Also see:
Part Numbers Index Main article for usage, photos, cross-reference Trunk (boot) Rear Bumper Weatherstripping Jack
Sedan
1 84300-H1000 ASSY-TRUNK LID SEDAN 2 84420-H1000 ASSY-STRIKER SEDAN 3 08915-53610 WASHER-PLAIN M6 (2) SEDAN 4 08310-61214 SCREW-MACHINE WITH WASHER M6 (2) SEDAN 5 84430-H1000 ASSY-LOCK TRUNK LID SEDAN 5 84460-H1000 ASSY-CYLINDER LOCK TRUNK LID SEDAN 5 84460-H1001 ASSY-CYLINDER LOCK TRUNK LID SEDAN 6 08915-43510 WASHER-PLAIN M5 SEDAN 7 08310-51262 SCREW-MACHINE WITH WASHER M5 SEDAN 8 84520-H1001 HINGE-TRUNK LID RH SEDAN 9 84521-H1001 HINGE-TRUNK LID LH SEDAN 10 84532-H1002 BAR-TORSION TRUNK LID RH SEDAN 11 84533-H1002 BAR-TORSION TRUNK LID LH SEDAN 12 65409-18000 PIN-HINGE FIX HINGE TO BRACKET (2) SEDAN 13 84541-18400 WASHER-WAVE FIX FINGE TO BRACKET (2) SEDAN 14 08915-43810 WASHER-PLAIN FIX FINGE TO BRACKET (2) SEDAN 15 08110-61211 BOLT-HEX M6X1.0 FIX HINGE TO TRUNK LID (4) SEDAN 16 08915-43610 WASHER-PLAIN FIX HINGE TO TRUNK LID (4) SEDAN 17 08915-13610 WASHER-LOCK FIX HINGE TO TRUNK LID (4) SEDAN 18 84810-H1001 WEATHERSTRIP-TRUNK LID SEDAN 19 84820-H1000 HANDLE-TRUNK SEDAN 20 84821-H1000 WASHER-TRUNK LID HANDLE SEDAN 21 84832-H1000 SPACER-TRUNK LID SEDAN 22 80833-78500 RUBBER-BUMPER (2) SEDAN 23 84902-H1100 MAT-TRUNK ROOM T=2.5 SEDAN(DX) 24 84910-H1900 FINISH-TRUNK ROOM T=2.5 SEDAN 25 79415-H1000 BAND-RUBBER JACK HANDLE SEDAN 1070- 26 99604-H1400 CLAMP-JACK HANDLE SEDAN 1070- 27 08510-41212 SCREW-TAPPING (7) SEDAN 28 68118-19900 WASHER-PLAIN (7) SEDAN 29 85011-H1900 BUMPER-REAR CENTER SEDAN 29 85011-H7000 BUMPER-REAR CENTER SEDAN 0772- 30 85012-H1000 BUMPER-REAR RH SEDAN 31 85013-H1000 BUMPER-REAR LH SEDAN 32 62663-18000 BOLT-SPECIAL M6 FIX BUMPER CENTER TO SI (4) SEDAN 33 08915-13610 WASHER-LOCK FIX BUMPER CENTER TO SI (4) SEDAN 34 08911-10610 NUT-HEX M6X1.0 FIX BUMPER CENTER TO SI (4) SEDAN 35 08915-53610 WASHER-PLAIN FIX BUMPER CENTER TO SI (4) SEDAN 36 85204-H1000 STAY-BUMPER REAR (2) SEDAN 36 85204-H7000 STAY-BUMPER REAR (2) SEDAN 0772- 37 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER (4) SEDAN 37 08114-01610 BOLT (4) SEDAN 0772- 38 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER (4) SEDAN 38 08915-44010 WASHER-PLAIN (4) SEDAN 0772- 39 08915-13610 WASHER-LOCK M6 FIX STAY TO BUMPER (4) SEDAN 39 08915-14010 WASHER-SPRING (4) SEDAN 0772- 40 08911-10610 NUT-HEX M6 FIX STAY TO BUMPER (4) SEDAN 41 85206-H7000 BRACKET-BUMPER REAR SIDE RH SEDAN 0772- 41 85206-H1000 BRACKET-BUMPER REAR SIDE RH SEDAN 42 85207-H1000 BRACKET-BUMPER REAR SIDE LH SEDAN 42 85207-H7000 BRACKET-BUMPER REAR SIDE LH SEDAN 0772- 43 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER (2) SEDAN 44 08915-43610 WASHER-PLAIN M6 FIX BRACKET TO BUMPER (2) SEDAN 45 08915-13610 WASHER-LOCK FIX BRACKET TO BUMPER (2) SEDAN 46 08911-10610 NUT-HEX M6X1.0 FIX BRACKET TO BUMPER (2) SEDAN 47 08110-82062 BOLT-HEX WITH WASHER FIX STAY TO BODY (2) SEDAN 48 08915-53810 WASHER-PLAIN FIX STAY TO BODY (2) SEDAN 49 62685-73000 WASHER-RUBBER FIX STAY TO BODY (2) SEDAN 50 62678-21000 SHIM-BRACKET BUMPER SIDE FIX BRACKET TO (2) SEDAN 51 08110-61862 BOLT-HEX WITH WASHER FIX BRACKET TO B (2) SEDAN 52 08915-53610 WASHER-PLAIN FIX BRACKET TO BODY (2) SEDAN 53 85020-H1900 OVERRIDER-REAR BUMPER RH OP SEDAN 53 85020-H7000 OVERRIDER-REAR BUMPER RH SEDAN 0772- 54 85021-H1900 OVERRIDER-REAR BUMPER LH OP SEDAN 54 85021-H7000 OVERRIDER-REAR BUMPER LH SEDAN 0772- 55 85024-H1900 RUBBER-OVERRIDER (4) OP SEDAN -672
