Dash Part Numbers
Revision as of 02:14, 1 May 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Dash
Firewall
Kick Panel
Package Tray
[hide]
DASH
DASH TRIMMING
Dash Side Trimming
Sedan
1 66900-H1001 TRIM-DASH SIDE RH SEDAN
1 66900-H1101 TRIM-DASH SIDE RH SEDAN
2 66901-H1601 TRIM-DASH SIDE LH SEDAN
2 66901-H1901 TRIM-DASH SIDE LH SEDAN
3 08540-41012 SCREW-TAPPING (4) SEDAN
4 08915-43420 WASHER-PLAIN (4) SEDAN
5 08410-61212 SCREW-MACHINE (2) SEDAN
5 08410-61220 SCREW-MACHINE (2) SEDAN
6 36528-22500 WASHER-PLAIN (2) SEDAN
7 66904-H1001 PLUG-DASH SIDE RH SEDAN
8 66905-H1001 PLUG-DASH SIDE LH SEDAN
9 67100-H1600 ASSY-PANEL DUSH UPPER SEDAN
10 46580-H1600 STAY-BRACKET PEDAL & STEERING POS SEDAN
11 46581-H1600 STAY-BRACKET PEDAL & STEERING POS SEDAN
12 67300-H1600 ASSY-PANEL DASH LOWER SEDAN MANUAL
12 67300-H1601 ASSY-PANEL DASH LOWER SEDAN MANUAL 0272-
12 67300-H1922 ASSY-PANEL DASH LOWER SEDAN AUTOMATIC
12 67300-H1921 ASSY-PANEL DASH LOWER SEDAN AUTOMATIC 0272-
13 18050-24900 STOPPER-ACCELERATOR PEDAL SEDAN
14 18055-H1000 BRACKET-ACCELERATOR PEDAL STOPPER SEDAN
15 18023-H1000 RETAINER-ACCELERATOR PEDAL BRACKET SEDAN
16 46570-H1600 ASSY-BRACKET PEDAL & STEERING POS SEDAN
17 67812-H1601 GROMMET-STEERING POST SEDAN
18 67813-H1600 PLATE-STEERING GROMMET LOWER SEDAN
19 67814-H1600 PLATE-STEERING GROMMET UPPER SEDAN
20 08510-51212 SCREW-TAPPING M5 GROMMET FIX (6) SEDAN
21 67900-H1600 ASSY-DASH INSULATOR RH SEDAN
22 67901-H1600 ASSY-DASH INSULATOR LH SEDAN
23 08963-10510 NUT-SPRING TYPE A (4) SEDAN
24 96800-H1600 ASSY-PACKAGE TRAY OP SEDAN
24 96800-H1601 ASSY-PACKAGE TRAY OP SEDAN 0471-
25 08410-61212 SCREW-MACHINE (3) SEDAN
26 36528-22500 WASHER-PLAIN (3) SEDAN
26 01311-00051 WASHER-PLAIN (3) SEDAN 0171-
27 28890-H1000 COVER-WIPER LINK SEDAN 0771-
28 08510-51612 SCREW (4) SEDAN 0771-
29 77730-89906 NUT (4) SEDAN 0771-
30 67830-H1000 CAP-BRACKET PACKAGE TRAY SEDAN(STD)
31 68100-H1600 ASSY-PANELINSTRUMENT SEDAN
32 01111-00022 BOLT-HEX M6X1 INST TO DASH SIDE (2) SEDAN
33 08915-13610 WASHER-LOCK INST TO DASH SIDE (2) SEDAN
34 08915-43610 WASHER-PLAIN INST TO DASH SIDE (2) SEDAN
35 08440-51612 SCREW-MACHINE M5X0.8 INST TODASH UP (3) SEDAN
36 08915-13510 WASHER-LOCK INST TO DASH UP (3) SEDAN
Coupe
1 66900-H1101 TRIM-DASH SIDE RH COUPE
2 66901-H1901 TRIM-DASH SIDE LH COUPE
3 08540-41012 SCREW-TAPPING (4) COUPE
4 08915-43420 WASHER-PLAIN (4) COUPE
5 66904-H1001 PLUG-DASH SIDE RH COUPE
6 66905-H1001 PLUG-DASH SIDE LH COUPE
7 67100-H1600 ASSY-PANEL DUSH UPPER COUPE
8 46580-H1600 STAY-BRACKET PEDAL & STEERING POS COUPE
9 46581-H1600 STAY-BRACKET PEDAL & STEERING POS COUPE
10 67300-H1922 ASSY-PANEL,DASH,LOWER COUPE,AUTOMATIC
10 67300-H1921 ASSY-PANEL,DASH,LOWER COUPE,AUTOMATIC 0272- 2 67300-H1922
10 67300-H1601 ASSY-PANEL,DASH,LOWER COUPE,MANUAL 0272- 2 67300-H1600
10 67300-H1600 ASSY-PANEL DASH LOWER COUPE,MANUAL
11 18050-24900 STOPPER-ACCELERATOR PEDAL COUPE
12 18055-H1000 BRACKET-ACCELERATOR PEDAL STOPPER COUPE
13 18023-H1000 RETAINER-ACCLERATOR PEDAL BRACKET COUPE
14 46570-H1600 ASSY-BRACKET PEDAL & STEERING POS COUPE
15 67812-H1601 GROMMET-STEERING POST COUPE
16 67813-H1600 PLATE-STEERING GROMMET UPPER COUPE
17 67814-H1600 PLATE-STEERING GROMMET LOWER COUPE
18 08510-51212 SCREW-TAPPING M5 GROMMET FIX (6) COUPE
19 48324-H1005 CLAMP-STEERING POST UPPER COUPE
20 48326-H1005 CLAMP-STEERING POST LOWER COUPE
21 48325-04100 PACKING-STEERING POST COUPE
22 08110-82010 BOLT-HEX M8X1.25 CLAMP FIX (2) COUPE
23 08915-43810 WASHER-PLAIN M8 CLAMP FIX (2) COUPE
24 08915-13810 WASHER-LOCK CLAMP FIX (2) COUPE
25 67900-H1600 ASSY-DASH INSULATOR RH COUPE
26 67901-H1600 ASSY-DASH INSULATOR LH COUPE
27 08963-10510 NUT-SPRING TYPE A (4) COUPE
28 96800-H1600 ASSY-PACKAGE TRAY COUPE
28 96800-H1601 ASSY-PACKAGE TRAY COUPE 0471- 2 96800-H1600
29 08410-51212 SCREW-MACHINE (3) COUPE
30 96830-A0800 WASHER-PLAIN (3) COUPE
31 28890-H1000 COVER-WIPER LINK COUPE 0771-
32 08510-51612 SCREW (4) COUPE 0771-
33 77730-89906 NUT (4) COUPE 0771-
34 68100-H1600 ASSY-PANEL INSTRUMENT COUPE
35 01111-00022 BOLT-HEX M6X1 INST TO DASH SIDE (2) COUPE
36 08915-13610 WASHER-LOCK INST TO DASH SIDE (2) COUPE
37 08915-43610 WASHER-PLAIN INST TO DASH SIDE (2) COUPE
38 08440-51612 SCREW-MACHINE M5X0.8 INST TO DASH UP (3) COUPE
39 08915-13510 WASHER-LOCK INST TO DASH UP (3) COUPE
