The Datsun 1200 had a wikipedia:Unibody design made out of high-strength steel.
Also See
Also See:
- Badges emblems, marks, IDs
- Colors
- Radiator Grille
and
Bonnet (Hood)
The bonnet (hood) of the Datsun 1200 is a classic design: an elegant flat sheet with a strengthening ridge down the middle. You can use the ridge to aim it down the autobahn.
See main article: Hood
Guards (Fenders)
See Fenders
Doors
See main article: Doors
Rear Panels
Rear Panel
Sometimes called a beaver panel, however the 1200 rear panel is one piece:
- 79100-H1000 ASS'Y PANEL-rear Sedan
- 79100-H1800 ASS'Y PANEL-rear Coupe
- 79100-H1400 ASS'Y PANEL-rear Van
Ute
Back Panel
- 79110-G1001 PANEL-REAR, LOWER
Rear Gate Panel
See Tailgate
Rear Floor Panel
The rear floor is the bottom of the tray (cargo well). The supporting structure (side members and cross members) are also part of the floor.
Rear Floor Panel サニトラ リア フロア パネル
- 79100-G1000 PANEL ASSY-BACK -7803
- 79106-G1401 PANEL-BACK, LOWER -7803
- 79100-G1060 PANEL ASSY-BACK 7804-
- 79106-G1660 PANEL-BACK, LOWER 7804-8105
- 79106-G1902 PANEL-BACK, LOWER 8106-8111 SB
- 79106-G1903 PANEL-BACK, LOWER 8106-8111 LB
- 79106-G1904 PANEL-BACK, LOWER 8112- SB
- 79106-G1905 PANEL-BACK, LOWER 8112- LB
- 74502-G1001 PANEL-floor, rear SB
- 74502-G1400 PANEL-floor, rear LB
- 16 74502-G1001 PANEL-floor, rear
- 17 74540-G1000 COVER ASS'Y-floor hole (up to '71-3)
- 17 74540-G1001 COVER ASS'Y-floor hole (from '71-4)
- 18 74546-G1001 ANGLE-floor hole (up to '71-3) (2)
- 18 74546-G1002 ANGLE-floor hole (from '71-4) (2)
- 19 24200-89920 CLIP (2)
- 20 74850-G1001 MEMBER ASS'Y-rear side (R.H.)
- 20 74851-G1000 MEMBER ASS'Y-rear side (L.H.)
- 21 55202-G1000 BRACKET ASS'Y-rear spring, front (R.H.)
- 21 55203-G1000 BRACKET ASS'Y-rear spring, front (L.H.)
- 22 55242-G1000 STOPPER ASS'Y-bumper rear (R.H.)
- 22 55243-G1000 STOPPER ASS'Y-bumper rear (L.H.)
- 23 55208-G1000 BRACKET ASS'Y-shackle (2)
- 24 20633-G1001 BRACKET-muffler mounting (2)
- 25 74860-G1002 MEMBER ASS'Y-cross #1, replaced 74860-G1001
- 26 74870-G1000 MEMBER ASS'Y-cross #2
- 27 17241-G1000 BRACKET ASS'Y-fuel tank mounting
- 28 74870-G1002 MEMBER ASS'Y-cross #3, replaced 74870-G1001
- 29 [not used for Short Bed]
- 30 74890-G1001 MEMBER ASS'Y-rear end
- 31 96206-G1000 BRACKET ASS'Y-license plate
- 31 96206-G1001 BRACKET ASS'Y-license plate
- 32 79110-G1001 PANEL ASS'Y-rear, replaced 79110-G1000
Long Body - parts above except:
- 16 74502-G1400 PANEL-floor, rear LB
- 20 74850-G1400 MEMBER ASS'Y-rear side (R.H.)
- 20 74851-G1400 MEMBER ASS'Y-rear side (L.H.)
- 21 55202-G1400 BRACKET ASS'Y-rear spring, front (R.H.)
- 21 55203-G1400 BRACKET ASS'Y-rear spring, front (L.H.)
- 23 55208-G1400 BRACKET ASS'Y-shackle (R.H.)
- 23 55209-G1400 BRACKET ASS'Y-shackle (L.H.)
