Disc Brake Part Numbers
From Datsun 1200 Club
Categories: Brake System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Disc Brake
1 41000-H1006 ASSY-CALIPER RH OP -972 24 41000-H1005
1 41000-H1007 ASSY-CALIPER RH OP 1072- 2 41000-H1006
1 41000-H6100 ASSY-CALIPER RH OP 1172- 6 41000-H1007
1 41000-H6101 ASSY-CALIPER RH OP 1272- 2 41000-H6100
1 41000-H1005 ASSY-CALIPER RH OP
2 41010-H1005 ASSY-CALIPER LH OP
2 41010-H1006 ASSY-CALIPER LH OP -972 24 41010-H1005
2 41010-H1007 ASSY-CALIPER LH OP 1072- 2 41010-H1006
2 41010-H6100 ASSY-CALIPER LH OP 1172- 6 41010-H1007
2 41010-H6101 ASSY-CALIPER LH OP 1272- 2 41010-H6100
3 41060-H1025 KIT-B REPAIR DISC BRAKE OP 41000-H1026
3 41000-H1026 KIT-B REPAIR DISC BRAKE OP
4 41060-H1005 ASSY-PAD FRONT BRAKE (4) OP
4 41060-H1006 ASSY-PAD FRONT BRAKE (4) OP 4 41060-H1005
5 41206-H1005 SPRING-COIL (2) OP
6 41049-H1005 CLIP (2) OP
7 41025-H1005 YOKE (2) OP
8 41040-H1005 SPRING-YOKE (2) OP
9 41041-H1005 SPRING-YOKE (2) OP
10 41121-H1005 PISTON A (2) OP
11 41122-H1005 PISTON B (2) OP
12 41000-H1025 KIT-A REPAIR DISC BRAKE (2) OP
12 41120-28525 KIT-A REPAIR DISC BRAKE (2) OP 41000-H1025
13 41124-28500 SEAL-PISTON (4) OP
14 41127-28500 BOOT (4) OP
15 41135-28500 RING-RETAINING (4) OP
16 41214-H1005 RING-BIAS (2) OP
16 41214-H1007 RING-BIAS (2) OP 0772- 2 41214-H1005
17 41084-H1005 SHIM (4) OP
17 41084-M6800 SHIM (4) OP 41084-H1005
18 41080-H1005 SPRING-HANGER (4) OP
19 41217-28500 PIN (4) OP
20 41128-21010 BLEEDER (2) OP
21 41129-A2410 CAP-BLEEDER (2) OP
22 08114-02510 BOLT-HEX M10X1.25 (4) OP
23 08915-14010 WASHER-LOCK (4) OP
24 41151-H1005 PLATE-BAFFLE RH OP
25 41161-H1005 PLATE-BAFFLE LH OP
26 08340-60812 SCREW-MACHINE M6X1.0 (8) OP
27 08915-13610 WASHER-LOCK (8) OP
28 46245-H1006 ASSY-TUBE TO WHEEL CYL RH OP -473 3
28 46245-H5100 ASSY-TUBE TO WHEEL CYL RH OP 0573- 2 46245-H1006
29 46246-H1006 ASSY-TUBE TO WHEEL CYL LH OP -473 3
29 46246-H5100 ASSY-TUBE TO WHEEL CYL LH OP 0573- 2 46246-H1006
30 46202-89913 ASSY-HOSE BRAKE FRONT L=280 (2) OP
30 46202-H7025 ASSY-HOSE BRAKE FRONT L=280 (2) OP 46202-89913
31 46205-61000 PLATE-LOCK FRONT HOSE (4) OP
32 46206-18000 SPRING-LOCK FRONT HOSE (4) OP
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Disc_Brake_Part_Numbers"
This page has been accessed 8,077 times. This page was last modified 04:51, 4 September 2017. Content is available under Datsun 1200 Club.
