56-Series Transmission Parts
Revision as of 00:19, 18 August 2013; view current revision
Category: Transmission
Synchros
4-speed and 5-speed synchronizers are very different. 4-speed uses synchro baulk rings. 5-speed has baulk nubs on the hub itself.
4-SPEED EARLY
  • 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED $78 USD
  • 32604-H1000 BAULK RING
  • 32606-18000 SLEEVE-COUPLING $52 USD
4-SPEED LATE
Coupling with hub. Left: assembled. Right: not assembled
5-SPEED
32601-H7200 HUB-SYNCHRONIZER, 2nd & 3rd, 4th & 5th 5-speed
32606-H7200 SLEEVE-coupling
Case
The case is the front part of the transmission (the "bell housing"). The case for 4-speed and 5-speed looks the same, but has different part numbers. Note that different years and different markets added changes to the case.
RHD (JDM Catalog)
  • 32100-18000 CASE-transmission 4-speed B10
    • bell-crank clutch linkage
  • 32100-H1000 CASE-transmission 4-speed B110 (56L)
  • 32100-H7230 CASE-transmission 5-speed B110 GX-5
  • 32100-G1030 CASE COMP.-transmission B120 (56A)
  • 32100-H5035 CASE-transmission 4-speed B210 1975
  • 32100-H5030 CASE-transmission 4-speed B210 (from 7503)
  • 32100-H7421 CASE-transmission 4-speed B210, B310 1976-
  • 32100-G1123 CASE-transmission 4-speed B120 SB 7510-
  • 32100-G1124 CASE-transmission 4-speed B120 LB 7510-
LHD (USA catalog)
  • 32100-H1600 CASE-transmission 4-speed B110 LHD to 0970
  • 32100-H1630 CASE-transmission 4-speed B110 LHD from 1070-
  • 32101-H3900 CASE-transmission 4-speed B110 LHD from 0671-
  • 32101-H3930 CASE-transmission 4-speed B110 LHD from 0172-
  • 32100-H6200, 32100-H6201 CASE-transmission 4-speed B210 LHD to 0874 (A13 engine)
  • 32100-H6127 CASE-transmission 4-speed B210 LHD USA
  • 32100-H8511, 32100-H8529 CASE-transmission 4-speed B210 LHD CANADA
    • Has an electrical switch in case (reverse)
Extension
variations:
  • double-mount with top switch drilled & tapped (8910-)
  • double-mount w/o top switch (? B310?)
  • 56L with bushing & small oil seal (B110 early)
  • 56L with large oil seal (B110 late)
  • 56A with internal w/o oil dam (early B120???)
  • 56A with internal oil dam
F4W56
* 32010-H1652 ASSY-TRANSMISSION(F4W56)
* 32010-H3551 ASSY-TRANSMISSION (F4W56) 0972-
*: replaces 32010-H1652
* 32010-H3950 ASSY-TRANSMISSION(F4W56E)	0671-
* 32010-H3951 ASSY-TRANSMISSION (F4W56L) 0172-
* 32010-H3953 ASSY-TRANSMISSION (F4W56L) 0972-0373
*: replaces 32010-H3951
* 32010-H3963 ASSY-TRANSMISSION (F4W56A) 0473-
*: replaces 32010-H3953
Reverse Lamp Switch
See Reverse Lamp Switch
Counter Gear
Cluster Gear
* 32210-24900 GEAR-COUNTER 29T,25T,19T,13T B10, -0373 B110 (F4W56L)
* 32210-G1100 GEAR-COUNTER 29T,25T,19T,13T B120 ALL, CAR 0473-0874 (F4W56A)
*: USA B110, starting April 1973
*: Used through 1982 (listed for A12-powered B210 & B310)
Bearings
BALL BEARINGS
COUNTER SHAFT, FRONT
* 32219-18000 (56L only)
COUNTER SHAFT, REAR
* 32223-24900 -7805 (56L & 56A)
* 32223-H7400 7806-8109
* 32223-H8500 8110-
INPUT SHAFT (MAIN DRIVE)
* 32203-18000 (56L & 56A)
MAIN SHAFT
* 32273-24900 (56L)
* 32273-G1000 (56A)
32273-H7300 ???
