Carburetor Specifications
Revision as of 02:26, 21 December 2012; view current revision
Hitachi DCx carburetors have different specifications depending on market, year, state and other factors. All A-series engines used Hitachi DCx-306 carburetors 26/30 bores, except for the A10 engine which used a smaller DCG-286 model with 26/28 bores. A12 carburetors have 20/26 primary/secondary venturis, and other engines used bigger venturis up to A15s which have bigger 21/27 or 23/27 venturis.
[hide]
DCG - manual choke
DCH - electric automatic choke from 1972 USA
DCx-306: 26/30 Datsun B110
DCx-286: 26/28 Datsun B10
DCx-340: Datsun 510/620
Also See: Carburetor Repair, Instruction Sheet section
5919.jpg Hitachi DCH306 ID boss
4968.jpgHitachi DCH306
Jet Locations
jet locations
Main jets are accessible without removing the carburetor
Main jets
You will need to remove the carburetor top to identify the other jets which are installed. This can be done with the carburetor on the engine.
See Carburetor Top Removal
pic
pic
If the fuel bowl has dirty fuel like this, remove the main jet plugs (bottom of carb) to drain the fuel.
North American Models
Carburator Models
Year Engine Hitachi Model
1971 A12 Hitachi DCG306
72-73 A12 Hitachi DCH306
74 A13 Hitachi DCH306
75-76 A14 Hitachi DCH306
Primary Main Jet - North American Models
Year Jet Size
1971 No. 98
1972 No. 97
1973 No. 95
1974 No. 104
1975-76 California No. 104
1975-76 No. 102
1977-78 California Manual Trans. No. 105
1977 No. 104
1978 California Manual Trans. No. 105
1978 No. 104
1978 Federal 5-speed No. 107
Main Air Bleed
71-73 No. 80
74 No. 65
75-77 No. 95
1978 All California No. 95
1978 Four-speed No. 110
1978 Five-speed No. 65
1978 Automatic No. 95
Secondary Main Jet
Year Jet Size
1971 No. 135
1972-73 No. 140
1974 No. 145
1975 No. 150
1976 No. 145
1977-78 No. 145
Secondary Air Bleed
Year Jet Size
71-78 No. 80
1977 California 5-speed No. 60
Primary Slow Jet
Year Jet Size
1971-74 No. 43
1975-78 No. 45
1978 non-California 5-speed No. 46
Secondary Slow Jet
Year Hitachi Model
71-76 No. 50
1980
FED 106 original 108 countermeasure [non-GFU]
CAL 107 original 109 countermeasure
Australia Model Specifications
Hitachi DCG-306 (G indicated manual choke)
NOTE: B310 A15 uses DCF-306, which differs from DCG as follows:
* vacuum secondaries, instead of counterweighted secondaries
* replaceable sight glass with O-ring
* modified choke fast idle system
Datsun B310
source: Gregory's
Controls
 Idle Cut Off Solenoid (anti-diesel valve)
 Servo Diaphragm
 Dashpot
Venturi
  primary, A12: 20 mm
  primary, A14: 22 mm
  primary, A15: 21 mm
  secondary, A12: 26 mm
  secondary, A14/A15: 27 mm
Main jet,
 primary, A12: 96
 primary, A14: 104
 primary, A15: 100
 secondary, A12: 150
 secondary, A14: 150
 secondary, A15: 145
Main air bleed
 primary, A12: 80
 primary, A14: 65
 primary, A15: 70
 secondary, A12: 80
 secondary, A14: 60
 secondary, A15: 80
Slow Jet
 primary, A12: 43
 primary, A14: 46
 primary, A15: 43
 secondary, A12: 50
 secondary, A14: 50
 secondary, A15: 70
Slow air bleed
 primary, A12: 220
 primary, A14: 170
 primary, A15: 100
 secondary, A12: 100
 secondary, A14: 100
 secondary, A15: 100
Power jet
 A12: 60
 A14: 60
 A15: 40
Japan Market Specfications
B110
16010-H1000 DCG306-1
16010-H1001 DCG306-1A (from '70-Sept.)
16010-H1002 DCG306-1B (from '70-Nov.)
16010-H1003 DCG306-1C (from '71-Jul.)
16010-H1004 DCG306-1D (from '71-Sept.)
Controls
manual choke (DCG)
idle adjust CAP (from '70-Sept.)
Main jet,
primary, A12: 98
primary, A12: 97 (from '71-Jul.)
secondary, A12: 135
Main air bleed
primary, A12: 80
secondary, A12: 80
Slow Jet
primary, A12: 43
secondary, A12: 50
Slow air bleed
primary, A12: 220
secondary, A12: 100
Power jet (Power Valve)
A12: 60
B120
16010-H7802 -7803
16010-G1660 7804-7907
16010-G1615 7908-8109
16010-G2600 8110-8503
16010-G1900 8504-8910
16010-95W00 8910-
