Rocker arms
From Datsun 1200 Club
Category: Valvetrain
The rocker shaft assembly (including the rocker arms) bolts to the cylinder head. Also see Pushrods and Lifters.
The stock 1.44:1 rocker arm ratio means that for every 0.100 lift at the camshaft lobe, the valve opens 0.144 inch (less slight flexing of pushrod and rocker arm).
Stock Datsun A-series
* 13257-18003 ROCKER-VALVE (4) $16.25 USD
* 13258-18003 ROCKER-VALVE (4) $16.25 USD
Roller-tipped rocker arms can increase horsepower and reduce valvetrain wear. The low friction of the roller bearings & roller tip lessen the side-to-side wear of the valve guides. Higher ratios like the Datsun Competition rocker arms increase this side thrust force, so using roller rockers seems like a good idea.
If the head has been skimmed extensively or the block machined down, see: Rocker geometry
16015.jpgAlbum 16015 504.jpgAlbum 504 25201.jpgAlbum 25201 25655.jpgAlbum 25655
Parts
 Also see Valvetrain Part Numbers
ROCKER-VALVE NO.1 (4)
ROCKER-VALVE NO.2 (4)
13252-18000 ASSY-SHAFT & VALVE ROCKER A12
ROCKER SHAFT EXPANSHION PLUG (2)
SPRING-INSIDE ROCKER SHAFT (4)
BRACKET-ROCKER SHAFT (5)
BOLT-ROCKER SHAFT (5)
08915-43810 WASHER-PLAIN (5)
SCREW-ADJUSTING ROCKER VALVE (8)
13288-H5000 NUT-ADJUSTING ROCKER VALVE (8) < 13288-18001, 01225-00112 $0.82 USD
* NUT-LOCK ROCKER PIVOT SCREW
High-Ratio Rocker Arms
Nismo
Datsun Competition/Nismo rocker arms
* highlift
* large diameter mushroom
Datsun Competition (Nismo) stock-type rockers (1.54:1) and Rocker rollers are available in more extreme ratios than the stock 1.44:1 rocker arm ratio. This means that at maximum opening, the valves open further than with the stockers.
When using these rockers, there are two things that should be checked before installing:
  • Valve-to-piston clearance - this is in addition to the normal valve stem clearance check (Valve adjustment)
  • Clearance in the valve spring/collet/spring seat area (Spring coil bind) and retainer-to-guide or guide seal clearance
We all know that sometimes even a few thousands of an inch clearance can make all the difference between success and engine damage.
If a high-lift camshaft is being fitted, it is doubly important to check these clearances.
Piston-to-valve static clearance should be between 0.060 inch for a stock-cammed street engine to 0.080 or more for a high-lift cam racing engine. Remember that the valves grows a little bit as they warm up. Clearance is most often adjusted by machining the valve pockets in the piston face a bit deeper. This may also need to be done if you mill the cylinder head. This is usually only a problem with Flat-top pistons.
Ford 250
Quote: "Ford rockers off the earlier 250's have a 1.6:1 ratio and can be resized to fit the datsun rocker shaft."
wikipedia: "Officially dubbed the Thriftpower Six, this engine line is sometimes referred to as the Falcon Six."
The stock ratio is 1.5. High-ratio 1.6 is available aftermarket, for example from Classic Inlines.
High RPM
The only place the little race A series is fragile is in the design and wall thickness of the original rocker shaft. It is a thin wall tube that has plugged ends and allows oil to be fed to the rocker bores. Over time the mounting posts can soften and deform causing the rocker to bind simply because the rocker shaft has become out of round. The extra lift and load of big cams only makes this worse.
When assembling your top end and check that you have zero rocker bind once the posts are torqued up. If there is a problem you might have to use a little loctite on the post bolts and reduce the torque setting on individual bolts to ensure no deformation of the rocker shaft Outside Diameter.
Modified Shaft
Pitroad sells a modified shaft to reduce friction and improve oiling. Grooves are machine around the rocker arm oiling holes.
174_5ae4f63c6ec84.jpgPost 488198 174_5ae4f5d884f85.jpgPost 488198
Shaft Collars
To avoid high-speed galling, you can machine up some rocker spacers to ensure good oil pressure at the rocker bores. They replace the end float springs in the stock design, and when set up right ensure the centreline of the rocker is directly over the centreline of the valve head (see Rocker geometry).
6232_4c0c27a197844.jpgPost 320874 174_5ae4f3cc585ba.jpgPost 320874
This little build tip has been a very cheap and effective solution to a problem that only applies to high-lift high-load high-rpm engines.
Bproject Spacers for high-RPM operation
21481.jpgAlbum 21481 8677.jpgAlbum 8677
* Bprojects spacers
* POST Pitroad spacers
* Fumiya spacers
Pitroad
174_5ae4f3aeb0c1e.jpgPost 488198
174_5ae4f63c6ec84.jpgPost 488198 174_5ae4f3962c907.jpgPost 488198
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Rocker_arms"
This page has been accessed 25,759 times. This page was last modified 19:22, 31 March 2019. Content is available under Datsun 1200 Club.
