The Hitach H150 differential was fitted to 1975-up Sunny, starting in September 1974. It has a 150mm (5.91 inch) ring gear, so is stronger than the H145 that was fitted to previous models. H150 is strong enough to handle the torque from A14 and A15 engines. Datsun used the H150 for all A14-powered cars.
Ratios
- H150 is HA
- H150A is HB
3.700
HB37, 3.700:1 ratio
JAPAN B310 A15 USA B210 MANUAL 0476- USA B310 A14 MANUAL -0780 USA B310 AUTO CAN,FED 0880-
3.889
HB38, 3.889:1 ratio replaced the H145 3.90. The new ratio with 35/9 teeth allowed for quieter gears than the old 39/10 teeth.
B210 1975-1978 USA B310 A12 AUTO -0780 USA B310 A12 AUTO CAL 0880- USA B310 AUTO, A12 MANUAL 1279- JAPAN B310 -7903 USA B310 AUTO -1179
3.545
HB35 (3.545:1 ratio), highway gear, low torque ratio was only used in USA, and only in the MPG fuel economy champion B310s.
USA B310 MPG A14/15 MANUAL
3.545 is listed in the catalog as being for:
- AUTO(CAL),A12 from Aug 80 [i.e. 1981 model and newer]
- MPG MANUAL
- A15 from Dec 1979 to July 1980
- A14 from Aug 1980 [1980 model only]
Swap Into H145 Housing
The easiest swap is to get the entire rear-axle assembly from a 1975 or newer B210 with A14 (140Y) -- this is the H150 (150mm diameter ring gear). The main spring is 55mm longer, but the others can be used on the 1200.
See Bolts right in!
Japan diff
Datsun Competition (later Nismo) used to sell various ratios: 3.545, 3.7, 3.9, 4.111 for the H150.
Whilst NISMO produced H150 LSDs (Limited-Slip Differential), Axles baffles and Oil Coolers were not available from Nissan for the H150.
Good for maybe 125 lb. ft. of torque
You can also just put the H150 gear assembly in the stock H145 axle housing. You just need a 2mm spacer:
Pitroad Spacer
Use a B310 propeller shaft with H150 diff in B110.
38300-H5000 FINAL DRIVE ASS'Y HB38 (35/9=3.889) 38300-H7000 FINAL DRIVE ASSY HB37 (37/10=3.700) 38300-H9000 FINAL DRIVE ASSY HB35 (37:11=3.545)
1 CARRIER COMP-gear 38310-H8500 CARRIER-GEAR HB38 7904- superceded 38310-H5000 CARRIER COMP-gear HB38 38310-H9000 HB37 1279- USA replaced 38310-H9500 38310-H9500 CARRIER-GEAR HB37 1279- replaced 38310-H7000 COMP-CARRIER,GEAR HB37 2 08915-14010 WASHER-lock fixing diff bearing cap (4 needed) 3 38315-H7000 BOLT 7906- superceded 38315-G0400 BOLT-cap fixing diff bearing cap (4) -7905 4 38100-H5000 GEAR SET-hypoid (HB38 35/9=3.8889) 38100-H7000 GEAR SET-hypoid (HB37 37/10=3.700) 38100-H9000 GEAR SET-hypoid (HB35 39/11=3.545) 5 38102-G0300 BOLT-drive gear (8) 6 38103-G0400 STRAP-lock bolt (4) 7 38421-H8500 CASE-DIFF 7909- superceded 38421-H5000 CASE-diff -7908 8 38423-H8500 GEAR-side diff bevel (2) 7906- superceded 38423-H5000 GEAR-side diff bevel (2) -7905 9 38425-G0300 PINION-mate diff bevel (2) 10 SELECT (2) 38424-H5000 WASHER-thrust side gear (t=0.76-0.81) 38424-H5001 WASHER-thrust side gear (t=0.81-0.86) 38424-H5002 WASHER-thrust side gear (t=0.86-0.91) 11 38426-18000 WASHER-thrust pinion mate (2) 12 38427-18000 SHAFT-pinion mate 13 38428-G0400 PIN-lock pinion shaft B210 38428-U1500 PIN-lock pinion shaft B310 14 38440-H1000 BEARING ASS'Y-diff side (2) 15 as required 38453-H1000 SHIM-adjusting side bearing (t=0.05) 38454-H1000 SHIM-adjusting side bearing (t=0.07) 38455-H1000 SHIM-adjusting side bearing (t=0.10) 38456-H1000 SHIM-adjusting side bearing (t=0.20) 38457-H1000 SHIM-adjusting side bearing (t=0.50) 16 38120-18000 BEARING ASS'Y-drive pinion, rear 17 38140-04100 BEARING ASS'Y-drive pinion, front 18 38165-N5000 SPACER-drive pinion (pinion bearing) 19 as required (1) 38154-G0400 WASHER-adjusting drive pinion (t=2.74) 38154-G0401 WASHER-adjusting drive pinion (t=2.77) 38154-G0402 WASHER-adjusting drive pinion (t=2.80) 38154-G0403 WASHER-adjusting drive pinion (t=2.83) 38154-G0404 WASHER-adjusting drive pinion (t=2.86) 38154-G0405 WASHER-adjusting drive pinion (t=2.89) 38154-G0406 WASHER-adjusting drive pinion (t=2.92) 38154-G0407 WASHER-adjusting drive pinion (t=2.95) 38154-G0408 WASHER-adjusting drive pinion (t=2.98) 38154-G0409 WASHER-adjusting drive pinion (t=3.01) 38154-G0410 WASHER-adjusting drive pinion (t=3.04) 38154-G0411 WASHER-adjusting drive pinion (t=3.07) 38154-G0412 WASHER-adjusting drive pinion (t=3.10) 38154-G0413 WASHER-adjusting drive pinion (t=3.13) 38154-G0414 WASHER-adjusting drive pinion (t=3.16) 38154-G0415 WASHER-adjusting drive pinion (t=3.19) 38154-G0416 WASHER-adjusting drive pinion (t=3.22) 38154-G0417 WASHER-adjusting drive pinion (t=3.25) 20 38189-A6100 SEAL-oil front (oil drive pinion) 21 38210-H5000 FLANGE ASS'Y-comp pinion B210 38210-H5003 FLANGE ASS'Y-COMPANION B310 22 38216-U3000 NUT-drive pinion 7805- superceded 38216-U1500 NUT-drive pinion -7804 23 38320-H5000 GASKET-gear carrier 24 38321-H5000 BOLT (8)
Nissan Competition
From the 1984 Nissan Competition Catalog
- H150 RING & PINION SETS (FROM 9/74)
- 38100-H9000 3.545 R&P SET
- 38100-H7000 3.700 R&P SET
- 38100-H5000 3.900 R&P SET
- 38100-H5100 4.111 R&P SET
- The H150 3rd members will fit the B210 (from 8/74) and 210 and do not include limited-slip units
- 38300-H9000 3.545 3RD MEMBER
- 38300-H7000 3.700 3RD MEMBER
- 38300-H5000 3.900 3RD MEMBER
- 38300-H5100 4.111 3RD MEMBER
- The factory does not produce axles baffles or limited-slip units for the H150 differentials.
