1000 Disc Brakes
asunny
Swap pioneered by asunny and D, photos by LAGWAGON
* B110 disc hub (newer 1200 hubs differ) * Mitsubishi/Chrysler rotor 229mm * PBR caliper * Sigma GE bracket * strongly recommend a dual-system master cylinder B110 or 120Y (non-boosted) master cylinder * Rear wheel cylinders swapped for 11/16" units
Weld the holes in the bracket, and drill new holes to suit the 1000.
ROTOR sizes * Mitsu: 229 mm * Late 120Y: 220 mm * 1200: 212 mm
Bolt modified Sigma bracket to 1000 axle
B110 hub * 1970-1973 1200 w/disc brakes * 1974-1975 120Y w/disc brakes (1976-1978 120Y differs)
early Sigma caliper machined to fit 1200 disc hub (inner circumference lathed by 3mm)
- disc centres machined out to suit the 1200 disc hubs
- 3 holes redrilled on the caliper bracket
- Finish a little of the corner of the new pads for clearance
- Use the standard flexible brake line from the 1000 wagon
PBR CALIPER * CHRYSLER Sigma GE PBR Front Disc 1978-1980 * NISSAN 120Y Sedan P.B.R Front Disc 1977-1979
DISC ROTOR 229 mm RDA 210 RAYBESTOS 9094R $22 Amazon.com * 1971-1980 Dodge Colt USA (with 229mm rotors) * 1976-1980 Plymouth Arrow USA * 1978-1980 Sigma GE (Chrysler Australia) * Mitsubishi Galant GC, GD 1974-1977 * Mitsubishi Lancer LA, LB, LC 1974-1981 Outside Diameter: 229 mm (9.005") Overall Height: 30mm (1.18") Number of Bolts/Holes: 4 Bolt Circle: 86mm (1200 disc hub is 87 mm) Discard Thickness: 11.4mm (0.449") Solid (non-vented)
Hamilton
Gary Hamilton managed to squeeze RX7 4-spots on his 1000 sport sedan which uses 13" wheels, but don't ask me how!