Coupe
1 84300-H1800 ASSY-TRUNK LID COUPE 2 84420-H1800 ASSY-STRIKER TRUNK LID LOCK COUPE 3 08310-61614 SCREW-MACHINE WITH WASHER M6X1.0 (2) COUPE 4 08915-43610 WASHER-PLAIN M6 (2) COUPE 5 84430-H1800 ASSY-LOCK TRUNK LID COUPE 5 84460-H1800 ASSY-CYLINDER LOCK TRUNK LID COUPE 5 84460-H1801 ASSY-CYLINDER LOCK TRUNK LID COUPE 2 84460-H1800 6 08310-61612 SCREW-MACHINE M6 (2) COUPE 7 08915-13610 WASHER-LOCK M6 (2) COUPE 8 08915-43610 WASHER-PLAIN M6 (2) COUPE 9 84520-H1800 ASSY-HINGE TRUNK LID RH COUPE 10 84521-H1800 ASSY-HINGE TRUNK LID LH COUPE 11 84532-H1800 BAR-TORSION TRUNK LID RH COUPE 12 84533-H1800 BAR-TORSION TRUNK LID LH COUPE 13 84542-H1800 ROLLER-TRUNK LID SPRING (2) COUPE 14 08310-51018 SCREW M5 W/WASHER FIX HINGE TO BODY 1 (10) COUPE 15 77720-89921 SCREW-MACHINE M6 W/WASHER FIX HINGE TO (4) COUPE 16 84810-H1800 WEAHERSTRIP-TRUNK LID COUPE 17 85011-H1905 BUMPER-REAR CENTER COUPE 17 85011-H7100 BUMPER-REAR CENTER COUPE 0772- 0 85011-H1905 18 85012-H1000 BUMPER-REAR RH COUPE 19 85013-H1000 BUMPER-REAR LH COUPE 20 62663-18000 BOLT-SPECIAL M6 FIX BUMP CENTER TO SI (4) COUPE 21 08915-13610 WASHER-LOCK FIX BUMP CENTER TO SIDE (4) COUPE 22 08911-10610 NUT-HEX M6 FIX BUMP CENTER TO SIDE (4) COUPE 23 85204-H7100 ASSY-STAY BUMPER REAR (2) COUPE 0772- 0 85204-H1000 23 85204-H1000 STAY-BUMPER REAR (2) COUPE 24 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER (4) COUPE 24 08144-01610 BOLT (4) COUPE 0772- 25 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER (4) COUPE 25 08915-44010 WASHER-PLAIN (4) COUPE 0772- 26 08915-13610 WASHER-LOCK (4) COUPE 26 08915-14010 WASHER-LOCK (4) COUPE 0772- 27 08911-10610 NUT-HEX M6 (4) COUPE 28 85206-H1801 BRACKET-BUMPER REAR SIDE RH COUPE 28 85206-H7100 BRACKET-BUMPER REAR SIDE RH COUPE 0772- 0 85206-H1801 29 85207-H1801 BRACKET-BUMPER REAR SIDE LH COUPE 29 85207-H1000 BRACKET-BUMPER REAR SIDE LH COUPE 2 85207-H1801 29 85207-H7100 BRACKET-BUMPER REAR SIDE LH COUPE 0772- 0 85207-H1000 30 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER (2) COUPE 31 08915-43610 WASHER-PLAIN M6 (2) COUPE 32 08915-13610 WASHER-LOCK M6 FIX BRACKET TO BUMPER (2) COUPE 33 08911-10610 NUT-HEX M6 (2) COUPE 34 08110-82010 BOLT-HEX M8X1.25 FIX STAY TOBODY (2) COUPE 35 08915-53810 WASHER-PLAIN M8 FIX STAY TO BODY (2) COUPE 36 08915-13810 WASHER-LOCK M8 (2) COUPE 37 62678-21000 SHIM-BRACKET BUMPER SIDE (2) COUPE 38 08110-61810 BOLT-HEX M6 FIX BRACKET TO BODY (2) COUPE 39 08915-53610 WASHER-PLAIN M6 FIX BRACKET TO BODY (2) COUPE 40 08915-13610 WASHER-LOCK M6 FIX BRACKET TO BODY (2) COUPE 41 85020-H1900 OVERRIDER-REAR BUMPER RH COUPE 41 85020-H7000 OVERRIDER-REAR BUMPER RH COUPE 0772- 0 85020-H1900 42 85021-H1900 OVERRIDER-REAR BUMPER LH COUPE 42 85021-H7000 OVERRIDER-REAR BUMPER LH COUPE 0772- 0 85021-H1900 43 85024-H1900 RUBBER-OVERRIDER (4) COUPE -672 2
