A remote-mounted Hydraulic clutch Master cylinder may also be needed if there is not enough room in the engine compartment.
Contents[hide] |
Mount the clutch master inside the passenger compartment -- under the dash -- and connect it to the gearbox slave cylinder via a hydraulic line.
- Fabricate L-shaped bracket, bolt (or weld) to the under-dash steering column brace
- Lengthen clutch pedal, attach the master rod ABOVE the fulcrum
- Place the filler tube under the dash, connect to master via rubber hose
Girling
Under-dash mounted Girling clay pipe master
Girling "claypipe" master cylinder, available in 5/8" and 3/4" bores (about $70 AUD). Threads are 3/8 unc for pipe outlet and 7/16 unc for fluid in
Urvan
https://en.wikipedia.org/wiki/Nissan_Caravan
- Use with Nissan Urvan remote-fill tops
- A simple 90-degree bracket is fabricated to mount it to the under-dash steering column brace
Sentra
https://en.wikipedia.org/wiki/Nissan_Sentra
Nissan Sentra Clutch Master Cylinder
Fluid reservoir is connected to the cylinder via a rubber hose.
Lancer
https://en.wikipedia.org/wiki/Mitsubishi_Lancer_(A70)
For ideas, could something like this be used on a 1200?
Cable-to-Hydraulic custom remote clutch m/c found on Mitsubishi LA Lancer
