Floor
Revision as of 03:25, 8 December 2015; view current revision
Category: Body
フロア The front floor panel is stamped in one piece with the tunnel. However, automatic cars have a separate tunnel.
[hide]
fullsize
A CROSS MEMBER, front seat (RH & LH differ)
  * Van & Truck driver's side has Jack bracket
B SEAT BRACKET, inner (RH & LH)
C SEAT BRACKET, outer (RH & LH)
D (Truck only) Back Panel, lower
E (Truck only) Back Panel
Replacement coupe floor panels by Automotive Panel Craft (1mm cold rolled mild steel)
th_floor_coupe_L_1.jpg th_floor_coupe_L_2.jpg th_floor_coupe_L_3.jpg th_floor_coupe_L_4.jpg
Front Floor
Floor Side (inner sill)
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN/VAN
 1 ASSY-FLOOR FRONT
   74300-H1000 3 SPEED
   74300-H1010 4 SPEED
   74300-H1021 AUTOMATIC
 2 FRONT SEAT CROSS MEMBER RH
 3 FRONT SEAT CROSS MEMBER LH
   * H14 Van RHD [has bracket for Jack]
 4 FRONT SEAT BRACKET-INNER RH
 5 FRONT SEAT BRACKET-INNER LH
 6 FRONT SEAT BRACKET-OUTER RH
 7 FRONT SEAT BRACKET-OUTER LH
 8 INNER SILL (FLOOR SIDE MEMBER) RH
 9 INNER SILL (FLOOR SIDE MEMBER) LH
16 FRONT SIDE MEMBER RH
17 FRONT SIDE MEMBER LH
18 TENSION ROD BRACKET RH
19 TENSION ROD BRACKET LH
20 FRONT CROSS MEMBER
Rear Floor
Coupe, Sedan, Van and Truck all differ in the rear floor area. All use a front & rear crossmember attached to side members to create a basic ladder support to which the floor is attached.
Coupe
Rear Floor, Truck
The Truck rear floor is the bottom of the tray/bed. The supporting structure (side members and cross members) are also part of the floor.
See Truck Rear Floor Panel
Floor Trim
See main article: Upholstery
See main article: Floor Part Numbers
Ute
Rear Floor: See Body Panels
Front Floor Panel サニトラ フロント フロア  パネル
  • 74300-G1050 FLOOR ASS'Y-front (up to '72-12) 3-speed
  • 74300-G1450 FLOOR ASS'Y-front (from '73-1) 3-speed
  • 74300-G1150 FLOOR ASS'Y-front (up to '72-12) 4-speed
  • 74300-G1450 FLOOR ASS'Y-front (from '73-1) 4-speed
  • 74300-G1401 FLOOR-FRONT 7510-7803
  • 74300-G1160 FLOOR-FRONT 7804-8808
  • 74300-G1950 FLOOR-FRONT 8809-9810
  • 74300-95W00 FLOOR-FRONT 9810-
Floor assembly includes:
A
* 74310-H1000 MEMBER ASS'Y-cross seat, front (R.H.) -8904
* 74330-95W00 MEMBER-FRONT SEAT MOUNTING, RH 8904-
* 74311-H1400 MEMBER ASS'Y-cross seat, front (L.H.) -8910
* 74331-95W00 MEMBER-FRONT SEAT MOUNTING, LH 8910-
B
* 74314-H1001 BRACKET-front seat, inside (R.H.)
* 74315-H1000 BRACKET-front seat, inside (L.H.) -8910
* 74351-95W00 BRACKET-FRONT SEAT MOUNTING, INNER LH 8910-
C
* 74316-H1000 BRACKET-front seat, outside(R.H.)
* 74317-H1000 BRACKET-front seat, outside(L.H.)
(not shown in photo)
inner sill, under the aluminum sill trim
* 74320-G1000 FLOOR ASS'Y-side (R.H.)
* 74321-G1000 FLOOR ASS'Y-side (L.H.)
D, E: See Body
Related parts
* 74810-H1001 MEMBER ASS'Y-side, front (R.H.)
* 74810-G1600 MEMBER-SIDE, FRONT RH 7510-7803
* 74810-G1601 MEMBER-SIDE, FRONT RH 7804-8910
* 74810-G1900 MEMBER-SIDE, FRONT RH 8910-
* 74811-H1001 MEMBER ASS'Y-side, front (L.H.)
* 74811-G1601 MEMBER-SIDE, FRONT LH 7510-8503
* 74811-H1001 MEMBER-SIDE, FRONT LH 8504-8910
* 74811-G1900 MEMBER-SIDE, FRONT LH 8910-
* 54532-H1001 BRACKET ASS'Y-tension rod (R.H.)
* 54532-H1001 BRACKET ASS'Y-tension rod (L.H.)
* 74800-H1000 MEMBER ASS'Y-cross front
