EGI intake manifold
From Datsun 1200 Club
Category: Fuel Injection
<-- Back to EGI
A14E & A15E engines used EGI.
16596.jpgAlbum 16596 15062.jpgAlbum 15062 1100.jpgAlbum 1100
21776.jpgAlbum 21776 21831.jpgAlbum 21831
21849.jpgAlbum 21849 8104.jpgAlbum 8104
On the bottom of the intake manifold is the water hose. It connects to the front block water tube.
21837.jpgAlbum 21837
Water hose is "E" in this photo
14052-H9200 HOSE-WATER
* 08723-12000 CLAMP (2)
High RPM Usage
Modified for 8500 RPM use including larger throttle body
2758.jpgAlbum 2758 6218.jpgAlbum 6218 3273.jpgAlbum 3273 3268.jpgAlbum 3268
Port Size
Port size
* 28x32 mm (medium oval) with injection cutout of extending up to 40mm
* compare to standard A14: 28x34
21848.jpgAlbum 21848
* Port sizes on the same manifold vary a bit
21834.jpgAlbum 21834
14003-H9200 MANIFOLD-INTAKE A14E
14003-H9254 MANIFOLD-INTAKE A15E
* 08223-84510 STUD $1.15 USD
* 08223-84010 STUD $0.78 USD
3684.jpgAlbum 3684
Be sure to port match, as ports can vary.
Black shows the gasket opening (port matching)
21775.jpgAlbum 21775
Support Bracket
Just like the B310 A14 & A15 carburetor manifolds, the EFI manifold needs a support brace.
26722.jpgAlbum 26722 174_58ad5435b7983.jpgPost 484061
14018-H9200 MANIFOLD SUPPORT
fasteners to manifold
* 14018E (2) 11053-H9200 MANIFOLD BRACKET WASHER
* 08120-81610 BOLT M8x16
fasteners to engine mount stud
* 08915-53810 PLAIN LARGE WASHER M8
* 08915-23810 THICK SPRING LOCK WASHER M8
* 08911-10810 M8 NUT
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=EGI_intake_manifold"
This page has been accessed 5,265 times. This page was last modified 08:52, 1 June 2019. Content is available under Datsun 1200 Club.
