Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers/flashers (Australia). Because USA purpose is for visibily (instead of turn signals) they are made larger to be more visible, and are fitted front and rear. USA B110 markers are approximately the same size as B210 worldwide markers.
Variations
- USA: large lenses for running lights/reflectors
- front and rear
- All other countries: long thin ORANGE lenses for turn signal (blinkers)
- front only
Global
- 26160-H1001 LAMP ASS'Y-side flasher
- 26160-G1060 LAMP ASS'Y-side flasher 7804- TRUCK
- integrated two-wire harness (bulb 12V + earth/ground)
- 26161-H1001 LENS
- marked 'IKI 5002 JAPAN'
- 26162-H1001 RIM
- 26164-H1001 PACKING
- 26164-G1060 PACKING 7804- TRUCK
- 01451-00071 SCREW
- 08964-10410 NUT-spring
- 26715-89900 BULB-6W
- 2-wire (12V + Ground)
- right and left differ
- front and back differ
- sedan and coupe differ
COMMON
- 26182-H1900 RIM
- 26715-89902 BULB 12V-8W(ICHIKHO)
- 08964-10410 NUT-SPRING(ICHIKHO)
ORANGE, FRONT
- 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
- 26181-H1900 LENS
- 01451-00041 SCREW (2 per lens)
- 26184-H1900 PACKING RH
OKINAWA FRONT FROM 0772
- 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH FROM 0772
RED, REAR
COMMON
- 26191-H1900 LENS
- 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
- 26194-H1910 PACKING RH(ICHIKHO) COUPE
- 01451-00061 SCREW(ICHIKHO) COUPE
- 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN
- 26194-H1900 PACKING RH(ICHIKHO) SEDAN
- 01451-00041 SCREW(ICHIKHO) SEDAN [same as front]
B210 side lamp is totally different from B110 lamp.
Remember, B110 is rectangular, while B210 is slightly pointed rectangular, or a totally angular lense.
Datsun 1000
See main article: Datsun 1000
Clear Lense
- 26121-27700 Lens [clear]
Custom
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ
