [8mm studs]
B10 Mounts
As you can see these are different from newer (B110, etc) mounts.
B210 Mounts
  • 11220-H5000 INSULATOR-ENGINE MOUNTING FRONT V [? mm studs]
  • 11220-H7500 INSULATOR-ENGINE MOUNTING FRONT [except] V [10 mm studs]
  • 11221-H7301 BRACKET-ENGINE MOUNTING, FRONT RH
  • 11222-H5001 BRACKET-ENGINE MOUNTING, FRONT LH
B310 Mounts
The B310 insulators have a metal wrap in case the rubber breaks, the engine won't move too far.
  • 11223-H1900 INSULATOR-ENGINE MOUNTING FRONT B310 [10 mm studs]
  • B310 insulators have a larger studs and locating pins, but otherwise are the same dimensions as B110 mounts.
  • 11221-H8500 BRACKET-ENGINE MOUNTING, FRONT RH
  • 11222-H5001 BRACKET-ENGINE MOUNTING, FRONT RH
    • Same as mid-model B120, except larger hole for 10mm studs
Upgraded Insulators
  • "These are the heavy duty engine mounts we were talking about. Broken engine mounts are a common thing in rally cars and this fixes the problem. Mounts are polyurethane and come out of a ford cortina and last for years of competition...Part number MT8156N. Kelpro make them...I usually just go to a good parts place and ask for cortina engine mounts and this is what they give me. Maybe there are two types, these are about 70mm in dia."
keywords マウント エンジン マウンテング
