A14E Service Manual
Revision as of 10:15, 15 July 2016; view current revision
Categories: Documentation | Fuel Injection
Nissan Factory service manual for the A14E fuel injected engine, 1978 edition.
A14E Service Manual
A14E Service Manual Part 2 Engine Overhaul & Service Data
You can help us out! If you can type Japanese, please click Edit and type in the text. Also need help translating. Thanks!
A型 エンジン
A14型EGI仕様
(53年適合車版)
1978 整備要領書
A-series Engine
A14 type EGI specification
(1978 Standards Conforming Car)
1978 Service Manual
はじめに Introduction
はじめに
この本は、53年度排出ガス規制適合のNAPSを挟用したA系EGI仕 ...
Introduction
This book, A-specifications EGI system was for conforming the NAPS of 1978 fiscal exhaust gas regulations ...
目次 Table of Contents
[hide]
Summary 4
page 4
1. 概要
1. エンジン改?(エンジン本体、点火系)
2. EGI??
3. 排気ガス??(EGR)??〔〔VVT方代)
4. ?(触媒ペレットの改?)
5. (EAI)
1. Summary
  1. Engine ? (Engine main, ignition system)
  2. EGI
  3. EGR with VVT
  4. Catalytic Converter (pellet type)
  5. EAI
Engine Main Specifications 5
1-1 エンジン主要諸元 Engine Main Specifications
page 5
NAPS Specification List 6
1-2 NAPS仕様-覧 NAPS Specification - List
page 6
Engine Appearance 7
1-3 エンジン外観 Engine Appearance
page 7
1. 二?空気導入 Exhaust Air Induction Tube
2. Throttle Chamber
3. Air Regulator
4. EGR control valve
5. Dash Pot
page 8
1. Water temperature switch
2. TV valve
3. Water temp sensor
4. Blowby lower hose
page 9
1. Alternator
2. Distributor
3. Blowby upper hose
4. Pressure Regulator
5. VVT valve
6. VC solenoid valve
7. Fuel injector
Engine Sectional View 10
1-4 エンジン断面図 Engine Sectional View
page 10
Engine Performance Curve 11
1-5 エンジン性能曲線 Engine Performance Curve
page 11
NAPS System View 12
1-6 NAPSシステム図 NAPS System View
page 12
NAPS Piping Diagram 13
1-7 NAPS配管図 NAPS Piping Diagram
(1) Vacuum Hose Diagram
full
    mm
 1. 170 Vacuum gallery ~ pressure regulator
 2.  90 VVT tube ~ VVT valve
 3. 200 VVT valve ~ TV valve 3-way connector
 4.  70 Vacuum gallery ~ Distributor 3-way connector
 5.  50 Vacuum gallery ~ Distributor 3-way connector
 6. 190 Vacuum gallery ~ TV valve
 7. 170 EGR control valve ~ TV valve
 8. 110 TV valve ~ 3-way connector
 9. 540 Distributor ~ 3-way connector
10. 120 Vacuum gallery ~ VC solenoid valve
11. 200 VVT valve ~ VC solenoid valve
12. 200 Throttle chamber ~ vacuum gallery
13.  90 Vacuum connector ~ vacuum gallery
14. 130 Throttle chamber ~ vacuum gallery (for Distributor)
15. 230 Throttle chamber ~ VC solenoid valve
16. 170 Throttle chamber ~ vacuum gallery (for EGR control)
17.     Blind Cap
page 14
Engine Maintenance Notes 15
1-8 エンジン整備上の注意 Engine Maintenance Notes
page 15
page 16
page 17
Engine Start-up Notes 18
1-9 エンジン始動上の注意 Engine Start-up Notes
page 18
Regular Inspection And Maintenance 19
2. 定期点検整備 Regular inspection and maintenance
page 19
page 20
page 21
page 2
page 23
page 24
page 25
page 26
page 27
Checker 28
3. チェッカー Checker
Function Checker 28
3-1 ファンクション チェッカー Function Checker
page 28
page 29
EGI Harness Check 30
3-2 EGI ハーネス チェッカー (EG1131) EGI Harness Checker
page 30
(1) (2)page 31
page 31
page 32
page 33
EGI Circuit (page 34)
full | japanese
Checker: ハーネス実態図 EGI Harness Schematic View (page 35)
full | Japanese
page 36
page 37
EGI Control Unit Checker 38
3-3 EGIコントロール ユニット チェッカー EGI Control Unit Checker
page 38
page 39
page 40
page 41
Fault Diagnosis 42
4. 故障診断 Fault diagnosis
page 42
page 43
page 44
On-vehicle Engine Maintenance 45
5. 車載上のエンジン整備 On-vehicle Engine maintenance
Air Door Adjustment 45
5-1 アイ ドル調整
page 45
page 46
page 47
Air Cleaner and ? 48
5-2 エア クリーナー及びニ?空気?入(EAI)装
page 48
Throttle Chamber 89
5-8 スロットル チャンバー
page 89
Manifold 90
5-9 マニホールド
page 90
page 91
Cylinder Head 92
5-10 シリダー ヘッド
page 92
page 93
page 94
Catalyst ? 95
5-11 触媒コンベーター及び排気温?報装置
page 95
page 96
page 97
page 98
page 99
page 100
page 101
page 102
103
page 103
104
page 104
105
page 105
page 106
page 107
108
page 108
page 109
page 110
Engine ? 111
6. エンジン脱? Engine ?
page 111
page 112
page 113
Engine Overhaul 114
See A14E Service Manual Part 2
7 Engine Overhaul 114 7.1 Overhaul Notes 114
7.2 Disassembly 115
7.3 Inspection, Correction, Replacement 119 7.3.1 Cylinder Head and Valve 119
7.3.2 Cylinder Block 124
7.3.3 Piston, Piston Ring, Conrod 125
7.3.4 Crankshaft, Main Bearing 128
7.3.5 Camshaft 130
7.3.6 Other Components 131
7.4 Assembly 132
Service Data 141
8. サ=ビス データ Service Data
8.1 Standard Bolt, Nut Tightening Torque 141
8.2 Engine Torque Specs 142
8.3 Service Data 143
Special Tools And Checker 146
9. 特殊工具監及びチェッカー Special tools and checker
Special Tools 146
9-1 特殊工具
page 146
page 147
page 148
page 149
page 150
Checker and Check Sheet 151
9-2 チェッカー及びチェック シート
page 151
page 152
page 153
page 154
Inspection Circuits 155
10. 点検回路 Checking Circuits
Function Checker Check 155
10-1 ファンクション チェッカー チェック
page 155
EGI Harness Checker Check 156
10-2 EGI ハーネス チェッカー チェック
page 156
page 157
page 158
page 159
page 160
page 161
page 162
page 163
page 164
page 165
page 166
page 167
page 168
page 169
page 170
page 171
page 172
page 173
page 174
page 175
Memos
[pages 176-183 are blank "Memo" pages for taking notes]
Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum
page about publication
Back cover
日産自動車株式会社
Nissan Motor Co., Ltd.
