Also see: Power Windows
Ventilation
1972 USA Owners manual (page 7: opening of the windows: door window, ventilator glass, and Quarter Window):
Driving Safety and Comfort
Windshield/Windscreen
See main article: Windshield
Front Door Glass
- 2-dr Coupe Door glass differs from 2-dr Sedan glass
- 2-dr and 4-dr glass differs
- 4-dr van and 4-dr sedan are the same
Wing Window
The wing window is officially named the Door Ventilator.
- 80244-H1001 GLASS-door ventilator (R.H.) 2 std
- 80244-H1101 GLASS-door ventilator (R.H.) 2 DX, 2 GL [tinted]
- 80244-H8000 GLASS-door ventilator (R.H.) Coupe
- 80250-H1001 CHANNEL ASS'Y-door ventilator (R.H.) 2 door [pivoting bottom-channel]
- 80250-H1800 CHANNEL ASS'Y-door ventilator (R.H.) Coupe [pivoting bottom-channel]
- 80270-H1001 FRAME ASS'Y-door ventilator (R.H.) 2 door
Compare to Datsun 1000 latch handle
Rubber Seals
2-door sedan, 4-door sedan, and Pickup
- 80282-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, RH $13.69
- 80246-H1000 RUBBER-glazing, door ventilator (2) 2 door-Sedan & Coupe
- [holds glass in the pivoting bottom-channel]
Coupe
- 80282-H1800 WEATHERSTRIP-front door ventilator (R.H.)
- Sedan doors are a bit taller than coupe doors ... about 1/4 to 1/2 inch difference.
- Spectrum Rubber
- 221.101 Quarter window seals - front (coupe) LH
- 221.102 Quarter window seals - front (coupe) RH[/quote]
Rear 4-door Sedan
- 82242-H1000 WEATHERSTRIP-partition rear door (2)
Wing Delete
Datrotor: glass is curved and no you won't find another window to fit.its a big job so don't do it unless you know people and know what your doing.i had custom made rubbers and channels made to suit.and changed the window reg
Front Door Glass
Removal & Reinstall
- Take apart the door bits and pieces
- Unscrew the door pull/armrest, door handle, and window winder
- Carefully pop the door card (panel) off to access the inside of the door. Use a putty knife or other flat tool, slide it between the card and door until you locate the clip. Then twist to pop the clip out. There are two on one end and three on the other end.
- Roll the window up first. Then unbolt the window stop at the bottom of the door.
- Roll the window down so that the regulator comes out of the track on the window glass frame but be careful not to let the window drop too hard. Leave the glass at the bottom of the door temporarily.
- Take the quarter window frame out.
- There are three screws at the top of the door concealed under the door rubber.
- Also there is one larger screw towards the bottom of the door. It's recessed a bit.
- Once loose pull the quarter window assembly out.
- Reach in the door and turn the door glass 90 degrees then pull of out from the top.
- To reinstall, do everything in reverse. However don't tighten the screws on the quarter window assembly until you get the new window to align with the slots on each side. That is the hardest part.
Rubber Seals
Glass Run
Glass Run uses Bailey Channel type rubber.
80336-H1001 RUBBER-glass run "B" (2) 4 door, 2 door 80335-H1001 RUBBER-glass run "A" (2) 4 door 80335-H1202 RUBBER-glass run "A" (2) 2 door 80336-H1800 RUBBER-glass run "B" (2) Coupe 80335-H1800 RUBBER-glass run "A" (2) Coupe
Truck 80336-G1000 RUBBER-glass run "B" (2) * replaced 80336-H1001 RUBBER-glass run "B" (2) 80336-H1001 RETAINER RUBBER-GLASS (2) -8910 80336-G1901 RETAINER RUBBER-GLASS (2) 8910- 80335-G1000 RUBBER-glass run "A" (2) * replaced 80335-H1001 RUBBER-glass run "A" (2) 80335-H1001 GLASS RUN RUBBER-A (2) -8508 80335-G1900 GLASS RUN RUBBER-A (2) 8508-8910 80335-G1901 GLASS RUN RUBBER-A (2) 8910-
Door Weatherstrip
The inside glass rubber is named the Inside Door Weatherstrip.
