Also see:
Part Numbers Index Main articless for usage, photos, cross-reference Floor Trunk (boot) Jack
See Floor Trimming Part Numbers
Sedan
1 74300-H1021 ASSY-FLOOR FRONT SEDAN AUTOMATIC 1 74300-H1010 ASSY-FLOOR FRONT SEDAN 4 SPEED 2 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH SEDAN 3 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH SEDAN 4 74314-H1000 BRACKET-FRONT SEAT INSIDE RH SEDAN 4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH SEDAN 5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH SEDAN 6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH SEDAN 7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH SEDAN 8 74320-H1000 ASSY-FLOOR SIDE RH SEDAN 9 74321-H1000 ASSY-FLOOR SIDE LH SEDAN 10 74500-H7000 ASSY-FLOOR REAR SEDAN 0772- 10 74500-H1000 ASSY-FLOOR REAR SEDAN 10 74500-H2800 ASSY-FLOOR REAR SEDAN 11 74528-H1000 REINFORCEMENT-BUMPER STAY REAR SEDAN 11 74528-H7000 REINFORCEMENT-BUMPER STAY REAR SEDAN 0772- 12 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOW SEDAN 13 74850-H1000 ASSY-MEMBER SIDE REAR RH SEDAN 14 74851-H1000 ASSY-MEMBER SIDE REAR LH SEDAN 15 55208-H1000 ASSY-BRACKET SHACKLE SEDAN 16 74810-H1001 ASSY-MEMBER SIDE FRONT RH SEDAN 17 74811-H1001 ASSY-MEMBER SIDE FRONT LH SEDAN 18 54532-H1001 ASSY-BRACKET TENSION ROD RH SEDAN 19 54533-H1001 ASSY-BRACKET TENSION ROD LH SEDAN 20 74800-H1000 ASSY-MEMBER CROSS FRONT SEDAN 21 74933-H1000 INSULATOR-TUNNEL FRONT SEDAN MANUAL 22 74933-H1020 INSULATOR-FLOOR COVER SEDAN AUTO 23 74931-H1000 INSULATOR-FLOOR FRONT RH SEDAN 24 74932-H1000 INSULATOR-FLOOR FRONT LH SEDAN 25 74934-H1000 INSULATOR-FLOOR,REAR,RH (2) SEDAN (DX) 26 74934-H1025 SET-INSULATOR FLOOR REAR RH SEDAN (DX) 0570- G5930-89902 INSULATOR-FLOOR FRONT LH SEDAN 27 74937-H1000 INSULATOR-TUNNEL REAR SEDAN (DX) 28 74965-H1000 BOOTS-HAND BRAKE SEDAN (DX) 28 74965-H7300 BOOTS-HAND BRAKE SEDAN (DX) 29 74936-H1000 INSULATOR-REAR SEAT LOWER SEDAN(DX) 29 G5930-89902 INSULATOR-REAR SEAT LOWER SEDAN(DX) 30 01658-00041 PLUG-RUBBER 39 (4) SEDAN 30 01658-00021 PLUG-RUBBER 25 FRONT FLOOR HOLE (4) SEDAN 31 57210-18000 HANDLE-SPARE WHEEL CLAMP SEDAN 31 74630-21002 HANDLE-SPARE WHEEL CLAMP SEDAN 0171- 32 84905-H1900 ASSY-COVER SPARE TIRE OP SEDAN 1270- 32 84905-H7000 ASSY-COVER SPARE TIPE SEDAN 0772- 33 74365-73000 PLUG-ANCHURAGE HOLE (4) SEDAN 34 74963-20900 BOOT-CONTROL LEVER SEDAN 4 SPEED 35 32021-35000 PLUG-INSPECTION HOLE SEDAN 36 74882-H1000 MEMBER-CROSS READ END SEDAN
Coupe
