Propeller Shaft
Revision as of 19:31, 2 July 2010; view current revision
Category: Propeller Shaft And Differential Carrier
Datsun 1200 used two types of Propeller Shaft:
  • Replaceable U-joints up to 0273
  • Non-replaceable, from 0373
If your tailshaft has snap rings (C-shaped circlips) holding the U-joints in, they are replaceable.
Automatic driveshaft/tailshaft assembly differs from Manual Transmission. Automatic transmissions are 15mm shorter than a standard transmission, so the automatic shaft slip yoke is 15mm longer. The yoke is the part that is different. The shaft and flange are identical.
Interchange:
  • B210 with H145 Differential uses the same tailshaft
  • B210 with H150 diff use different shaft
  • B120 with H165 differential (PB210) *may* be same as B310 two-piece shaft (?)
  • Longbed Trucks use a 2-piece tailshaft
See Propeller Shaft Swaps for:
  • Part Numbers
  • Specifications, including length
  • Swap information
7662.jpg Dimensions
Parts Numbers
B110
Shaft Assembly - Manual
  • 37000-H1001, 37000-H1000 4-speed 56 to 0872
  • 37000-H3100, 37000-H1011 4-speed 56 from 0973
  • 37000-H3100 4-speed 56 from 0373, "Shell" type (non-replaceable U-joints). Same as B210 with H145 diff
Shaft Assembly - Automatic
  • 37111-20300
U-joint Assembly
  • 37125-H1025, 37125-18025
Slip Yoke
  • 37111-18001 manual
  • 37111-20300 automatic
Flange (that bolts to H145 differential)
  • 37117-18000 (30mm from center of u-joint to end of flange)
B120
  • 01111-00051 BOLT-FIX PROPELLER SHAFT (4)
GB
Long Box
  • 37000-G1410 SHAFT ASS'Y-PROPELLER 7510-9204
  • 37000-95W00 SHAFT ASS'Y-PROPELLER 9204-
  • 37521-Y0125 BEARING KIT-CENTER 7510-9204
    Sunny, 610/710/810, 200SX
  • 37521-W1025 BEARING KIT-CENTER 9204- $146.58
    1986-1997 D21 Pickup (4x2 Navara/Hardbody/Hustler/Camiones)
    1998-present D22 Pickup (4x2 Navara/Frontier/Terrano)
    1979- Cedric 430
    0781- Datsun 910 Maxima L24E+LD28 USA
    1083-0786 Nissan S12 200SX CA18ET+CA20E USA
  • 37525-P0101, 37525-W1010 CUSHION-CENTER BEARING [included in Bearing Kit] $12.63
    • 0780- 910 L24E+LD28 USA
    • 0886- B12 4WD.E16I+4WD.GA16I USA
    • 0885- M10 (FED.S+CAL.S).4WD.CA20E.MT+4WD.CA20E.AT+FED.V.CA20E USA
    • 0179- S110 Z20E+Z22E USA
    • 0185- S12 CA18ET+CA20E+VG30E USA
    • 0788- S13 KA24E+KA24DE USA
  • 37163-G1400 NUT 7510-7712 (1)
  • 37163-G1401 NUT 7801- (1)
  • 38215-61001 WASHER-LOCK (1)
  • 37510-G1401 BRACKET-CENTER BEARING [lower clamp] 7510-8503
  • 37510-G1402 BRACKET-CENTER BEARING 8504-