- 25 74860-G1401 MEMBER ASS'Y-cross #1
- 26 74867-G1400 MEMBER ASS'Y-cross #2 LB
- 27 17241-G1400 BRACKET ASS'Y-fuel tank mounting bar
- 28 74870-G1000 MEMBER ASS'Y-cross #3
- 29 74880-G1400 MEMBER ASS'Y-cross #4
- 30 74890-G1400 MEMBER ASS'Y-rear end
Rear Side Panels
Ute Rear Side
- Long Body has 5 hooks per side
- Short Body has 4 hooks per side
- Red parts differ Long Body versus Short Body
76304-G1025 PANEL ASS'Y-body side outer (R.H.) 76305-G1025 PANEL ASS'Y-body side outer (L.H.) 1 76306-G1050 PANEL ASS'Y-body side outer rear (R.H.) with gas filler lid2 76307-G1050 PANEL ASS'Y-body side outer rear (L.H.) 3 76310-G1050 PANEL ASS'Y-body side outer rear end (R.H.) 3 76311-G1050 PANEL ASS'Y-body side outer rear end (L.H.) 4 90510-G1000 HOOK ASS'Y-rear gate (R.H.) 4 90511-G1000 HOOK ASS'Y-rear gate (L.H.) 5 75310-G1000 REINFORCEMENT ASS'Y-anchorage upper (R.H.) 5 75311-G1000 REINFORCEMENT ASS'Y-anchorage upper (L.H.) 6 76500-G1000 PILLAR ASS'Y-center (R.H.) 6 76501-G1000 PILLAR ASS'Y-center (L.H.) 7 76308-G1050 PANEL ASS'Y-body side outer upper (R.H.) superceded 76308 G1000 8 76309-G1050 PANEL ASS'Y-body side outer upper (L.H.) superceded 76309-G1000 9 76320-G1027 PANEL ASS'Y-body side inner rear (R.H.) 10 76321-G1026 PANEL ASS'Y-body side inner rear (L.H.) superceded 76321 G1025 superceded 76320-G1026, which replaced 76320-G1025
11 93332-G1000 HOOK-rope (8) 12 79200-G1000 PANEL ASS'Y-back inside (R.H.) 12 79201-G1000 PANEL ASS'Y-back inside (L.H.) 13 76907-G1000 COVER-body side (R.H.) [3-bar] 13 76908-G1000 COVER-body side (L.H.) [3-bar]
* 14 96706-G1000 GROMMET-screw (12 per side) * 15 08530-51612 SCREW (12 per side)
Long Body - same as above except:
76304-G1425 PANEL ASS'Y-body side outer (R.H.) LB 76305-G1425 PANEL ASS'Y-body side outer (L.H.) LB 1 76306-G1450 PANEL ASS'Y-body side outer rear (R.H.) with gas filler lid 2 76307-G1400 PANEL ASS'Y-body side outer rear (L.H.) 9 76320-G1425 PANEL ASS'Y-body side inner rear (R.H.) 10 76321-G1425 PANEL ASS'Y-body side inner rear (L.H.) 11 93332-G1000 HOOK-rope (10) 13 76907-G1400 COVER-body side (R.H.) [4-bar] 13 76908-G1400 COVER-body side (L.H.) [4-bar]
Rear Quarters
Scuff Plate
- 74951-H3600 PLATE-KICKING FRONT RH SEDAN 2DR, COUPE $27.67 USD
- formerly 74951-H1200
- 74952-H3600 PLATE-KICKING FRONT LH SEDAN 2DR, COUPE $25.17 USD
- formerly 74952-H1200
- 74921-H1100 COVER-FLOOR SIDE FRONT RH SEDAN 2DR, COUPE NLA
- 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 0173- NLA
- 74922-H1100 COVER-FLOOR SIDE FRONT LH SEDAN 2DR NLA
- 74922-H7002 COVER-FLOOR SIDE FRONT LH SEDAN 2DR (BLACK,LG-13 0173- NLA
- 74925-H1300 COVER-FLOOR SIDE REAR RH SEDAN 2DR NLA
- 74926-H1300 COVER-FLOOR SIDE REAR LH SEDAN 2DR NLA
- 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 SEDAN 2DR NLA
- 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG136 SEDAN 2DR NLA
Interior Trim
- G9910-H7000 Shelf-parcel $63.67
- 79911-H1000 Cover-parcel shelf
- 73950-H1000 Sunvisor-gry $39.83
Front window - 2-dr sedan
- 80260-H1000 Handle-vent R $19.67
- 80261-H1000 Handle-vent L $19.67
Door
- 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
- 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
- 80760-H1000 Handle-regulatr $24.00
Rear window - 2-dr sedan
- 76828-H1200 Cover-hinge [rear window] $1.02 USD
- 76870-H1200 Handle-window RR $39.17 USD
- 76871-H1200 Handle-window RL $40.62 USD
- 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
- 76832-H1201 HINGE-SIDE WINDOW (4) NLA
- 76828-H5300, 76828-H5301 COVER-SIDE WINDOW HINGE B210 [GRAY]
Sedan Trunk
- 84820-H1000 HANDLE-TRUNK
- 84810-H1001 Wthrstrip Trunk $53.73
Misc
- 78130-H1000 Lid-gas Filler SEDAN $18.83
Aftermarket Suppliers
Most of these body panel manufacturers have a minimum sale of a full cargo container. So look for a local distributor.
- CHUNG FU CHING - Taiwan
- EDP - Seattle, WA USA
- Auto Parts Industrial (API)
- http://www.autostone.com/contactus.asp
- We sell Auto Crash Parts to distributors on container base.
- DT20-013-0 DATSUN 1200 -73 FRT APRON LOWER
- DT20-015-0 DATSUN 1200 BONNET (Sedan / Ute)
- DT20-016-1 DATSUN 1200 FR GUARD RH (Sedan / Ute)
- DT20-016-2 DATSUN 1200 FR GUARD LH (Sedan / Ute)
- DT20-077-0 DATSUN 1200 TAILGATE
