Also see:
Part Numbers Index Main article for usage, photos, cross-reference Block Oil pan Timing Cover
1 11010-H1000 ASSY-BLOCK CYLINDER 11010-H2300 ASSY-BLOCK,CYLINDER USA 0570- <> 11010-H1000 11010-H2300 ASSY-BLOCK,CYLINDER JAPAN GX 2 12293-18001 BOLT FIXING BEARING CAP (10) 08915-14010 WASHER-lock (10) 3 11019-32200 PLUG-WELCH 44 CAM BEARING 4 00933-13500 PLUG-WELCH 35 CORE HOLE (3) 01648-00084 PLUG-WELCH 35 CORE HOLE (3) <> 00933-13500 5 00933-15000 PLUG-WELCH 50 CORE HOLE 6 11021-13200 PLUG-TAPER 12.7 OIL GALLERY (2) 11024-K0100 PLUG-TAPER 12.7 OIL GALLERY (2) <> 11021-13200 7 00933-20650 PLUG-TAPER 6 OIL GALLERY (5) 01647-00011 PLUG-TAPER 6 OIL GALLERY (5) <> 00933-20650 8 11046-73402 DOWEL-TIMING 5 FRONT COVER (2) 11023-32200 DOWEL-TIMING 5 FRONT COVER (2) <> 11046-73402 9 30412-21000 DOWEL-TIMING 9.5 CASE LOCATING (2) USA 30412-73000 DOWEL (9.5 diameter L=12.5) (fixing transmission case) (2) JAPAN 30412-H1000 DOWEL (9.5 diameter L=15.5) (fixing transmission case) (from '71-Jul) (2) JAPAN 10 08213-82810 STUD-FIXING FUEL PUMP (2) 11 08213-84810 STUD FIXING WATER PUMP (3) 1172- 2 08213-84510 08213-84510 STUD FIXING WATER PUMP (3) 12 08223-81610 STUD FIXING ENGINE MOUNTING BRACKET (4) () 15127-18000 ORIFICE-oil gallery (6 diameter x 6.5) 13 12279-18000 SEAL-OIL CRANKSHAFT REAR < 12279-18010 12279-18010 SEAL-OIL CRANKSHAFT REAR (NDK) 0271- <> 12279-H1000 12279-H1000 SEAL-OIL CRANKSHAFT REAR (NOK) 0271- 14 21045-18000 PIPE-SUCTION WATER PUMP ALL (except GX) 21045-H2300 PIPE-SUCTION WATER PUMP GX 15 08931-30410 PLUG-TAPER THREAD WATER DRAIN 16 11037-H1000 NET-STEEL CRANK CASE 17 11038-H1000 PLATE-BAFFLE CRANK CASE 18 08310-61214 SCREW-MACHINE (2)
OIL PAN 19 11110-H1001 ASSY-PAN OIL 20 11119-61000 SEAT-DRAIN PLUG USA 21 11128-69200 PLUG-DRAIN 22 11026-61000 GASKET-DRAIN PLUG 23 11130-18002 SEAL-OIL OIL PAN FRONT 24 11131-18002 SEAL-OIL OIL PAN REAR 25 11132-18001 GASKET-OIL PAN RH 26 11133-18001 GASKET-OIL PAN LH 27 08110-61410 BOLT M6 FIXING OIL PAN (12) ALL (except GX) 08110-61410 BOLT (fixing oil pan) (11) GX 08110-62010 BOLT (fixing oil pan) GX 28 11025-18000 STUD-LOCATING OIL PAN GASKET (4) 29 08915-13610 WASHER-LOCK FIXING OIL PAN (16) 30 08911-1062A NUT M6 FIXING OIL PAN (4) 08911-10610 NUT M6 FIXING OIL PAN (4) <> 08911-1062A 31 11140-H1002 GAUGE-OIL LEVEL <> 11140-H1003 11140-H1003 GAUGE-OIL LEVEL 0271-
32 13035-H1000 ASSY-COVER TIMING CHAIN 0570- 13035-18001 ASSY-COVER TIMING CHAIN -0470 <> 13035-H1000 33 13042-18000 SEAL-OIL CRANKSHAFT FRONT < 13035-H1000 13510-H1000 SEAL-OIL CRANKSHAFT FRONT (NOK) 0271- 34 13083-18001 TENSIONER-CHAIN TENSION SIDE -0470 35 13084-18000 SUPPORT-TENSIONER TENSION SIDE -0470 36 08110-62010 BOLT M6 FIXING TENSIONER -0470 37 11046-73402 DOWEL-WATER PUMP (2) 11023-32200 DOWEL-WATER PUMP (2) <> 11046-73402 38 08110-64010 BOLT-HEX (6) 08915-1361A WASHER-LOCK (6) <> 08915-13610 39 08915-13610 WASHER-LOCK (6) 40 13044-18001 GASKET-TIMING CHAIN COVER 41 10005-H1000 SLINGER-ENGINE FRONT 08110-8161B BOLT-HEX M8 42 08110-81611 BOLT-HEX M8 <> 08110-8161B 43 13002-18020 SET-BUSHING CAMSHAFT STD SIZE 13005-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.75MM 13004-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.50MM 13003-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.25MM <> 13003-18020 13002-H1020 SET-BUSHING CAMSHAFT STD SIZE <> 13002-18020 13003-18020 SET-BUSHING CAMSHAFT UNDER SIZE 0.25MM
CYLINDER LINER 44 11014-H1000 LINER-CYLINDER 5.00 mm over size 11012-H1000 LINER-CYLINDER 4.00 mm over size 11013-H1000 LINER-CYLINDER 450 USA () PCV system: see Emission Control Part Numbers
Sources: 1973 USA Catalog, 1971 Japan Catalog