See main article: Doors#Weatherstrip
ドア ウェザー ストリップ ドア インサイド モール ガラスウエザーストリップ
Rear Door Glass
Van & Sedan differ (H10/H11 vs H14/H15)
* Rear Door Glass (straight on top edge vs slightly curved)
* Rear Door Corner Glass (4-edged vs triangular)
Also see: Rear Door Part Numbers
Window Winders
See main article: Window Winders
Window Regulator
Top: 2-dr Coupe
Bottom: 2-dr Sedan
- 80700-H1202 or 80700-H1201 REGULATOR ASS'Y-door window (2) Sedan-2D
- replaced 80700-H1200 only works up to '70 Oct.
- 80700-H1800 REGULATOR ASS'Y-door window (R.H.) Coupe
- 80701-H1800 REGULATOR ASS'Y-door window (L.H.) Coupe
4-dr Sedan & Wagon
- 80700-H1002 or 80700-H1001 or 80700-H1000 REGULATOR ASS'Y-door window (2)
- 82700-H1001 or 82700-H1000 REGULATOR ASSY-rear door window, RH
- 82701-H1001 or 82701-H1000 REGULATOR ASSY-rear door window, LH
- 80700-H1002 REGULATOR ASSY-DOOR WINDOW, RH
- 80701-H1002 REGULATOR ASSY-DOOR WINDOW, LH
2-dr door regulators have longer pivot arms (pivot point to roller) while the shorter 4-door front door regulators are likewise shorter.
Side Glass
See main article: Side Glass
Rear Window
Removal and Installation
See Installing Rear Window
Truck
Back Window - two sizes (small one is for raised-roof B140)
79712-G1000 GLASS-back window -7308 * 79417-G1001 WEATHERSTRIP 79712-G1200 GLASS-REAR WINDOW 7309- * 79714-G1201 WEATHERSTRIP![]()
Rear Glass Protection Bars 79810-G1000 RAIL-GUARD, REAR WINDOW 7510-![]()
リア ガラス 保護 バー
Sedan
- 79710-H1001 WEATHERSTRIP-REAR WINDOW
- 79710-H1000 WEATHERSTRIP-REAR WINDOW
- 79713-H1101 GLASS-REAR WINDOW T=4.0 TEMPERED & T 0771-
- 79713-H1103 GLASS-REAR WINDOW T=4.0 TEMPERED & T
- 79713-H1001 GLASS-REAR WINDOW T=4.0 TEMPERED
- 79713-H1003 GLASS-REAR WINDOW T T=4.0
- 79713-H2900 GLASS-REAR WINDOW,T=4,0, HEAT,ANTI SU
- 79713-H2901 GLASS-REAR WINDOW T=4.0 HEAT
- 79810-H1100 SET-MOULDING REAR WINDOW
- 79812-H1100 MOULDING-REAR WINDOW UPPER
- 79813-H1100 MOULDING-REAR WINDOW LOWER
- 79814-H1100 MOULDING-REAR WINDOW RH
- 79815-H1100 MOULDING-REAR WINDOW LH
- 79810-H1101 SET-MOULDING REAR WINDOW 0670-
- 79811-H1101 MOULDING-REAR WINDOW UPPER RH
- 79812-H1101 MOULDING-REAR WINDOW UPPER LH
- 79814-H1101 MOULDING-REAR WINDOW RH
- 79815-H1101 MOULDING-REAR WINDOW LH
- 72814-13600 CLIP-MOULDING
Coupe
- 79710-H1800 WEATHERSTRIP-REAR WINDOW
- 79713-H1805 GLASS-REAR WINDOW TINTED T=4.0
- 79713-H2201 GLASS-REAR WINDOW,TINTED HEAT RIGHT,T
- 79810-H1800 SET-MOULDING REAR WINDOW
- 79812-H1800 MOULDING-REAR WINDOW UPPER
- 79813-H1800 MOULDING-REAR WINDOW LOWER
- 79814-H1800 MOULDING-REAR WINDOW SIDE RH
- 79815-H1800 MOULDING-REAR WINDOW SIDE LH
- 79816-H1800 CLIP-MOULDING UPPER
- 79817-H1800 CLIP-MOULDING LOWER
Heated Glass
Heated rear glass (electric rear defroster) was an option for Sedan & Coupe.
For operating information, see Owner's manual, Heat Glass
ACC on the Ignition Switch feeds the Rear Defroster.
Sedan rear-glass wiring
Parts Sources
Rubber Sources
See Rubber parts
Glass Sources
- eBay
- Wrecking Yards
- Datsun1200.com Classifieds forum
- USA:
- Pilkington Classics 1-800-848-1351
- PPG Vintage 1-877-855-8100
ガラス ウインドー
