Gearbox Mount
Revision as of 06:34, 19 February 2008; view current revision
Categories: Transmission | Drivetrain Modifications
The Rear Engine Crossmember is more commonly called the gearbox crossmember. This transmission crossmember hold the rear engine mount (transmission mount). The B210 and B310 crossmembers are wider than the B110 crossmember.
Nissan Part Numbers B110
  • 11322-H1020 MEMBER-engine mounting, rear Automatic
  • 11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
  • 11322-H7200 MEMBER-engine mounting, rear 5-speed
    • superceded by 11322-H7201 from 7210
  • 11322-H5200 MEMBER-engine mounting, rear Automatic
  • 11322-H5000 MEMBER-engine mounting, rear 3-speed, 4-speed (56-series)
  • 11322-H7400 MEMBER-engine mounting, rear from 7510 Van (also replaces 11322-H5000)
  • 11322-H5700 MEMBER-engine mounting, rear 5-speed F5C56
Gearbox Rubber Mount
There are two different types of rear engine mounts (transmission mounts).
  • One type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
  • This type, used with 60-series Transmission, bolts from the bottom:
