Hitachi DCx carburetors have different specifications depending on market, year, state and other factors. All A-series engines used Hitachi DCx-306 carburetors 26/30 bores, except for the A10 engine which used a smaller DCG-286 model with 26/28 bores. A12 carburetors have 20/26 primary/secondary venturis, and other engines used bigger venturis up to A15s which have bigger 21/27 or 23/27 venturis.
- DCG - manual choke
- DCH - electric automatic choke
Also See: Carburetor Repair, Instruction Sheet section
Contents[hide] |
Jet Locations
You will need to remove the carburetor top to identify the exact jets which are installed. This can be done with the carburetor on the engine.
To remove the top:
- remove pump lever cotter pin. The hardest part is disconnecting the throttle pump linkage on the outside of the carb. This is the long lever along the top of the carb and rods that connect the throttle to the pump. There are also small clips that hold the levers. Be careful and don't lose them
- remove choke linkage cotter pin
- remove and plug fuel line
- remove choke pull-off hose
- remove the top screws
- if equipped, disconnect auto choke wires and idle cut solenoid wires
North American Models
| Year | Engine | Hitachi Model |
| 1971 | A12 | Hitachi DCG306 |
| 72-73 | A12 | Hitachi DCH306 |
| 74 | A13 | Hitachi DCH306 |
| 75-76 | A14 | Hitachi DCH306 |
| Year | Jet Size |
| 1971 | No. 98 |
| 1972 | No. 97 |
| 1973 | No. 95 |
| 1974 | No. 104 |
| 1975-76 California | No. 104 |
| 1975-76 | No. 102 |
| 1977-78 California Manual Trans. | No. 105 |
| 1977 | No. 104 |
| 1978 California Manual Trans. | No. 105 |
| 1978 | No. 104 |
| 1978 Federal | 5-speed No. 107 |
| 71-73 No. 80 |
| 74 No. 65 |
| 75-77 No. 95 |
| 1978 All California No. 95 |
| 1978 Four-speed No. 110 |
| 1978 Five-speed No. 65 |
| 1978 Automatic No. 95 |
| Year | Jet Size |
| 1971 | No. 135 |
| 1972-73 | No. 140 |
| 1974 | No. 145 |
| 1975 | No. 150 |
| 1976 | No. 145 |
| 1977-78 | No. 145 |
| Year | Jet Size |
| 71-78 | No. 80 |
| 1977 California 5-speed | No. 60 |
| Year | Jet Size |
| 1971-74 | No. 43 |
| 1975-78 | No. 45 |
| 1978 non-California 5-speed | No. 46 |
| Year | Hitachi Model |
| 71-76 | No. 50 |
Australia Model Specifications
Hitachi DCG-306 (G indicated manual choke)
NOTE: B310 A15 uses DCF-306, which differs from DCG as follows: * vacuum secondaries, instead of counterweighted secondaries * replaceable sight glass with O-ring * modified choke fast idle system
Datsun B310
source: Gregory's
Controls Idle Cut Off Solenoid (anti-diesel valve) Servo Diaphragm Dashpot Venturi primary, A12: 20 mm primary, A14: 22 mm primary, A15: 21 mm secondary, A12: 26 mm secondary, A14/A15: 27 mm Main jet, primary, A12: 96 primary, A14: 104 primary, A15: 100 secondary, A12: 150 secondary, A14: 150 secondary, A15: 145 Main air bleed primary, A12: 80 primary, A14: 65 primary, A15: 70 secondary, A12: 80 secondary, A14: 60 secondary, A15: 80 Slow Jet primary, A12: 43 primary, A14: 46 primary, A15: 43 secondary, A12: 50 secondary, A14: 50 secondary, A15: 70 Slow air bleed primary, A12: 220 primary, A14: 170 primary, A15: 100 secondary, A12: 100 secondary, A14: 100 secondary, A15: 100 Power jet A12: 60 A14: 60 A15: 40
Japan Market Specfications
B110
16010-H1000 DCG306-1 16010-H1001 DCG306-1A (from '70-Sept.) 16010-H1002 DCG306-1B (from '70-Nov.) 16010-H1003 DCG306-1C (from '71-Jul.) 16010-H1004 DCG306-1D (from '71-Sept.)
Controls
manual choke (DCG) idle adjust CAP (from '70-Sept.)
Main jet,
primary, A12: 98 primary, A12: 97 (from '71-Jul.) secondary, A12: 135
Main air bleed
primary, A12: 80 secondary, A12: 80
Slow Jet
primary, A12: 43 secondary, A12: 50
Slow air bleed
primary, A12: 220 secondary, A12: 100
Power jet (Power Valve)
A12: 60
B120
16010-H7802 -7803 16010-G1660 7804-7907 16010-G1615 7908-8109 16010-G2600 8110-8503 16010-G1900 8504-8910 16010-95W00 8910-
