Tail Light Troubleshooting
From Datsun 1200 Club
<-- back to Tail Lights
Inoperative rear taillights, Turn Signal lights, or brake lights? Check for adequate grounding/earthing of the plastic combination lamp assembly.
Service Bulletin
24397.jpgAlbum 24397
1. Check the metal-to-metal contact of the ground wire (black) from the right side tail light assembly at the grounding post on the panel inside the trunk area. Remove any paint or dirt that prevents good contact
Sedan
24398.jpgAlbum 24398
Coupe
24399.jpgAlbum 24399
2. Using an ohmmeter, check the ground wire (black) from the harness in the engine compartment to the battery negative post for continuity to the instruments and lights of the vehicle. If continuity is lacking, repair the break or replace the wire
3. A heavy gauge ground strap connecting the engine to the body of the vehicle assures proper grounding. The ground strap is built into the original negative battery cable
21177.jpgAlbum 21177
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Tail_Light_Troubleshooting"
This page has been accessed 1,657 times. This page was last modified 22:40, 11 September 2025. Content is available under Datsun 1200 Club.