1 74300-H1021 ASSY-FLOOR,FRONT COUPE,AUTOMATIC 1 74300-H1010 ASSY-FLOOR FRONT COUPE,MANUAL 2 74310-H1000 ASSY-MEMBER CROSS FRONT SEATRH COUPE 3 74311-H1000 ASSY-MEMBER CROSS FRONT SEATLH COUPE 4 74314-H1000 BRACKET-FRONT SEAT INSIDE RH COUPE 4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH COUPE 2 74314-H1000 5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH COUPE 6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH COUPE 7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH COUPE 8 74320-H1000 ASSY-FLOOR SIDE RH COUPE 9 74321-H1000 ASSY-FLOOR SIDE LH COUPE 10 74500-H1800 ASSY-FLOOR REAR COUPE 10 74500-H1905 ASSY-FLOOR REAR COUPE 0171- 10 74500-H1906 ASSY-FLOOK REAR COUPE 2 74500-H1905 10 74500-H7100 ASSY-FLOOR REAR COUPE 0772- 0 74500-H1906 11 74528-H1800 REINFORCEMENT-BUMPER STAY REAR (2) COUPE 12 84122-H1800 BRACKET-SEAT REAR SIDE (2) COUPE 13 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOWER COUPE 14 74870-H1800 ASSY-MEMBER CROSS SHOCK ABSORBER COUPE 15 74882-H1800 MEMBER-CROSS REAR END COUPE 16 74850-H1800 ASSY-MEMBER SIDE REAR RH COUPE 16 74850-H2501 ASSY-MEMBER SIDE REAR RH COUPE 2 74850-H1800 17 74851-H1800 ASSY-MEMBER SIDE REAR LH COUPE 18 55208-H1000 ASSY-BRACKET SHACKLE RH COUPE 19 55208-H1800 ASSY-BRACKET SHACKLE LH COUPE 20 84106-H1800 BRACKET-TRUNK ROOM TRIM REARSIDE (2) COUPE 21 74810-H1001 ASSY-MEMBER SIDE FRONT RH COUPE 22 74811-H1001 ASSY-MEMBER SIDE FRONT LH COUPE 23 54532-H1001 ASSY-BRACKET TENSION ROD RH COUPE 24 54533-H1001 ASSY-BRACKET TENSION ROD LH COUPE 25 74800-H1000 ASSY-MEMBER CROSS FRONT COUPE 26 74933-H1000 INSULATOR-TUNNEL FRONT COUPE,MANUAL 26 74933-H1020 INSULATOR-TUNNEL,FRONT COUPE,AUTOMATIC 27 74931-H1000 INSULATOR-FLOOR FRONT RH COUPE 28 74932-H1000 INSULATOR-FLOOR FRONT LH COUPE 29 74934-H1000 INSULATOR-FLOOR REAR (2) COUPE 30 74934-H1025 SET-INSULATOR FLOOR REAR RH COUPE 0570- 2 74934-H1000 31 74937-H1000 INSULATOR-TUNNEL REAR COUPE 32 74965-H1000 BOOT-HAND BRAKE COUPE 33 74936-H1000 INSULATOR-REAR SEAL LOWER COUPE 34 84124-H1801 BRACKET-FUEL TANK MOUNTING RH COUPE 35 01658-00021 PLUG-RUBBER 25D (4) COUPE 35 01658-00041 PLUG-RUBBER 39D (4) COUPE 0 01658-00021 36 57210-18000 HANDLE-SPARE WHEEL CLAMP COUPE 36 74630-21002 HANDLE-SPARE WHEEL CLAMP COUPE 0171- 0 57210-18000 37 99606-H1800 CLAMP-JACK HANDLE (2) COUPE 38 74962-H1905 PROTECTOR-BREATHER TUBE COUPE 39 74365-73000 PLUG-ANCHORAGE (2) COUPE 40 74963-20900 BOOT-CONTROL LEVER COUPE 41 32021-35000 PLUG-INSPECTION HOLE 55D COUPE 42 74891-H2500 ASSY-COVER INSPECTION HOLE COUPE 43 08510-61212 SCREW (6) COUPE