NEEDLE BEARINGS
32219-G1000 COUNTER SHAFT, FRONT (56A only)
32272-18000 BEARING-pilot, main shaft (56L & 56A)
32264-24900 gear (1 or 0), main shaft
32264-18000 gears (2 or 3) 32264-H1000
BUSHING
32283-24901 BUSH-GEAR REVERSE IDLER (56L)
32283-G1100 BUSH-GEAR REVERSE IDLER (56A)
32253-18000 BUSH-1ST GEAR
Bearing Comparison
* 63/71 - TIMKEN 306L F4W63, F4W63A, F4W63L, F4W71B, R4W71A
* 56/60 - TIMKEN 305L F4W56A, F4W56L, F4W60, F4W60L, F4WF60, F4WF60L
Counter Shaft Ball Bearings
RockAuto.com
56L Front Countershaft Bearing
Nissan 32219-18000 BEARING-BALL COUNTER SHAFT
* Timken 305AG (F4W56L)
** also fits Center F4W71B, Rear R4W71A
* National 305 (Aichi F4W56L) $24.89
** Ball Bearing
** Outer Race Radius=0.0402"
** Bore=0.9843"
** Outer Diameter=2.4409"
** Width=0.6693"
** Inner Race Radius=0.0402"
Rear Countershaft Bearing (56L & 56A) -7805
Nissan 32223-24900 BEARING-ball counter
* Timken 303SS (F4W56L) $17
* National/BCA 303SS (Aichi F4W56L)
** Ball Bearing
** Bore=0.6693"
** Outer Diameter=1.8504"
** Width=0.5512"
Rear Countershaft Bearing (56A) 7806-8109
Nissan 32223-H7400
* superseded by 32223-H8500
Rear Countershaft Bearing (56A) 8110-
Nissan 32223-H8500 Bearing Ball $22 USD
rockauto.com
* National 205 $12.10
* Timken 205BB (F4W56A) $13.00
** Ball Bearing
** Width: 0.5906"
** Bore=0.9843"
** Outer Diameter=2.0472"
Counter Shaft Needle Bearing
56A Front Countershaft
* Nissan 32219-G1000 BEARING-NEEDLE COUNTER SHAFT
* Timken 304WB (F4W56A)
** also fits F4W71B front, F4W71A front
** Cone Bearing
** Bore=0.787"
** Outer Diameter=2.047"
** Width=0.591"
Input Shaft Ball Bearing
Rockauto.com
Main Drive Gear Ball Bearing (input shaft 56L & 56A)
32203-18000 BEARING-ball, main drive gear
* superceded by 32203-E9800 $25.45 USD
* Timken 305L Front; F4W56L $27.79
* National 305L Aichi F4W56L
** Ball Bearing
** Bore=0.9843"
** Width=0.6693"
* Timken 306L Front; F4W56A, Front; R4W71A
** Ball Bearing
** Bore=1.1811"
** Outer Diameter=2.8346"
** Width=0.748"
Main Shaft Bearing
Rockauto.com
56L Main Shaft Ball Bearing
Nissan 32273-24900 BEARING-main shaft $21 USD
* SKF 6305J Main Shaft Bearing $24.79
* Timken 305L
56A Main Shaft Ball Bearing
Nissan 32273-G1000 BEARING-ball, main shaft $48 USD
Nissan 32273-H7300 $61 USD
Seals
* SKF Seal 99098 SKF Part # 99098
** http://www.rockauto.com/catalog/x,carcode,1208483,parttype,14200
Input Shaft Seal
* Nissan 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0971-
** supercedes 32113-13200
* Nissan 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0473- [56A]
* http://www.rockauto.com/catalog/x,carcode,1208483,parttype,10065
* Timken 222540 F4W56L, F4W56A $2.84
* National 710316 F4W56L
** Oil Seal: Nitrile
** Shaft Size=0.984"
** Housing Bore=1.575"
** Outer Diameter=1.583"
** Width=0.315"
* Timken 710417 F4W63, F4W63A, F4W63L
* Timken 1981 R4W71A
* Timken KWK99098 Kwik Sleeve repair F4W56L, F4W56A
* National/BCA 99098 Redi-Sleeve $27.79
** .982" x .986" x .313"
Main Shaft Seal
* Nissan 32136-H3100 SEAL-OIL REAR EXTENSION 4 SPEED -0972
** supercedes 32136-18001
* Nissan 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 1072-
* TIMKEN 3771 F4W63, F4W63A, F4W63L, F4W71B, R4W71A $4.04
* TIMKEN 2016 F4W56A, F4W56L, F4W60, F4W60L, F4WF60, F4WF60L $11.04
* NATIONAL 2016 Aichi F4W56L $15.87
** Shaft Size=1.181"
** Housing Bore=1.772"
** Outer Diameter=1.78"
** Width=0.591"
F5C56
Counter Gear
  • 32213-H7200 GEAR-counter B110
  • 32213-H7201 GEAR-counter B210
  • 32210-H7200 GEAR-1st counter
Nissan Competition
  • 32010-H7251 TRANSMISSION ASSY B110 GX-5
  • 32010-H7251P TRANSMISSION ASSY Nissan Competition OPT 1
  • 32010-H7220N TRANSMISSION ASSY Nissan Competition OPT 2
  • 32010-H5250 TRANSMISSION ASSY B210 GFK
  • 32010-H5250 TRANSMISSION ASSY B210 GFK from 73-10
  • 32010-H5251 TRANSMISSION ASSY B210 GFK ratiol tire
  • 32010-H5253 TRANSMISSION ASSY B210 GFK from 73-10 ratiol tire
