910 Brake Rotors can be modified to bolt to the back of the 1200 hub.
Usage
USA: 250 mm (same as the smallest S13 size) EUR: 238 mm JAP: 250 mm or 238 mm
250 mm Nissan 40206-W1210 40206-W1260 40206-W1265 40206-W1270 Girling 6019401 Brembo 09.4789.10 * height: 22mm * center hole: 73 mm * PCD: 4 on 95 mm, 10.7mm holes * thickness: 18mm * weight: 4.13 kg * also used by EUR C120
238 mm Nissan 40206-W1010 40206-W1060 40206-W1070 * 238 mm * height: 22mm * center hole: 73 mm * thickness: 18mm * also used by JAP C120, EUR C120
Rear Discs
Maxima 240mm rear disc brakes can be modified for use on the H165
