Adapting Seats
From Datsun 1200 Club
Category: Interior
<-- back to Seats
NOTE: When bolting in seats, use high-strength bolts (10.8 spec), so that in a minor accident the bolts do not break.
Many, many seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Seat Adapting
5186.jpgAlbum 5186
Seat Slide
554.gifAlbum 554 573.gifAlbum 573 574.gifAlbum 574
Chassis Brackets - for flat seat runners
5085.jpgAlbum 5085
323 seats in 1200 coupe
9731.jpgAlbum 9731
17934.jpgAlbum 17934 17935.jpgAlbum 17935
22679.jpgAlbum 22679
Australia Legalities
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Adapting_Seats"
This page has been accessed 388 times. This page was last modified 06:46, 6 September 2025. Content is available under Datsun 1200 Club.
