Body Side Panels
Revision as of 05:35, 4 October 2015; view current revision
Category: Body
Side panels of the Body.
full - 4-door Sedan
60 Front Pillar (A-pillar)
   Front Pillar Lower Reinforcement 8910-
   Window Corner Patch 8504-
62 Windshield Pillar, inner (A-pillar)
64 Dash side (Front Pillar Lower Bracket)
65 Roof Side Rail, outer
67 Roof Side Rail, inner
   Roof Side Rail, rear (Van)
69 Sill Panel, outer
   Sill Panel, inner - See Floor side panel
71 Center Pillar, outer
   Center Pillar, inner
   Center Pillar, lock (Coupe)
73 Rear Pillar, inner (4-door sedan)
   Rear Pillar, outer
   Rear Pillar, lower outer
   Body Side inner panel (2-door sedan)
   Body Side outer panel (see Quarter Panel)
74 Rear Wheel House, outer
76 Rear Wheel House, inner
78 Shock mounting Bracket
79 Rear Sill Closing Plate
81 Lower Trunk floor side panel
2-door Sedan - differs mainly in using Rear Panels instead of rear Pillar.
full
Sill
Sill is the lower plate of the door opening. Sills differ for each body style. It also has the front Jack locating notch stamped in it. Sedan sills additionally have a notch for the rear Jack location.
LONG SILLS - goes back to wheel housing
* H10 4-door Sedan, 4-door Van
* H12 2-door Sedan, 2-door Van
MEDIUM LENGTH - about 6" shorter than Van/Sedan
* H18 Coupe
SHORT SILL - 150mm shorter than Coupe
* G12 Truck > G10 to 8503
2-door Sedan sills
full
full
full
Coupe - 76412-H1800 < G6412-H1800 (pre-drilled for the stainless Moulding)
full
th_76412-H1800a.jpg th_76412-H1800b.jpg th_76412-H1800c.jpg th_76412-H1800d.jpg th_76412-H1800e.jpg th_76412-H1800f.jpg th_76412-H1800g.jpg th_76412-H1800h.jpg th_76412-H1800i.jpg th_76412-H1800j.jpg th_76412-H1800k.jpg
New Sills
Genunine Nissan
full
Aftermarket reproduction
Sill Repair
Ed's 81 Datsun 1200 ute build
Make your own sheet metal brake:
Quarter Panel
Sedan quarter panel
78101-H1900 ASSY-FENDER REAR LH 2DR SEDAN USA
78101-H1200 ASS'Y-FENDER,rear (L.H.) 2 door JAPAN
78101-H1055 ASS'Y-FENDER,rear (L.H.) 4 door JAPAN
Sedan Airbox (attaches to inside of upper quarter)
H10 4-door sedan
H12 2-door sedan
Coupe quarter panel
78111-H1955 ASSY-FENDER REAR LH COUPE 78111-H1905 <> 78111-H1955 USA
78111-H1800 ASS'Y-FENDER,rear <> 78111-H1850 < 78111-H1851 JAPAN
Van quarter panel
78101-H1450 ASS'Y-FENDER, rear (L.H.) < 78101-H1455 JAPAN
Truck Rear Side
  • Long Body has 5 hooks per side
  • Short Body has 4 hooks per side
  • Red parts differ Long Body versus Short Body
76304-G1025 PANEL ASS'Y-body side outer (R.H.)
76305-G1025 PANEL ASS'Y-body side outer (L.H.)
1 76306-G1050 PANEL ASS'Y-body side outer rear (R.H.) with gas filler lid
2 76307-G1050 PANEL ASS'Y-body side outer rear (L.H.)
3 76310-G1050 PANEL ASS'Y-body side outer rear end (R.H.)
3 76311-G1050 PANEL ASS'Y-body side outer rear end (L.H.)
4 90510-G1000 HOOK ASS'Y-rear gate (R.H.)
4 90511-G1000 HOOK ASS'Y-rear gate (L.H.)
5 75310-G1000 REINFORCEMENT ASS'Y-anchorage upper (R.H.)
5 75311-G1000 REINFORCEMENT ASS'Y-anchorage upper (L.H.)
6 76500-G1000 PILLAR ASS'Y-center (R.H.)
6 76501-G1000 PILLAR ASS'Y-center (L.H.)
7 76308-G1050 PANEL ASS'Y-body side outer upper (R.H.)
  * superceded 76308 G1000
8 76309-G1050 PANEL ASS'Y-body side outer upper (L.H.)
  * superceded 76309-G1000
9 76320-G1027 PANEL ASS'Y-body side inner rear (R.H.)
10 76321-G1026 PANEL ASS'Y-body side inner rear (L.H.)
   * superceded 76321 G1025 superceded 76320-G1026
   ** replaced 76320-G1025
11 93332-G1000 HOOK-rope (8)
12 79200-G1000 PANEL ASS'Y-back inside (R.H.)
12 79201-G1000 PANEL ASS'Y-back inside (L.H.)
13 76907-G1000 COVER-body side (R.H.) [3-bar]
13 76908-G1000 COVER-body side (L.H.) [3-bar]
* 14 96706-G1000 GROMMET-screw (12 per side)
* 15 08530-51612 SCREW (12 per side)
Long Body - same as above except:
76304-G1425 PANEL ASS'Y-body side outer (R.H.) LB
76305-G1425 PANEL ASS'Y-body side outer (L.H.) LB
1 76306-G1450 PANEL ASS'Y-body side outer rear (R.H.)
  * includes gas filler lid
2 76307-G1400 PANEL ASS'Y-body side outer rear (L.H.)
9 76320-G1425 PANEL ASS'Y-body side inner rear (R.H.)
10 76321-G1425 PANEL ASS'Y-body side inner rear (L.H.)
11 93332-G1000 HOOK-rope (10)
13 76907-G1400 COVER-body side (R.H.) [4-bar]
13 76908-G1400 COVER-body side (L.H.) [4-bar]
Truck Rear Quarters
X-RAY
3330.jpg 6240.jpg 6241.jpg 9197.jpg 10879.jpg 11082.jpg 11618.jpg 11619.jpg 11621.jpg 11735.jpg 14180.jpg 14468.jpg 14820.jpg 15017.jpg
