All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck). But it varies by country and by year. USA has single-bulb, Japan has dual-bulb. Sunny Truck after 1973 has dual-reflector type.
Market Differences
Front running light lenses are either all-orange or white + orange. Reportedly the lamp housing is different so that you cannot simply swap lenses.
Japan, America (single-color, but are different)
Japan - Single Reflector (early) 3-wire Large + small bulb
Japan - Twin Reflector (late model) 3-wire 2-large-bulb
Body Style
Early Versus Late
Sunny Truck 1200 after September 1973 use a dual-reflector lens. Earlier 1200 Trucks use the standard 1200 single-reflector lense (same as Coupe/Sedan/Van).
This uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector.
Interchange 1200 with B210: Probable, but requires wiring connector change.
Bulbs
See main article: Bulbs
Japan single-reflector * 26717-89920 inner 23/8 watt * 26261-89900 outer (small) 3 watt
Japan dual-reflector * 26717-89900 inner 23 watt * 26715-89920 outer 8/3.4 watt
USA single-bulb * 26717-89920 23/8 watt
Wiring Differences
Connectors
1200 bullet connectors (B110 or B120)
2-wire Versus 3-wire
3-wire bullet connectors - Japan
2-wire bullet connectors - North America
510 Lamps
Do not confuse 1200 front lamps with 510 laps. They look very similar but the
1200 unit is more rounded.
Clear Lenses
Get the right kind of your assembly
- Euro/Aussie
- Japan single-reflector
- Japan dual-reflector
- USA single-bulb, single-reflector
B140
The late-model B140 Bakkie has the front combination lamp in the front bumper.
Gasket
ウインカー パッキンゴム
See Front Combination Lamp Part Numbers
Lens
JAPAN all-orange 26121-H1000 1-reflector lens -7308 ICHIKO 市光 <> 26121-H1010 KOITO 26121-H5000 2-reflector lens 7309- [same as B210]
AUS/EUR orange & white
NORTH AMERICA all-orange 26121-H1000 <> 26121-H1901
Assembly
JAPAN all-orange, dual bulb, 3 male bullet wires 26120-H1000 single reflector -7308 small & large bulbs <> 26120-H1010 KOITO![]()
26120-G1000 dual reflector, two large bulbs 7309-
NORTH AMERICA all-orange, single bulb, 2 male bullet wires 26120-H1900 <> 26120-H1901 <> 26120-H7000
