Datsun 1000 tail lights vary by model and country.
Side Lights
Datsun 1000 front guard was fitted with different indicator lamp lenses depending on the year.
1967 Model: Small Round dome type 26161-18000 LENS-lamp![]()
upload
1968-1969: Short spear (about 10cm long) 26161-25700 LENS-lamp (from C/# B10-80026, VB10-84001)![]()
1970: Long spear (13cm+). Same as Datsun 510 "1600" 26161-A4600 LENS-lamp (from C/# B10-350001, VB10-240001, KB10-80001, B20-61001)![]()
* Replaces spear A Same as JDM & ADM 510s
Coupes uses same lense as others, but the assembly (lamp housing) is different for Coupe.
1967 round type looks similar to 1969 Datsun 510 rear USA (EVER WING A3036 SAE P167), but this is much flatter (the B10 lens sticks out quite a bit).
Similar to Datsun 410 side lamp
1968-1960 short spear looks identical to USA Datsun 521 part number 26160-B0101
The 1970 long spear looks similar to USA 510, but those are asymmetric:
* 26161-21000 ASSY LENS WITH RIM RH 1068- 510 USA
* 26166-21000 ASSY LENS WITH RIM LH -0969 510 USA
Front Lights
Datsun 1000 was fitted with clear lens front combination lamp, using an orange bulb.
Australia
Aussie models had a orange bulb offset to the inside of the lens.
FRONT PARKING & TURN SIGNAL LAMP * Coupe: Below bumper * Sedan: Above bumper
PARKING & TURN SIGNAL LAMP ASSY H03 Coupe 209 Sedan, Wagon, Ute 1967 277 Sedan, Wagon, Ute 1968-1970
Sedan
Sedan clear rectangular lens
26120-20908 ASSY=LAMP,PARKING & TURN SIGNAL RH (TO SEP-'67) 26125-20908 ASSY=LAMP,PARKING & TURN SIGNAL LH (TO SEP-'67)
1967
26126-20900 LENS=TURN SIGNAL RH CLEAR (TO SEP-'67) 26127-20900 LENS=TURN SIGNAL LH AMBER (TO SEP-'67)
1967 Right
26122-20900, Right Amber Lens.
26120-27751 ASSY=LAMP,PARKING & TURN SIGNAL RH (FROM OCT-'67) 26125-27751 ASSY=LAMP,PARKING & TURN SIGNAL LH (FROM OCT-'67)
1968
26125-27750 'EVER WING EW0603L'
1968
1969
1969-1970
Coupe
Coupe front lights * 257 Early: Large Amber lens * H03 Late: 2-section (amber + clear)
Late Coupe: 2-section (amber + clear)
PARKING & TURN SIGNAL LAMP ASSY 26120-H0300 RH COUPE 26125-H0300 LH COUPE 26120-25702 Right 26125-25702 Left
26126-25702 lens, lh
Ute
Export B20 (B20U) introduction
Japan-market. Clear lens with centered orange bulb.
full
EXCEPT COUPE 26120-18000 ASS'Y-LAMP, & turn signal ALL except Coupe 26120-27701 RH 26125-27701 RH 26120-H0110 LH 26125-H0110 LH![]()
26121-18000 LENS-parking & turn signal (2)
COUPE 26120-18010 LENS-parking & turn signal (2) [1967?] 26120-25703 RH 26125-25703 LH 26120-H0310 RH 26125-H0310 LH![]()
Position
Sedan, Van, Ute: Fitted above the bumper
Coupe: Fitted below the bumper
Tail Lights
Datsun 1000 rear lamps were combination type.
Sedan
B10 Sedan rear lamps came in two styles.
1967-1960 reverse in center 1970 reverse inside, extra wide
180 type: 1967-1969full
H01 type: 1970 (from October 1969)full
H01 type
full
Coupe
KB10 taillights
Wagon
VB10 lamp
1968 (to September 1968), also 1967 Australia
182 1967 Red + Red 209 1967 Red + Amber Australia 209 1968 Red + Amber H04 1969-1970 Amber + Red + Clear
Reverse Lamp 1967-1968 Deluxe had separate lamp 1969-1970 Lower portion of tail lamps
1967 - note reverse lamp under right side of bumper
1969-1790 seperate lenses
26536-H0401 center lens
