Template:EI Curve
From Datsun 1200 Club
Spark Curve
When swapping distributors, will the spark curve be right?
Actually, the weights and curves from a stock A12 distributor are not right for performance. You should calibrate every distributor if you want maximum performance.
Otherwise, yes it will run as-is no problems. Set the static initial timing to 5 degrees BTDC for USA distributors, as they have MORE advance than non-USA distributors (which are set to 7 degrees initial). Likely you could go up to 7 or 9 degrees, but it depends on the tolerance of the individual distributor and your specific engine. In other words, don't let it ping.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Template:EI_Curve"
This page has been accessed 470 times. This page was last modified 00:08, 14 December 2012. Content is available under Datsun 1200 Club.
